Nathanio 35 Posted August 5, 2015 Posted August 5, 2015 Hi I am trying out using emby live tv as my new backend to move away from WMC. I have a HDHR4-2DT freeview tuner in the UK receiving DVB-T2. I have set the tuner up and it appears to be working as I can get a stream through emby (to all bar Windows 8 native app). I have spoken to Robert to get a trial of SD in the UK but when trying to configure emby it only gives me US options and no UK options Thanks
Nathanio 35 Posted August 6, 2015 Author Posted August 6, 2015 Can anyone help? At the moment I am finding it all very frustrating!
Luke 42242 Posted August 6, 2015 Posted August 6, 2015 UK has not been added to EmbyTV yet, so for now you will need to use one of the other Live TV plugins.
Nathanio 35 Posted August 6, 2015 Author Posted August 6, 2015 I take that includes the EmbyTV plugin? Do you have an ETA Luke for when it will be? Thanks
benjamoomin 3 Posted August 6, 2015 Posted August 6, 2015 Also eager to find out about this. I was planning shortly to buy one of these tuners just for this purpose and get fully on board with emby and move away from 10 years of mediaportal. Once UK freeview channels are supported I'd love to know if schedules direct can supply epg for all the channels.
Nathanio 35 Posted August 7, 2015 Author Posted August 7, 2015 Hi Ben, I have started to play with NextPVR and Emby. I have got the basics working but need to do a lot of tweaking to get it were i'd like it. No series recording (yet) with it through emby but I think it will do it through the web interface of NPVR so there is options. The HD HR Connect itself is quite a cool piece of kit and I like the decoupling of PC and tuners.
rkulagow 19 Posted August 7, 2015 Posted August 7, 2015 Also eager to find out about this. I was planning shortly to buy one of these tuners just for this purpose and get fully on board with emby and move away from 10 years of mediaportal. Once UK freeview channels are supported I'd love to know if schedules direct can supply epg for all the channels. [i work for Schedules Direct] We already have Freeview available; if you PM me your postal code then I can send you what we have in the lineup and what the data looks like so that you know what to expect once the plugin goes live.
benjamoomin 3 Posted August 8, 2015 Posted August 8, 2015 Thanks for the info Nathanio. I'm in the middle of a house move so I'll be looking to hopefully implement a new set up in a couple months. Hopefully by then emby tv will be fully live including UK channels. Thanks rkulagow I've sent you a pm
ssperring 2 Posted August 31, 2015 Posted August 31, 2015 So I have set up emby TV with the UK options and my postcode but a large amount of channels have no guide data or are incorrectly mapped, same for logos. I've used both the BskyB and freesat guide options same results. Anything I can provide to help? Or where can I make a manual re-map? Thanks.
Latchmor 584 Posted August 31, 2015 Posted August 31, 2015 So I have set up emby TV with the UK options and my postcode but a large amount of channels have no guide data or are incorrectly mapped, same for logos. I've used both the BskyB and freesat guide options same results. Anything I can provide to help? Or where can I make a manual re-map? Thanks. Hi, are you using all of your post code? I had issues before I realised that only the first part of the post code was needed. Once I only used the first part I had more lineups to choose from and found one better suited to my location.
ebr 16335 Posted August 31, 2015 Posted August 31, 2015 So I have set up emby TV with the UK options and my postcode but a large amount of channels have no guide data or are incorrectly mapped, same for logos. I've used both the BskyB and freesat guide options same results. Anything I can provide to help? Or where can I make a manual re-map? Thanks. Also please do this.
