Need help
Lightprincess98
Lightprincess98
Hello.
I know I am new here, but I am running into a problem, and need help.
Running Kodi 15.0 Isengard
Emby 1.1.26
Windows 10 (Edit)
Log is attached.
Thank you for taking the time
kodi.log
Edited by Lightprincess98
Angelblue05
Very strange.... Is your userdata corrupted? It seems to be unable to find the database file, then after it throws some error that the Emby add-on doesn't exist? Try reinstalling the add-on first, see if this solves the issue. If not, I'd delete or rename your userdata folder to force Kodi to recreate it.
  • Like 1
Lightprincess98
Removing userdata seemed to have worked. It was performing a full sync, but I think the sync failed because I already have all the shows and everything that is on Emby set on Kodi. Thanks for the help
  • Like 1
Guest
