fc7 123 Posted July 30, 2015 Posted July 30, 2015 (edited) I'm having problems with the search function. Every time I want to search for something in my library (movie, song, tv show) the webclient goes back to home screen without showing any results. This was working for sure before but right now I can't tell when it stopped. I'm running Emby 3.0.5675.1 on CentOS 7. In Emby log, for every search I try I get this exception: 2015-07-30 22:40:24.1658 Error - DtoService: Error getting artist *** Error Report *** Version: 3.0.5675.1 Command line: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe -programdata /var/opt/Emby/server Operating system: Unix 3.10.0.229 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/opt/Emby/server Mono: 3.10.0 (tarball Sat Nov 15 03:35:34 UTC 2014) Application Path: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: name System.ArgumentNullException at MediaBrowser.Server.Implementations.Library.LibraryManager.GetItemByName[MusicArtist] (System.String path, System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager.GetArtist (System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Dto.DtoService+<AttachBasicFields>c__AnonStorey6.<>m__1 (System.String i) [0x00000] in <filename unknown>:0 2015-07-30 22:40:24.2502 Error - DtoService: Error getting artist *** Error Report *** Version: 3.0.5675.1 Command line: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe -programdata /var/opt/Emby/server Operating system: Unix 3.10.0.229 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/opt/Emby/server Mono: 3.10.0 (tarball Sat Nov 15 03:35:34 UTC 2014) Application Path: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: name System.ArgumentNullException at MediaBrowser.Server.Implementations.Library.LibraryManager.GetItemByName[MusicArtist] (System.String path, System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager.GetArtist (System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Dto.DtoService+<AttachBasicFields>c__AnonStorey6.<>m__1 (System.String i) [0x00000] in <filename unknown>:0 2015-07-30 22:40:24.3183 Error - DtoService: Error getting artist *** Error Report *** Version: 3.0.5675.1 Command line: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe -programdata /var/opt/Emby/server Operating system: Unix 3.10.0.229 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/opt/Emby/server Mono: 3.10.0 (tarball Sat Nov 15 03:35:34 UTC 2014) Application Path: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: name System.ArgumentNullException at MediaBrowser.Server.Implementations.Library.LibraryManager.GetItemByName[MusicArtist] (System.String path, System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager.GetArtist (System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Dto.DtoService+<AttachBasicFields>c__AnonStorey6.<>m__1 (System.String i) [0x00000] in <filename unknown>:0 2015-07-30 22:40:24.3554 Error - DtoService: Error getting artist *** Error Report *** Version: 3.0.5675.1 Command line: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe -programdata /var/opt/Emby/server Operating system: Unix 3.10.0.229 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/opt/Emby/server Mono: 3.10.0 (tarball Sat Nov 15 03:35:34 UTC 2014) Application Path: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: name System.ArgumentNullException at MediaBrowser.Server.Implementations.Library.LibraryManager.GetItemByName[MusicArtist] (System.String path, System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager.GetArtist (System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Dto.DtoService+<AttachBasicFields>c__AnonStorey6.<>m__1 (System.String i) [0x00000] in <filename unknown>:0 2015-07-30 22:40:24.4836 Error - DtoService: Error getting artist *** Error Report *** Version: 3.0.5675.1 Command line: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe -programdata /var/opt/Emby/server Operating system: Unix 3.10.0.229 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/opt/Emby/server Mono: 3.10.0 (tarball Sat Nov 15 03:35:34 UTC 2014) Application Path: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: name System.ArgumentNullException at MediaBrowser.Server.Implementations.Library.LibraryManager.GetItemByName[MusicArtist] (System.String path, System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager.GetArtist (System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Dto.DtoService+<AttachBasicFields>c__AnonStorey6.<>m__1 (System.String i) [0x00000] in <filename unknown>:0 2015-07-30 22:40:24.4948 Error - DtoService: Error getting artist *** Error Report *** Version: 3.0.5675.1 Command line: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe -programdata /var/opt/Emby/server Operating system: Unix 3.10.0.229 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/opt/Emby/server Mono: 3.10.0 (tarball Sat Nov 15 03:35:34 UTC 2014) Application Path: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: name System.ArgumentNullException at MediaBrowser.Server.Implementations.Library.LibraryManager.GetItemByName[MusicArtist] (System.String path, System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager.GetArtist (System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Dto.DtoService+<AttachBasicFields>c__AnonStorey6.