smalik0 3 Posted July 31, 2015 Posted July 31, 2015 I am attempting to configure DLNA to stream media from my Emby server to my living room TV via my Denon AVR. The server does appear in the Denon's list of available DLNA devices; however, it says "(Not Authorized)" after the server name and doesn't let me select it. DLNA streaming to other TVs directly works perfectly, the only problem device is the Denon. Unfortunately, the only way to stream media to the living room TV is via the Denon. Do I have to set up a profile to authorize the Denon? And if so, how would I do that?
bluemonkey07 590 Posted July 31, 2015 Posted July 31, 2015 What are you trying to stream, most avrs will only do audio via dlna
Luke 42239 Posted August 3, 2015 Posted August 3, 2015 there might be settings on the denon where you have to authorize certain devices. I know some TV's have that. From the Emby side there is no authorization required.
embyuser2016 0 Posted November 13, 2016 Posted November 13, 2016 Hi smalik0, have you solved this issue? Got the same problem.
Happy2Play 9811 Posted November 13, 2016 Posted November 13, 2016 (edited) Anyone tried this? zc. WIN 7 PC shows up as "Not Authorized": On the AVR, set DHCP to OFF, then put in a manual address for the router and set DHCP back to ON. http://www.avsforum.com/forum/308-community-articles/1550945-denon-2011-2012-avr-faq-setup-troubleshooting-guide.html#user_L29 https://forum.dbpoweramp.com/showthread.php?24566-Asset-uPnP-quot-not-authorized-quot-on-new-Pioneer-AV-receiver&s=bb69e534ef56c1051cd6a1e5df24bab3&p=119187&viewfull=1#post119187 Edited November 13, 2016 by Happy2Play