ssperring 2 Posted August 31, 2015 Posted August 31, 2015 (edited) Thanks for the quick responses and yep Latchmor that did the trick. If you still want it ebr here you go, i have disabled some channels on my homerun as I never watch them, if you'd like to see them let me know. A couple still aren't right but i may just disable them too. [{"GuideNumber":"1","GuideName":"BBC ONE South","URL":"http://192.168.0.15:5004/auto/v1"},{"GuideNumber":"2","GuideName":"BBC TWO","URL":"http://192.168.0.15:5004/auto/v2"},{"GuideNumber":"3","GuideName":"ITV","URL":"http://192.168.0.15:5004/auto/v3"},{"GuideNumber":"4","GuideName":"Channel 4","URL":"http://192.168.0.15:5004/auto/v4"},{"GuideNumber":"5","GuideName":"Channel 5","URL":"http://192.168.0.15:5004/auto/v5"},{"GuideNumber":"6","GuideName":"ITV2","URL":"http://192.168.0.15:5004/auto/v6"},{"GuideNumber":"7","GuideName":"BBC THREE","URL":"http://192.168.0.15:5004/auto/v7"},{"GuideNumber":"8","GuideName":"That's Solent","URL":"http://192.168.0.15:5004/auto/v8"},{"GuideNumber":"9","GuideName":"BBC FOUR","URL":"http://192.168.0.15:5004/auto/v9"},{"GuideNumber":"10","GuideName":"ITV3","URL":"http://192.168.0.15:5004/auto/v10"},{"GuideNumber":"11","GuideName":"Pick","URL":"http://192.168.0.15:5004/auto/v11"},{"GuideNumber":"12","GuideName":"Dave","URL":"http://192.168.0.15:5004/auto/v12"},{"GuideNumber":"13","GuideName":"Channel 4+1","URL":"http://192.168.0.15:5004/auto/v13"},{"GuideNumber":"14","GuideName":"More 4","URL":"http://192.168.0.15:5004/auto/v14"},{"GuideNumber":"15","GuideName":"Film4","URL":"http://192.168.0.15:5004/auto/v15"},{"GuideNumber":"16","GuideName":"QVC","URL":"http://192.168.0.15:5004/auto/v16"},{"GuideNumber":"17","GuideName":"Really","URL":"http://192.168.0.15:5004/auto/v17"},{"GuideNumber":"18","GuideName":"4Music","URL":"http://192.168.0.15:5004/auto/v18"},{"GuideNumber":"19","GuideName":"Yesterday","URL":"http://192.168.0.15:5004/auto/v19"},{"GuideNumber":"20","GuideName":"Drama","URL":"http://192.168.0.15:5004/auto/v20"},{"GuideNumber":"21","GuideName":"5 USA","URL":"http://192.168.0.15:5004/auto/v21"},{"GuideNumber":"22","GuideName":"Ideal World","URL":"http://192.168.0.15:5004/auto/v22"},{"GuideNumber":"24","GuideName":"ITV4","URL":"http://192.168.0.15:5004/auto/v24"},{"GuideNumber":"25","GuideName":"Dave ja vu","URL":"http://192.168.0.15:5004/auto/v25"},{"GuideNumber":"26","GuideName":"ITVBe","URL":"http://192.168.0.15:5004/auto/v26"},{"GuideNumber":"27","GuideName":"ITV2 +1","URL":"http://192.168.0.15:5004/auto/v27"},{"GuideNumber":"28","GuideName":"E4","URL":"http://192.168.0.15:5004/auto/v28"},{"GuideNumber":"29","GuideName":"E4+1","URL":"http://192.168.0.15:5004/auto/v29"},{"GuideNumber":"30","GuideName":"5*","URL":"http://192.168.0.15:5004/auto/v30"},{"GuideNumber":"31","GuideName":"Spike","URL":"http://192.168.0.15:5004/auto/v31"},{"GuideNumber":"32","GuideName":"Movie Mix","URL":"http://192.168.0.15:5004/auto/v32"},{"GuideNumber":"33","GuideName":"ITV +1","URL":"http://192.168.0.15:5004/auto/v33"},{"GuideNumber":"34","GuideName":"ITV3+1","URL":"http://192.168.0.15:5004/auto/v34"},{"GuideNumber":"40","GuideName":"Rocks & Co 1","URL":"http://192.168.0.15:5004/auto/v40"},{"GuideNumber":"41","GuideName":"Food Network","URL":"http://192.168.0.15:5004/auto/v41"},{"GuideNumber":"42","GuideName":"Travel