<>m__1 (System.String i) [0x00000] in <filename unknown>:0 2015-07-30 22:40:24.5608 Error - DtoService: Error getting artist *** Error Report *** Version: 3.0.5675.1 Command line: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe -programdata /var/opt/Emby/server Operating system: Unix 3.10.0.229 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/opt/Emby/server Mono: 3.10.0 (tarball Sat Nov 15 03:35:34 UTC 2014) Application Path: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: name System.ArgumentNullException at MediaBrowser.Server.Implementations.Library.LibraryManager.GetItemByName[MusicArtist] (System.String path, System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager.GetArtist (System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Dto.DtoService+<AttachBasicFields>c__AnonStorey6.<>m__1 (System.String i) [0x00000] in <filename unknown>:0 2015-07-30 22:40:24.6163 Error - DtoService: Error getting artist *** Error Report *** Version: 3.0.5675.1 Command line: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe -programdata /var/opt/Emby/server Operating system: Unix 3.10.0.229 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/opt/Emby/server Mono: 3.10.0 (tarball Sat Nov 15 03:35:34 UTC 2014) Application Path: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: name System.ArgumentNullException at MediaBrowser.Server.Implementations.Library.LibraryManager.GetItemByName[MusicArtist] (System.String path, System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager.GetArtist (System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Dto.DtoService+<AttachBasicFields>c__AnonStorey6.<>m__1 (System.String i) [0x00000] in <filename unknown>:0 2015-07-30 22:40:24.6383 Error - DtoService: Error getting artist *** Error Report *** Version: 3.0.5675.1 Command line: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe -programdata /var/opt/Emby/server Operating system: Unix 3.10.0.229 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/opt/Emby/server Mono: 3.10.0 (tarball Sat Nov 15 03:35:34 UTC 2014) Application Path: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: name System.ArgumentNullException at MediaBrowser.Server.Implementations.Library.LibraryManager.GetItemByName[MusicArtist] (System.String path, System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager.GetArtist (System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Dto.DtoService+<AttachBasicFields>c__AnonStorey6.<>m__1 (System.String i) [0x00000] in <filename unknown>:0 2015-07-30 22:40:24.6651 Error - DtoService: Error getting artist *** Error Report *** Version: 3.0.5675.1 Command line: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe -programdata /var/opt/Emby/server Operating system: Unix 3.10.0.229 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/opt/Emby/server Mono: 3.10.0 (tarball Sat Nov 15 03:35:34 UTC 2014) Application Path: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: name System.ArgumentNullException at MediaBrowser.Server.Implementations.Library.LibraryManager.GetItemByName[MusicArtist] (System.String path, System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager.GetArtist (System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Dto.DtoService+<AttachBasicFields>c__AnonStorey6.<>m__1 (System.String i) [0x00000] in <filename unknown>:0 2015-07-30 22:40:24.7055 Error - DtoService: Error getting artist *** Error Report *** Version: 3.0.5675.1 Command line: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe -programdata /var/opt/Emby/server Operating system: Unix 3.10.0.229 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/opt/Emby/server Mono: 3.10.0 (tarball Sat Nov 15 03:35:34 UTC 2014) Application Path: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: name System.ArgumentNullException at MediaBrowser.Server.Implementations.Library.LibraryManager.GetItemByName[MusicArtist] (System.String path, System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager.GetArtist (System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Dto.DtoService+<AttachBasicFields>c__AnonStorey6.<>m__1 (System.String i) [0x00000] in <filename unknown>:0 2015-07-30 22:40:24.7214 Error - DtoService: Error getting artist *** Error Report *** Version: 3.0.5675.1 Command line: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe -programdata /var/opt/Emby/server Operating system: Unix 3.10.0.229 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/opt/Emby/server Mono: 3.10.0 (tarball Sat Nov 15 03:35:34 UTC 2014) Application Path: /opt/Emby/server/bin/MediaBrowser.Server.Mono.exe Argument cannot be null. Parameter name: name System.ArgumentNullException at MediaBrowser.Server.Implementations.Library.LibraryManager.GetItemByName[MusicArtist] (System.String path, System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Library.LibraryManager.GetArtist (System.String name) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Dto.DtoService+<AttachBasicFields>c__AnonStorey6.<>m__1 (System.String i) [0x00000] in <filename unknown>:0It looks like a problem with some item in my library but I can't tell from the error where to look exactly. Any ideas? Edited July 30, 2015 by fc7
Luke 42243 Posted July 30, 2015 Posted July 30, 2015 that shouldn't be a problem. it will handle that and march on. see if by chance it might just be acting slowly
fc7 123 Posted July 30, 2015 Author Posted July 30, 2015 Ok. So there is nothing I can do on my side to fix it or workaround it right? It's not a problem with my library items? Sent from my iPhone using Tapatalk
fc7 123 Posted July 30, 2015 Author Posted July 30, 2015 post the complete log Please find attached the complete log since server start until trying to do a search and failed. Let me know if you need anything else. Thanks. server-63573897029.txt
Luke 42243 Posted July 30, 2015 Posted July 30, 2015 how are you defining failure? can you repeat the test with debug logging on (under advanced)? thanks.
