Guest Diefenthal Posted March 19, 2016 Posted March 19, 2016 (edited) that was know that only Free to Air Channels working now is the question is the Problem on ffmpegs rtsp side that can we only naildown if @@Luke add my rtsp stack feed them with the m3u values and give ffmpeg the rtp:// URL Edited March 19, 2016 by Diefenthal
denethor 90 Posted March 19, 2016 Posted March 19, 2016 that was know that only Free to Air Channels working Is this applies to CI descrambling I think it shouldn't? But if you descramble with plugins yes it is not supported with SATIP server.
Guest Diefenthal Posted March 19, 2016 Posted March 19, 2016 the spec dont describe where channels /Service should descramble it give one SatIp Server(DigitalDevices Octopus Net) ,that had an ci but only ci not ci+ Interface and with newer Smardcards V13 v14( Videoguard) without an Uni DeltaCam dont work it normaly should the Cleint handle the descramble i have an SatIp Receiver with ci+ Interface (Kathrein UFS Connect 906) :-)this descramble me the Ts and can Show the programs the satip Samples are only just for fun and learning 1
Nikolaech 32 Posted March 19, 2016 Posted March 19, 2016 Scrambled channels - not shows. Free channel - works. In EmbyServer -no. #EXTM3U #EXTINF:-1,Orion Express - Kino TV HD src=1&freq=11800&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=28800&mtype=8psk&tnr=1,11800,28800,10600,1,0,0,2,4408,3408,1408,1408,6,0,24,0,20,1,-1&pids=0,16,17,18,20,1408,3408,4408 #EXTINF:-1,Orion Express - Первый Канал src=1&freq=12640&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=30000&mtype=qpsk&tnr=1,12640,30000,10600,1,1,0,4,2101,1101,101,101,1,0,25,0,7,1,-1&pids=0,16,17,18,20,101,1101,151,2101
Nikolaech 32 Posted March 19, 2016 Posted March 19, 2016 Does not work, nowhere. #EXTM3U #EXTINF:-1,Orion Express - Kino TV HD #EXTVLCOPT:program=1408 rtsp://localhost:554/?src=1&freq=11800&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=28800&mtype=8psk&tnr=1,11800,28800,10600,1,0,0,2,4408,3408,1408,1408,6,0,24,0,20,1,-1&pids=0,16,17,18,20,1408,3408,4408 #EXTINF:-1,Orion Express - Первый Канал #EXTVLCOPT:program=101 rtsp://localhost:554/?src=1&freq=12640&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=30000&mtype=qpsk&tnr=1,12640,30000,10600,1,1,0,4,2101,1101,101,101,1,0,25,0,7,1,-1&pids=0,16,17,18,20,101,1101,151,2101
Nikolaech 32 Posted March 19, 2016 Posted March 19, 2016 I need to work the plugin. My provider NTV+. They are using C+. I have the receiver humax vahd-3100s. But on the PC, C+ not working.
Nikolaech 32 Posted March 19, 2016 Posted March 19, 2016 EmbyServer. server error .m3u8? Logs, enabled debug entries. logs.zip
denethor 90 Posted March 19, 2016 Posted March 19, 2016 I can also confirm that removing the line that starts with #EXTVLCOPT helps on sample RTSP player and I can stream FTA channels. But it fails with Emby. Sent from my iPad using Tapatalk
Luke 42244 Posted March 19, 2016 Posted March 19, 2016 yea ffmpeg seems to not like it for some reason. maybe you can expirement and find a way to get that rtsp path passed into ffmpeg? thanks.
Luke 42244 Posted March 19, 2016 Posted March 19, 2016 Latest dev should correctly parse the m3u now, but ffmpeg will still fail for the above reason.
Nikolaech 32 Posted March 19, 2016 Posted March 19, 2016 ES 3.0.5922.26429 is not possible configure the page live TV
Luke 42244 Posted March 19, 2016 Posted March 19, 2016 ES 3.0.5922.26429 is not possible configure the page live TV What does that mean?
Nikolaech 32 Posted March 19, 2016 Posted March 19, 2016 What does that mean? updated server does not work
Luke 42244 Posted March 19, 2016 Posted March 19, 2016 updated server does not work What does that mean? How to report a problem. Describe the problem in your own words, including what you're trying to accomplish, and where you're getting stuck.
