Deihmos 170 Posted August 9, 2015 Posted August 9, 2015 (edited) It use to work before but not anymore. I did a new install and the thumb isn't generating and I don't see a way to get it done. There are a few collections in the folder. Edited August 9, 2015 by Deihmos 1
Rasputin 2 Posted August 9, 2015 Posted August 9, 2015 Make sure your Collections are checked on in the "My Views" section under user settings > home screen settings. They won't automatically group and generate an image, otherwise.
Guest Posted March 24, 2018 Posted March 24, 2018 I'm having this same issue but with an up-to-date version of Emby Version 3.3.1.0. It's been a day since I added this directory to the library. While two out of four thumbnails were created, the last two did not create thumbnails (see attached screen capture emby thumbnails not showing.png). What I noticed was that if I click on one of those folders's three dots and go to Refresh Metadata and then tick the "Replace existing images" and hit the Refresh button, it WILL update the thumbnail (see another screen capture emby thumbnails showing.png), but I would expect this to be done automatically, and not me having to go through all my folders and do this manually now.
Luke 42208 Posted March 24, 2018 Posted March 24, 2018 Please try again with the next release of emby server, thanks.
Guest Posted March 24, 2018 Posted March 24, 2018 Please try again with the next release of emby server, thanks. ok
