memorynet 0 Posted July 30, 2015 Posted July 30, 2015 I would like to know a way to return to the previous version after upgrade my debian server version 7 presented incompatibility with windows phone and SmarT TV, PS4.
Luke 42243 Posted July 30, 2015 Posted July 30, 2015 build from source or overwrite some of your install files based on these https://github.com/MediaBrowser/Emby.Releases/tree/master/Server
Luke 42243 Posted July 30, 2015 Posted July 30, 2015 aside from this can you navigate normally with the web interface? i can try to put in some fixes for the next release for browsers such as this. thanks.
memorynet 0 Posted July 30, 2015 Author Posted July 30, 2015 Yes, navigation normally, only the errors I mentioned in PS4, windows phone 8.1 and chrome for SmarTV.
Luke 42243 Posted July 30, 2015 Posted July 30, 2015 what errors exactly? are they all the same? if not, can you describe each one? thanks.