fc7 123 Posted July 30, 2015 Author Posted July 30, 2015 how are you defining failure? can you repeat the test with debug logging on (under advanced)? thanks. The repro steps are: Open the webclient Go to Music library Clic on Songs for example In the Songs section clic on the search icon on the top right. Type something in the search field and press <Enter> Expected result: the web client will return a list of results or a message that there are no results Actual result: no search results are returned, instead the webclient returns to the Home screen and the server logs the exception that you can see in the logs. I will repeat the test with debug loggin enable now.
fc7 123 Posted July 30, 2015 Author Posted July 30, 2015 Ok. I have more details. I'm running Elementary OS which is based on Ubuntu 14.04 and the default browser is Midori. Most of the time I'm using Firefox, but just by coincidence I connected to Emby using Midori and guess what. Seach is working fine in Midori! Searching for the keyword as I typed and finding results. Not like in Firefox where nothing happens as I type and I need to press <Enter> after entering the entire keyword to fire the search which doesn't return any results and take me back to the home screen, logging the exception in the server log. So search is failing under Firefox 39.0 but it's working ok under Midori 0.5.10. Midori uses the WebKit rendering engine which is different from Gecko, used by Firefox. Anyway I got the debug enabled log, please find it attached. I did some basic clean on IPs, usernames and folders that I'm not comfortable posting in a public forum. But if you need the original log I can send it to you by PM. In the log you should see my test with Midori (working) and right after my test with Firefox (not working). server-63573898987.txt
Luke 42243 Posted July 30, 2015 Posted July 30, 2015 is there any possibility you may have assumed failure based on it taking longer than expected? the server log shows all the search requests sending back a status of 200 OK, taking anywhere from 1.5 to 5 seconds. either that or there was just a clientside problem in the browser. i'm not on ff39 but it seems ok on 40
fc7 123 Posted July 30, 2015 Author Posted July 30, 2015 (edited) is there any possibility you may have assumed failure based on it taking longer than expected? the server log shows all the search requests sending back a status of 200 OK, taking anywhere from 1.5 to 5 seconds. either that or there was just a clientside problem in the browser. i'm not on ff39 but it seems ok on 40 Hi Luke thanks a lot for coming back so fast. It's a really weird issue. I just connected again with Midori and it was failing too! Exactly in the same way as Firefox. Just to try something, right after step 3 (repro steps above) I did a reload on the page (F5). After the page was reloaded I clicked again on search icon, started typing and the search function was working as expected. I repeated exactly the same procedure now in Firefox up to step 3, then F5 to reload the page, I clicked on the search icon, started typing and the search function is working as expected. It seems that if I don't force reload the page (F5), at least once during my session, the search will not work. I can reproduce this constantly, at will, and with both browsers. I'm really lost here. Edited July 31, 2015 by fc7
fc7 123 Posted August 3, 2015 Author Posted August 3, 2015 I still can't figure out why I need to reload the webclient at least once to get the search feature to work. I will really appreciate any ideas to troubleshoot this. Thanks. Sent from my iPad using Tapatalk
Luke 42243 Posted August 3, 2015 Posted August 3, 2015 if you can build against the latest code then try it there because there are search changes. otherwise i wouldn't worry about it and just test when the next release rolls around.
fc7 123 Posted August 4, 2015 Author Posted August 4, 2015 Thanks Luke. Will test the next server release then. Sent from my iPhone using Tapatalk