Channel","URL":"http://192.168.0.15:5004/auto/v42"},{"GuideNumber":"44","GuideName":"Channel 5+1","URL":"http://192.168.0.15:5004/auto/v44"},{"GuideNumber":"45","GuideName":"Film4+1","URL":"http://192.168.0.15:5004/auto/v45"},{"GuideNumber":"46","GuideName":"Challenge","URL":"http://192.168.0.15:5004/auto/v46"},{"GuideNumber":"47","GuideName":"4seven","URL":"http://192.168.0.15:5004/auto/v47"},{"GuideNumber":"48","GuideName":"movies4men","URL":"http://192.168.0.15:5004/auto/v48"},{"GuideNumber":"55","GuideName":"Channel 5+24","URL":"http://192.168.0.15:5004/auto/v55"},{"GuideNumber":"58","GuideName":"VIVA","URL":"http://192.168.0.15:5004/auto/v58"},{"GuideNumber":"59","GuideName":"BT Showcase","URL":"http://192.168.0.15:5004/auto/v59"},{"GuideNumber":"61","GuideName":"True Entertainm","URL":"http://192.168.0.15:5004/auto/v61"},{"GuideNumber":"62","GuideName":"ITV4+1","URL":"http://192.168.0.15:5004/auto/v62"},{"GuideNumber":"66","GuideName":"CBS Reality","URL":"http://192.168.0.15:5004/auto/v66"},{"GuideNumber":"70","GuideName":"Horror Channel","URL":"http://192.168.0.15:5004/auto/v70"},{"GuideNumber":"71","GuideName":"Motors TV","URL":"http://192.168.0.15:5004/auto/v71"},{"GuideNumber":"72","GuideName":"ITVBe+1","URL":"http://192.168.0.15:5004/auto/v72"},{"GuideNumber":"74","GuideName":"CBS Drama","URL":"http://192.168.0.15:5004/auto/v74"},{"GuideNumber":"101","GuideName":"BBC ONE HD","URL":"http://192.168.0.15:5004/auto/v101"},{"GuideNumber":"102","GuideName":"BBC TWO HD","URL":"http://192.168.0.15:5004/auto/v102"},{"GuideNumber":"103","GuideName":"ITV HD","URL":"http://192.168.0.15:5004/auto/v103"},{"GuideNumber":"104","GuideName":"Channel 4 HD","URL":"http://192.168.0.15:5004/auto/v104"},{"GuideNumber":"105","GuideName":"BBC THREE HD","URL":"http://192.168.0.15:5004/auto/v105"},{"GuideNumber":"106","GuideName":"BBC FOUR HD","URL":"http://192.168.0.15:5004/auto/v106"},{"GuideNumber":"107","GuideName":"BBC NEWS HD","URL":"http://192.168.0.15:5004/auto/v107"},{"GuideNumber":"108","GuideName":"Al Jazeera Eng","URL":"http://192.168.0.15:5004/auto/v108"},{"GuideNumber":"109","GuideName":"Channel 4+1 HD","URL":"http://192.168.0.15:5004/auto/v109"},{"GuideNumber":"110","GuideName":"4seven HD","URL":"http://192.168.0.15:5004/auto/v110"},{"GuideNumber":"120","GuideName":"CBBC","URL":"http://192.168.0.15:5004/auto/v120"},{"GuideNumber":"121","GuideName":"CBeebies","URL":"http://192.168.0.15:5004/auto/v121"},{"GuideNumber":"122","GuideName":"CITV","URL":"http://192.168.0.15:5004/auto/v122"},{"GuideNumber":"123","GuideName":"CBBC HD","URL":"http://192.168.0.15:5004/auto/v123"},{"GuideNumber":"124","GuideName":"CBeebies HD","URL":"http://192.168.0.15:5004/auto/v124"},{"GuideNumber":"125","GuideName":"POP","URL":"http://192.168.0.15:5004/auto/v125"},{"GuideNumber":"126","GuideName":"Tiny Pop","URL":"http://192.168.0.15:5004/auto/v126"},{"GuideNumber":"130","GuideName":"BBC NEWS","URL":"http://192.168.0.15:5004/auto/v130"},{"GuideNumber":"131","GuideName":"BBC Parliament","URL":"http://192.168.0.15:5004/auto/v131"},{"GuideNumber":"132","GuideName":"Sky News","URL":"http://192.168.0.15:5004/auto/v132"},{"GuideNumber":"200","GuideName":"BBC Red Button","URL":"http://192.168.0.15:5004/auto/v200"},{"GuideNumber":"245","GuideName":"Planet