Nikolaech 32 Posted March 19, 2016 Posted March 19, 2016 (edited) Ver. 3.0.5922.27945 and 3.0.5922.26429 I can not delete the file logs.zip Edited March 19, 2016 by Nikolaech
Nikolaech 32 Posted March 19, 2016 Posted March 19, 2016 (edited) did you try clicking the trash can? Yes. Luke do not hurt me Does not work in IE; Edge. Does not work restart Does not work "cancel" Edited March 19, 2016 by Nikolaech
Nikolaech 32 Posted March 20, 2016 Posted March 20, 2016 Мои примеры редактирования файла .m3u. Во всех случаях в ES нет воспроизведения. В SatIp.Rtsp.Sample.v1.0.0.3 работает в любых вариантах. Вам понятно что я написал? #EXTM3U#EXTINF:-1,Orion Express - Kino TV HDrtsp://localhost:554/?src=1&freq=11800&msys=dvbs2&fec=23&pol=h&sr=28800&pids=0,16,17,18,20,1408,3408,4408 rtsp://localhost:554/?src=1&freq=11800&msys=dvbs2&fec=23&pol=h&sr=28800&mtype=8psk&pids=0,16,17,18,20,1408,3408,4408 rtsp://localhost:554/?src=1&freq=11800&sr=28800&pol=h&msys=dvbs2&pids=0,16,17,18,20,1408,3408,4408 rtsp://localhost:554/?src=1&freq=11800&sr=28800&pol=h&msys=dvbs2&mtype=8psk&pids=0,16,17,18,20,1408,3408,4408 src=1&freq=11800&sr=28800&pol=h&msys=dvbs2&mtype=8psk&pids=0,16,17,18,20,1408,3408,4408 src=1&freq=11800&sr=28800&pol=h&msys=dvbs2&pids=0,16,17,18,20,1408,3408,4408 rtsp://localhost:554/src=1&freq=11800&sr=28800&pol=h&msys=dvbs2&pids=0,16,17,18,20,1408,3408,4408 rtsp://localhost:554/src=1&freq=11800&sr=28800&fec=23&pol=h&msys=dvbs2&pids=0,16,17,18,20,1408,3408,4408 rtsp://localhost:554/src=1&freq=11800&pol=h&sr=28800&fec=23&msys=dvbs2&pids=0,16,17,18,20,1408,3408,4408 rtsp://localhost:554/src=1&freq=11800&pol=h&sr=28800&fec=23&pids=0,16,17,18,20,1408,3408,4408 rtsp://localhost:554/src=1&freq=11800&pol=h&sr=28800&fec=23&pids=0,16,17,18,20,1408,3408,4408&.ts rtsp://localhost:554/src=1&freq=11800&pol=h&sr=28800&fec=23&pids=0,16,17,18,20,1408,3408,4408.ts
Guest Diefenthal Posted March 20, 2016 Posted March 20, 2016 (edited) what will you me say that i should learn the russian language ? Edited March 20, 2016 by Diefenthal
Nikolaech 32 Posted March 20, 2016 Posted March 20, 2016 (edited) that i should learn the russian language ? no. I write messages using google transliteration. Bad translation. You and Luke don't understand. That's why I wrote in Russian. It is easier to understand each other. Edited March 20, 2016 by Nikolaech
Guest Diefenthal Posted March 20, 2016 Posted March 20, 2016 no. let you me know what you there had wrote Мои примеры редактирования файла .m3u. Во всех случаях в ES нет воспроизведения. В SatIp.Rtsp.Sample.v1.0.0.3 работает в любых вариантах. Вам понятно что я написал?
Nikolaech 32 Posted March 20, 2016 Posted March 20, 2016 (edited) let you me know what you there had wrote Мои примеры редактирования файла .m3u. Во всех случаях в ES нет воспроизведения. В SatIp.Rtsp.Sample.v1.0.0.3 работает в любых вариантах. Вам понятно что я написал? try google transliteration I write messages using google transliteration. Bad translation. You and Luke don't understand. That's why I wrote in Russian. It is easier to understand each other. Edited March 20, 2016 by Nikolaech
Guest Diefenthal Posted March 20, 2016 Posted March 20, 2016 ok in my sample all m3u links are working and in emby not but where is the Problem in ffmpegs rtsp stack or somewhere
Luke 42244 Posted March 20, 2016 Posted March 20, 2016 It's the url that ffmpeg doesn't like. We might need to escape or encode something. 1
Nikolaech 32 Posted March 20, 2016 Posted March 20, 2016 message Emby "Error video An error occurred while playing video. Make sure there is an outdoor tuner."
