Scheduled Recordings not working past first one.
mellomade
First let me say that EmbyTV has been a breeze to work with so far!  Everything was smooth setting it up and I can see my guide and view LiveTV just fine.  I can also record successfully single shows from the guide.
Here is where I am having trouble.  I choose a show from the guide I want to record.  When I choose "Record Series" in the Record options then select every day and record anytime in the repeat options - the series gets saved to the Series list fine.  When I go to Scheduled - the only show that populates this list is the one from the time I created the series recording from.  No other shows for that name populate the list - when other instances are clearly in the guide for that channel - and therefore they do not get recorded.  It seems that whatever is in the scheduled list is what gets recorded irrespective of the series settings.
Bug?
I should note that I am using EmbyTV from the dev server build 3.0.5699.18256.
Edited by mellomade
  • 3 weeks later...
Just found this today actually:
That would most likely be why  :)  - guess i'll have to shell out to be a supporter too
