pir8radio 1313 Posted August 7, 2015 Posted August 7, 2015 (edited) My Emby logs are flooded with thousands of the below errors... Not sure what device emby is seeing that it then tries to connect to? I assume its something on my security camera network that is all IPV6 NO IPV4... Is there a way to bind emby's DLNA to one network interface? Otherwise can someone help me find this rogue device so i can kill it.. or disable DLNA. 2015-08-07 00:06:24.1057 Error - Dlna: Error creating PlayTo device. *** Error Report *** Version: 3.0.5695.36729 Command line: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 20 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Unable to connect to the remote server MediaBrowser.Model.Net.HttpException at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__1e.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsync>d__7.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<Get>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Dlna.PlayTo.SsdpHttpClient.<GetDataAsync>d__a.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Dlna.PlayTo.Device.<CreateuPnpDeviceAsync>d__cc.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Dlna.PlayTo.PlayToManager.<_deviceDiscovery_DeviceDiscovered>d__8.MoveNext() InnerException: System.Net.WebException Unable to connect to the remote server at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) InnerException: System.Net.Sockets.SocketException A socket operation was attempted to an unreachable network 169.254.5.70:49152 at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) 2015-08-07 00:06:25.1088 Info - App: HttpClientManager GET: http://169.254.5.70:49152/4/description.xml 2015-08-07 00:06:25.1088 Info - App: HttpClientManager GET: http://169.254.5.70:49152/4/description.xml 2015-08-07 00:06:25.1088 Error - App: Error getting response from http://169.254.5.70:49152/4/description.xml *** Error Report *** Version: 3.0.5695.36729 Command line: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 20 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Unable to connect to the remote server System.Net.WebException at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) InnerException: System.Net.Sockets.SocketException A socket operation was attempted to an unreachable network 169.254.5.70:49152 at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) 2015-08-07 00:06:25.1088 Error - App: Error getting response from http://169.254.5.70:49152/4/description.xml *** Error Report *** Version: 3.0.5695.36729 Command line: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 20 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Unable to connect to the remote server System.Net.WebException at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) InnerException: System.Net.Sockets.SocketException A socket operation was attempted to an unreachable network 169.254.5.70:49152 at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) 2015-08-07 00:06:25.1088 Error - Dlna: Error creating PlayTo device. *** Error Report *** Version: 3.0.5695.36729 Command line: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 20 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Unable to connect to the remote server MediaBrowser.Model.Net.HttpException at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__1e.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsync>d__7.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<Get>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Dlna.PlayTo.SsdpHttpClient.<GetDataAsync>d__a.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Dlna.PlayTo.Device.<CreateuPnpDeviceAsync>d__cc.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Dlna.PlayTo.PlayToManager.<_deviceDiscovery_DeviceDiscovered>d__8.MoveNext() InnerException: System.Net.WebException Unable to connect to the remote server at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) InnerException: System.Net.Sockets.SocketException A socket operation was attempted to an unreachable network 169.254.5.70:49152 at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) 2015-08-07 00:06:25.1088 Error - Dlna: Error creating PlayTo device. *** Error Report *** Version: 3.0.5695.36729 Command line: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 20 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Unable to connect to the remote server MediaBrowser.Model.Net.HttpException at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__1e.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsync>d__7.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<Get>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Dlna.PlayTo.SsdpHttpClient.<GetDataAsync>d__a.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Dlna.PlayTo.Device.<CreateuPnpDeviceAsync>d__cc.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Dlna.PlayTo.PlayToManager.<_deviceDiscovery_DeviceDiscovered>d__8.MoveNext() InnerException: System.Net.WebException Unable to connect to the remote server at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) InnerException: System.Net.Sockets.SocketException A socket operation was attempted to an unreachable network 169.254.5.70:49152 at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) 2015-08-07 00:17:21.1213 Info - App: HttpClientManager GET: http://10.0.1.7:49152/4/description.xml 2015-08-07 00:17:21.1213 Info - App: HttpClientManager GET: http://10.0.1.7:49152/4/description.xml 2015-08-07 00:17:21.1213 Info - App: HttpClientManager GET: http://169.254.5.70:49152/4/description.xml 2015-08-07 00:17:21.1213 Info - App: HttpClientManager GET: http://169.254.5.70:49152/4/description.xml 2015-08-07 00:17:21.1213 Error - App: Error getting response from http://169.254.5.70:49152/4/description.xml *** Error Report *** Version: 3.0.5695.36729 Command line: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 20 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\XXXX-User\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Unable to connect to the remote server System.Net.WebException at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) InnerException: System.Net.Sockets.SocketException A socket operation was attempted to an unreachable network 169.254.5.70:49152 at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) Edited August 8, 2015 by pir8radio
Raff 51 Posted August 7, 2015 Posted August 7, 2015 Yeah, I hate rouge devices - I prefer mine to be a nice matte black. Anyway - that is a really high port number, and is considered the "dynamic/transient" range where stuff gets handed over. I guess it is possible, but I don't image something would permanently bind to that port. However, the bigger issue is the 169.254.X.X IP - that says the device doesn't use DHCP and doesn't have an IP set. Maybe those cameras do have IPv4 but it is currently misconfigured?
pir8radio 1313 Posted August 8, 2015 Author Posted August 8, 2015 (edited) Oops, fat fingered that one, can't change the title... Oh well.... Yea they do support ipv4 but they do not have any IP's assigned to them.. I have 4 cameras, all setup the same, this appears to be the only one acting up.. Hum... I'll wireshark and see if I can find a mac address or something... Edited August 8, 2015 by pir8radio