Knowledg","URL":"http://192.168.0.15:5004/auto/v245"},{"GuideNumber":"601","GuideName":"BBC RB 1","URL":"http://192.168.0.15:5004/auto/v601"},{"GuideNumber":"602","GuideName":"BBC RB 2","URL":"http://192.168.0.15:5004/auto/v602"},{"GuideNumber":"603","GuideName":"BBC RB 3","URL":"http://192.168.0.15:5004/auto/v603"},{"GuideNumber":"700","GuideName":"BBC Radio 1","URL":"http://192.168.0.15:5004/auto/v700"},{"GuideNumber":"701","GuideName":"BBC R1X","URL":"http://192.168.0.15:5004/auto/v701"},{"GuideNumber":"702","GuideName":"BBC Radio 2","URL":"http://192.168.0.15:5004/auto/v702"},{"GuideNumber":"711","GuideName":"The Hits Radio","URL":"http://192.168.0.15:5004/auto/v711"},{"GuideNumber":"712","GuideName":"KISS FRESH","URL":"http://192.168.0.15:5004/auto/v712"},{"GuideNumber":"713","GuideName":"Kiss","URL":"http://192.168.0.15:5004/auto/v713"},{"GuideNumber":"714","GuideName":"KISSTORY","URL":"http://192.168.0.15:5004/auto/v714"},{"GuideNumber":"715","GuideName":"Magic","URL":"http://192.168.0.15:5004/auto/v715"},{"GuideNumber":"716","GuideName":"heat","URL":"http://192.168.0.15:5004/auto/v716"},{"GuideNumber":"717","GuideName":"Kerrang!","URL":"http://192.168.0.15:5004/auto/v717"},{"GuideNumber":"718","GuideName":"Smooth Radio","URL":"http://192.168.0.15:5004/auto/v718"},{"GuideNumber":"719","GuideName":"BBC Solent","URL":"http://192.168.0.15:5004/auto/v719"},{"GuideNumber":"723","GuideName":"talkSPORT","URL":"http://192.168.0.15:5004/auto/v723"},{"GuideNumber":"724","GuideName":"Capital FM","URL":"http://192.168.0.15:5004/auto/v724"},{"GuideNumber":"725","GuideName":"Premier Radio","URL":"http://192.168.0.15:5004/auto/v725"},{"GuideNumber":"727","GuideName":"Absolute Radio","URL":"http://192.168.0.15:5004/auto/v727"},{"GuideNumber":"728","GuideName":"Heart","URL":"http://192.168.0.15:5004/auto/v728"},{"GuideNumber":"792","GuideName":"ITV4","URL":"http://192.168.0.15:5004/auto/v792"},{"GuideNumber":"793","GuideName":"ITV3+1","URL":"http://192.168.0.15:5004/auto/v793"},{"GuideNumber":"795","GuideName":"CITV","URL":"http://192.168.0.15:5004/auto/v795"}] Edited August 31, 2015 by ssperring 1
Nathanio 35 Posted August 31, 2015 Author Posted August 31, 2015 Hi, are you using all of your post code? I had issues before I realised that only the first part of the post code was needed. Once I only used the first part I had more lineups to choose from and found one better suited to my location. Thanks for the quick responses and yep Latchmor that did the trick. If you still want it ebr here you go, i have disabled some channels on my homerun as I never watch them, if you'd like to see them let me know. A couple still aren't right but i may just disable them too. [{"GuideNumber":"1","GuideName":"BBC ONE South","URL":"http://192.168.0.15:5004/auto/v1"},{"GuideNumber":"2","GuideName":"BBC TWO","URL":"http://192.168.0.15:5004/auto/v2"},{"GuideNumber":"3","GuideName":"ITV","URL":"http://192.168.0.15:5004/auto/v3"},{"GuideNumber":"4","GuideName":"Channel 4","URL":"http://192.168.0.15:5004/auto/v4"},{"GuideNumber":"5","GuideName":"Channel 5","URL":"http://192.168.0.15:5004/auto/v5"},{"GuideNumber":"6","GuideName":"ITV2","URL":"http://192.168.0.15:5004/auto/v6"},{"GuideNumber":"7","GuideName":"BBC THREE","URL":"http://192.168.0.15:5004/auto/v7"},{"GuideNumber":"8","GuideName":"That's