Been going on for over a month now. But Emby Theater not marking things as watched in Trakt. Well it does sometimes but maybe only 1/15 things played.
Just had a look at the logs - maybe someone could provide some assistance or advice? Seems like some sort of error when trying to update the status?
2015-08-12 20:32:24.2607 Info - Trakt: Playback Started2015-08-12
20:32:24.5337 Info - App: HttpClientManager POST: https://api-v2launch.trakt.tv/auth/login2015-08-12
20:32:25.4988 Info - App: HttpClientManager POST: https://api-v2launch.trakt.tv/scrobble/start2015-08-12
21:01:25.5954 Info - App: Udp message sent to 10.10.10.23:414642015-08-12
21:01:25.5974 Info - App: Udp message sent to 10.10.10.23:414642015-08-12
21:01:27.3575 Info - App: HttpClientManager POST: http://www.mb3admin.com/admin/service/registration/ping2015-08-12
21:22:22.2870 Info - Trakt: Playback Stopped2015-08-12 21:22:22.2870 Info -
Trakt: Item is played. Scrobble2015-08-12 21:22:22.4620 Error - Trakt:
Exception handled sending status update *** Error Report
*** Version: 3.0.5675.1 Command line:
C:\Users\HTPC\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating
system: Microsoft Windows NT 6.2.9200.0 Processor count:
2 64-Bit OS: True 64-Bit Process: False Program data
path: C:\Users\HTPC\AppData\Roaming\MediaBrowser-Server Application
Path:
C:\Users\HTPC\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe The
request was aborted: Could not create SSL/TLS secure
channel. System.Net.WebException    at
System.Net.HttpWebRequest.GetRequestStream(TransportContext&
context)    at
System.Net.HttpWebRequest.GetRequestStream()    at
MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__1e.MoveNext() ---
End of stack trace from previous location where exception was thrown
---    at
System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task
task)    at
System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task
task)    at
MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsync>d__7.MoveNext() ---
---    at
task)    at
task)    at
Trakt.Api.TraktApi.<PostToTrakt>d__c5.MoveNext() --- End of stack
---    at
task)    at
task)    at
System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task
task)    at
Trakt.Api.TraktApi.<SendEpisodeStatusUpdateAsync>d__13.MoveNext() ---
---    at
task)    at
task)    at
Trakt.ServerMediator.<KernelPlaybackStopped>d__8.MoveNext() 2015-08-12
21:26:39.4938 Info - Trakt: Playback Started2015-08-12 21:26:39.6429 Info -
21:57:52.7071 Info - Trakt: Playback Stopped2015-08-12 21:57:52.7071 Info -
