Tranquil 95 Posted August 14, 2015 Posted August 14, 2015 Hello Forum and Devs. I'm really at the end of my road and need your advice for my issue: If I use the Titan Skin (and only this skin) I get a frequent stuttering of video which is played via HTTP stream on my KODI system. It seems to just drop some frames every 2-3 Minutes for approx 8 seconds. No pixelation or audio jitters, all is good expect the missing frames. Live TV is not effected by this problem. In an older thread (dont know were exactly) I read about this problem from another guy. I upgraded all drivers and windows updates to be up2date. Also installed a much powerful CPU on my board (4 cores instead of my old dual core), tried different screenmodes fullscreen, windowed fullscreen, different Audiosystems (I have two sound devices installed). Titan: 3.4.1, Titan Helper Script: 1.8.2 What to do? I will try to post a kodi log asap, until now I cant find any lines that maybe belong to my problem in it.
Angelblue05 4132 Posted August 14, 2015 Posted August 14, 2015 Do you experience the lag when using confluence skin? What version of Kodi are you using? When you say played via HTTP, do you mean direct streaming or transcoding?
Tranquil 95 Posted August 14, 2015 Author Posted August 14, 2015 Hi Angelblue05. Thanks for jumping into my topic! I'm using Kodi 14.2 Stable. Via HTTP I mean direct played via 1 Gigabit LAN (which is also set in the Emby settings), no transcoding. In the past I do not experienced the issues with confluence or any other skin just with Titan Skin. I can give it a try when I'm back at home just to be sure that it is still the case. 1
Tranquil 95 Posted August 14, 2015 Author Posted August 14, 2015 (edited) Okay, this is the log of a video played some minutes: There are some lines with DEBUG: CDVDClock::Discontinuity - CDVDPlayerAudio::HandleSyncError2 - was:519948126.129715, should be:519958160.184162, error:10034.054448 Whatever that mean... 08:32:14 T:2276 DEBUG: CWinEventsWin32::WndProcWindow is inactive 08:32:19 T:4232 DEBUG: CPullupCorrection: detected pattern of length 1: 40000.00, frameduration: 40000.000000 08:33:33 T:3652 DEBUG: Thread RemoteControl 3652 terminating 08:33:44 T:604 DEBUG: CPVRTimers - PVR::CPVRTimers::Update - updating timers 08:33:44 T:604 INFO: AddOnLog: DVBLink PVR Client: Found 0 timers 08:33:49 T:604 DEBUG: CPVRRecordings - PVR::CPVRRecordings::Update - updating recordings 08:33:49 T:604 INFO: AddOnLog: DVBLink PVR Client: Found 4 recordings 08:38:49 T:604 DEBUG: CPVRTimers - PVR::CPVRTimers::Update - updating timers 08:38:49 T:604 INFO: AddOnLog: DVBLink PVR Client: Found 0 timers 08:38:54 T:604 DEBUG: CPVRRecordings - PVR::CPVRRecordings::Update - updating recordings 08:38:54 T:604 INFO: AddOnLog: DVBLink PVR Client: Found 4 recordings 08:40:15 T:4272 DEBUG: CDVDClock::Discontinuity - CDVDPlayerAudio::HandleSyncError2 - was:519948126.129715, should be:519958160.184162, error:10034.054448 08:43:54 T:604 DEBUG: CPVRTimers - PVR::CPVRTimers::Update - updating timers 08:43:54 T:604 INFO: AddOnLog: DVBLink PVR Client: Found 0 timers 08:43:59 T:604 DEBUG: CPVRRecordings - PVR::CPVRRecordings::Update - updating recordings 08:43:59 T:604 INFO: AddOnLog: DVBLink PVR Client: Found 4 recordings 08:48:50 T:4272 DEBUG: CDVDClock::Discontinuity - CDVDPlayerAudio::HandleSyncError2 - was:1034016186.363407, should be:1034026188.358190, error:10001.994782 08:48:59 T:604 DEBUG: CPVRTimers - PVR::CPVRTimers::Update - updating timers 08:48:59 T:604 INFO: AddOnLog: DVBLink PVR Client: Found 0 timers EDIT & UPDATE: No discontinuitys during playback if I use confluence and deinstalled titan & titan helper script. I played a video of 25 minutes without a problem. Edited August 14, 2015 by Tranquil
im85288 1493 Posted August 14, 2015 Posted August 14, 2015 I am guessing it is something to do with the helper script, but I think you should report this in the Titan thread so that marcelveldt can look into it. As a test maybe you can try disabling the helper script and initiating the same playback, if confirmed then it would help Marcel in trouble shooting the problem.
Tranquil 95 Posted August 20, 2015 Author Posted August 20, 2015 Dont know why, but this problem has gone after a fresh installation. What ever it was, hopefully it keeps away. :-) 1