Solent","URL":"http://192.168.0.15:5004/auto/v8"},{"GuideNumber":"9","GuideName":"BBC FOUR","URL":"http://192.168.0.15:5004/auto/v9"},{"GuideNumber":"10","GuideName":"ITV3","URL":"http://192.168.0.15:5004/auto/v10"},{"GuideNumber":"11","GuideName":"Pick","URL":"http://192.168.0.15:5004/auto/v11"},{"GuideNumber":"12","GuideName":"Dave","URL":"http://192.168.0.15:5004/auto/v12"},{"GuideNumber":"13","GuideName":"Channel 4+1","URL":"http://192.168.0.15:5004/auto/v13"},{"GuideNumber":"14","GuideName":"More 4","URL":"http://192.168.0.15:5004/auto/v14"},{"GuideNumber":"15","GuideName":"Film4","URL":"http://192.168.0.15:5004/auto/v15"},{"GuideNumber":"16","GuideName":"QVC","URL":"http://192.168.0.15:5004/auto/v16"},{"GuideNumber":"17","GuideName":"Really","URL":"http://192.168.0.15:5004/auto/v17"},{"GuideNumber":"18","GuideName":"4Music","URL":"http://192.168.0.15:5004/auto/v18"},{"GuideNumber":"19","GuideName":"Yesterday","URL":"http://192.168.0.15:5004/auto/v19"},{"GuideNumber":"20","GuideName":"Drama","URL":"http://192.168.0.15:5004/auto/v20"},{"GuideNumber":"21","GuideName":"5 USA","URL":"http://192.168.0.15:5004/auto/v21"},{"GuideNumber":"22","GuideName":"Ideal World","URL":"http://192.168.0.15:5004/auto/v22"},{"GuideNumber":"24","GuideName":"ITV4","URL":"http://192.168.0.15:5004/auto/v24"},{"GuideNumber":"25","GuideName":"Dave ja vu","URL":"http://192.168.0.15:5004/auto/v25"},{"GuideNumber":"26","GuideName":"ITVBe","URL":"http://192.168.0.15:5004/auto/v26"},{"GuideNumber":"27","GuideName":"ITV2 +1","URL":"http://192.168.0.15:5004/auto/v27"},{"GuideNumber":"28","GuideName":"E4","URL":"http://192.168.0.15:5004/auto/v28"},{"GuideNumber":"29","GuideName":"E4+1","URL":"http://192.168.0.15:5004/auto/v29"},{"GuideNumber":"30","GuideName":"5*","URL":"http://192.168.0.15:5004/auto/v30"},{"GuideNumber":"31","GuideName":"Spike","URL":"http://192.168.0.15:5004/auto/v31"},{"GuideNumber":"32","GuideName":"Movie Mix","URL":"http://192.168.0.15:5004/auto/v32"},{"GuideNumber":"33","GuideName":"ITV +1","URL":"http://192.168.0.15:5004/auto/v33"},{"GuideNumber":"34","GuideName":"ITV3+1","URL":"http://192.168.0.15:5004/auto/v34"},{"GuideNumber":"40","GuideName":"Rocks & Co 1","URL":"http://192.168.0.15:5004/auto/v40"},{"GuideNumber":"41","GuideName":"Food Network","URL":"http://192.168.0.15:5004/auto/v41"},{"GuideNumber":"42","GuideName":"Travel Channel","URL":"http://192.168.0.15:5004/auto/v42"},{"GuideNumber":"44","GuideName":"Channel 5+1","URL":"http://192.168.0.15:5004/auto/v44"},{"GuideNumber":"45","GuideName":"Film4+1","URL":"http://192.168.0.15:5004/auto/v45"},{"GuideNumber":"46","GuideName":"Challenge","URL":"http://192.168.0.15:5004/auto/v46"},{"GuideNumber":"47","GuideName":"4seven","URL":"http://192.168.0.15:5004/auto/v47"},{"GuideNumber":"48","GuideName":"movies4men","URL":"http://192.168.0.15:5004/auto/v48"},{"GuideNumber":"55","GuideName":"Channel 5+24","URL":"http://192.168.0.15:5004/auto/v55"},{"GuideNumber":"58","GuideName":"VIVA","URL":"http://192.168.0.15:5004/auto/v58"},{"GuideNumber":"59","GuideName":"BT Showcase","URL":"http://192.168.0.15:5004/auto/v59"},{"GuideNumber":"61","GuideName":"True Entertainm","URL":"http://192.168.0.15:5004/auto/v61"},{"GuideNumber":"62","GuideName":"ITV4+1","URL":"http://192.168.0.15:5004/auto/v62"},{"GuideNumber":"66","GuideName":"CBS