Tolerant 74 Posted July 31, 2015 Posted July 31, 2015 (edited) Playto "Edge" shows spinning dot in center that keeps going around and around and around... its like watching a little bug crawling on my monitor. Using Windows 10 Home w/Edge browser and playing to it from FireFox. I do this so that I can keep it full screen on my second monitor while not messing with my browsing in FireFox. Sadly I no longer have WMC w/external MPC and Emby Theater is so unstable it is not an option. Any idea on how NOT to see this dot (pixel) going around in circles or another alternative? I do see in the server config, that this file is transcoding. Is that why there is a spinning dot? Edited July 31, 2015 by Tolerant
Luke 42185 Posted July 31, 2015 Posted July 31, 2015 known issue for now. maybe someone in the custom css section can give you a hack to permanently hide the spinner. you could also try theater again. i think the video player is more stable now.
Tolerant 74 Posted July 31, 2015 Author Posted July 31, 2015 known issue for now. maybe someone in the custom css section can give you a hack to permanently hide the spinner. you could also try theater again. i think the video player is more stable now. I tried it last night and it crashed on me with a UI Error and totally and completely hung windows 10. I had to force the PC to power down.
Tolerant 74 Posted July 31, 2015 Author Posted July 31, 2015 I found one that does NOT have a dot going in circles, here is the media info. General Complete name : E:\TV\AIRING_SHOWS\Extant\Season 2\Extant - S02E05 - The New Frontier.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 232 MiB Duration : 43mn 28s Overall bit rate mode : Variable Overall bit rate : 748 Kbps Encoded date : UTC 2015-07-29 16:57:37 Tagged date : UTC 2015-07-29 16:57:37 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 43mn 28s Bit rate : 632 Kbps Maximum bit rate : 3 500 Kbps Width : 720 pixels Height : 404 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.091 Stream size : 196 MiB (84%) Writing library : x264 core 146 r2538 121396c Encoding settings : cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=16 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2015-07-29 13:25:15 Tagged date : UTC 2015-07-29 16:57:39 Color range : Limited Matrix coefficients : BT.709 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 43mn 28s Bit rate mode : Variable Bit rate : 112 Kbps Maximum bit rate : 167 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 34.8 MiB (15%) Encoded date : UTC 2015-07-29 16:57:38 Tagged date : UTC 2015-07-29 16:57:39 This one DOES show the dot going in circles: General Complete name : E:\TV\AIRING_SHOWS\Mr. Robot\Season 1\Mr. Robot - S01E06 - eps1.5_br4ve-trave1er.asf.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 186 MiB Duration : 44mn 7s Overall bit rate mode : Variable Overall bit rate : 589 Kbps Encoded date : UTC 2011-09-08 11:43:25 Tagged date : UTC 2011-09-08 11:43:25 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 44mn 7s Bit rate : 451 Kbps Width : 720 pixels Height : 404 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.065 Stream size : 142 MiB (77%) Writing library : x264 core 146 r2538 121396c Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=24 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2011-09-08 11:43:25 Tagged date : UTC 2011-09-08 11:43:25 Color range : Limited Matrix coefficients : BT.709 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 44mn 7s Bit rate mode : Variable Bit rate : 132 Kbps Maximum bit rate : 203 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 41.5 MiB (22%) Encoded date : UTC 2011-09-08 11:43:25 Tagged date : UTC 2011-09-08 11:43:25 Hopefully this shows something useful..