Reality","URL":"http://192.168.0.15:5004/auto/v66"},{"GuideNumber":"70","GuideName":"Horror Channel","URL":"http://192.168.0.15:5004/auto/v70"},{"GuideNumber":"71","GuideName":"Motors TV","URL":"http://192.168.0.15:5004/auto/v71"},{"GuideNumber":"72","GuideName":"ITVBe+1","URL":"http://192.168.0.15:5004/auto/v72"},{"GuideNumber":"74","GuideName":"CBS Drama","URL":"http://192.168.0.15:5004/auto/v74"},{"GuideNumber":"101","GuideName":"BBC ONE HD","URL":"http://192.168.0.15:5004/auto/v101"},{"GuideNumber":"102","GuideName":"BBC TWO HD","URL":"http://192.168.0.15:5004/auto/v102"},{"GuideNumber":"103","GuideName":"ITV HD","URL":"http://192.168.0.15:5004/auto/v103"},{"GuideNumber":"104","GuideName":"Channel 4 HD","URL":"http://192.168.0.15:5004/auto/v104"},{"GuideNumber":"105","GuideName":"BBC THREE HD","URL":"http://192.168.0.15:5004/auto/v105"},{"GuideNumber":"106","GuideName":"BBC FOUR HD","URL":"http://192.168.0.15:5004/auto/v106"},{"GuideNumber":"107","GuideName":"BBC NEWS HD","URL":"http://192.168.0.15:5004/auto/v107"},{"GuideNumber":"108","GuideName":"Al Jazeera Eng","URL":"http://192.168.0.15:5004/auto/v108"},{"GuideNumber":"109","GuideName":"Channel 4+1 HD","URL":"http://192.168.0.15:5004/auto/v109"},{"GuideNumber":"110","GuideName":"4seven HD","URL":"http://192.168.0.15:5004/auto/v110"},{"GuideNumber":"120","GuideName":"CBBC","URL":"http://192.168.0.15:5004/auto/v120"},{"GuideNumber":"121","GuideName":"CBeebies","URL":"http://192.168.0.15:5004/auto/v121"},{"GuideNumber":"122","GuideName":"CITV","URL":"http://192.168.0.15:5004/auto/v122"},{"GuideNumber":"123","GuideName":"CBBC HD","URL":"http://192.168.0.15:5004/auto/v123"},{"GuideNumber":"124","GuideName":"CBeebies HD","URL":"http://192.168.0.15:5004/auto/v124"},{"GuideNumber":"125","GuideName":"POP","URL":"http://192.168.0.15:5004/auto/v125"},{"GuideNumber":"126","GuideName":"Tiny Pop","URL":"http://192.168.0.15:5004/auto/v126"},{"GuideNumber":"130","GuideName":"BBC NEWS","URL":"http://192.168.0.15:5004/auto/v130"},{"GuideNumber":"131","GuideName":"BBC Parliament","URL":"http://192.168.0.15:5004/auto/v131"},{"GuideNumber":"132","GuideName":"Sky News","URL":"http://192.168.0.15:5004/auto/v132"},{"GuideNumber":"200","GuideName":"BBC Red Button","URL":"http://192.168.0.15:5004/auto/v200"},{"GuideNumber":"245","GuideName":"Planet Knowledg","URL":"http://192.168.0.15:5004/auto/v245"},{"GuideNumber":"601","GuideName":"BBC RB 1","URL":"http://192.168.0.15:5004/auto/v601"},{"GuideNumber":"602","GuideName":"BBC RB 2","URL":"http://192.168.0.15:5004/auto/v602"},{"GuideNumber":"603","GuideName":"BBC RB 3","URL":"http://192.168.0.15:5004/auto/v603"},{"GuideNumber":"700","GuideName":"BBC Radio 1","URL":"http://192.168.0.15:5004/auto/v700"},{"GuideNumber":"701","GuideName":"BBC R1X","URL":"http://192.168.0.15:5004/auto/v701"},{"GuideNumber":"702","GuideName":"BBC Radio 2","URL":"http://192.168.0.15:5004/auto/v702"},{"GuideNumber":"711","GuideName":"The Hits Radio","URL":"http://192.168.0.15:5004/auto/v711"},{"GuideNumber":"712","GuideName":"KISS FRESH","URL":"http://192.168.0.15:5004/auto/v712"},{"GuideNumber":"713","GuideName":"Kiss","URL":"http://192.168.0.15:5004/auto/v713"},{"GuideNumber":"714","GuideName":"KISSTORY","URL":"http://192.168.0.15:5004/auto/v714"},{"GuideNumber":"715","GuideName":"Magic","URL":"http://192.168.0.15:5004/auto/v715"},{"GuideNumber":"716","GuideName":"heat","URL":"http://192.168.0.15:5004/auto/v716"},{"GuideNumber":"717","GuideName":"Kerrang!","URL":"http://192.168.0.15:5004/auto/v717"},{"GuideNumber":"718","GuideName":"Smooth Radio","URL":"http://192.168.0.15:5004/auto/v718"},{"GuideNumber":"719","GuideName":"BBC Solent","URL":"http://192.168.0.15:5004/auto/v719"},{"GuideNumber":"723","GuideName":"talkSPORT","URL":"http://192.168.0.15:5004/auto/v723"},{"GuideNumber":"724","GuideName":"Capital FM","URL":"http://192.168.0.15:5004/auto/v724"},{"GuideNumber":"725","GuideName":"Premier Radio","URL":"http://192.168.0.15:5004/auto/v725"},{"GuideNumber":"727","GuideName":"Absolute Radio","URL":"http://192.168.0.15:5004/auto/v727"},{"GuideNumber":"728","GuideName":"Heart","URL":"http://192.168.0.15:5004/auto/v728"},{"GuideNumber":"792","GuideName":"ITV4","URL":"http://192.168.0.15:5004/auto/v792"},{"GuideNumber":"793","GuideName":"ITV3+1","URL":"http://192.168.0.15:5004/auto/v793"},{"GuideNumber":"795","GuideName":"CITV","URL":"http://192.168.0.15:5004/auto/v795"}] Are you guys using EmbyTV in the UK with SD guide listings?
Latchmor 584 Posted August 31, 2015 Posted August 31, 2015 Are you guys using EmbyTV in the UK with SD guide listings? Yip
Latchmor 584 Posted August 31, 2015 Posted August 31, 2015 How have you been finding it? To be honest I've been away since I started using it. I've only tested a handful of recordings (still using WMC) but it looks promising. The good thing is, like all the Emby stuff, you know it's going to get better. If you look in some of the other threads you'll find others that have been using it for a while now and seem to be using it a lot.
Guest Posted June 28, 2016 Posted June 28, 2016 Hi, I am a new Emby user from the UK, and have Freeview (DVB-T/T2). Is there any update on this thread from last August? Is Emby TV now working for UK users? I currently use Argus TV any plans to support that as an Emby plug-in? If I were to buy a new tuner to use with (eg NextPVR) for now, and EmbyTV when available, what tuner(s) will Emby TV support for the UK - any generic DVB-T2, or specific ones? Many thanks! lisa
Luke 42242 Posted June 28, 2016 Posted June 28, 2016 Check the schedules direct website to see if that have appropiate lineup coverage for you. If not we have XML TV coming in the next release of the server
Guest Posted June 28, 2016 Posted June 28, 2016 I have a Schedules Direct subscription, their JSON service supports the UK, and works well in Argus TV. Would like to try the native Emby TV though, but not sure what tuner I would need. Does Emby TV have direct support for the Schedules Direct (newish) JSON service?
CBers 7554 Posted June 28, 2016 Posted June 28, 2016 Hi, I am a new Emby user from the UK, and have Freeview (DVB-T/T2). Is there any update on this thread from last August? Is Emby TV now working for UK users? I currently use Argus TV any plans to support that as an Emby plug-in? If I were to buy a new tuner to use with (eg NextPVR) for now, and EmbyTV when available, what tuner(s) will Emby TV support for the UK - any generic DVB-T2, or specific ones? Many thanks! lisa Yes. @@Spaceboy and I have it working.
