Guest Diefenthal Posted March 17, 2016 Posted March 17, 2016 Hi I use recording service with dvb-c. What can i do? perfect please wait i send you an private message if i had the dvbc support inbuild but you must have an ini file with the Tuning data
Guest Diefenthal Posted March 17, 2016 Posted March 17, 2016 as a client? any computer with Windows some (1 or 2%) Sat>Ip Server provide an link to an m3u file in the DeviceDescription, the marked text. in this Picture is the Field filled but there is nothing behind the link
Nikolaech 32 Posted March 17, 2016 Posted March 17, 2016 I have so. < <satip:X_SATIPCAP xmlns:satip="urn:ses-com:satip">DVBS2-1,DVBT-0,DVBT2-0,DVBC-0</satip:X_SATIPCAP> <satip:X_SATIPM3U xmlns:satip="urn:ses-com:satip">/rtspchannels.m3u</satip:X_SATIPM3U>
Luke 42244 Posted March 17, 2016 Posted March 17, 2016 Latest dev build going up displays the ini mappings. Note that this is only the form, it doesn't actually do anything yet. @ please verify it looks correct. thanks. 1
e123enitan 276 Posted March 17, 2016 Posted March 17, 2016 (edited) Latest dev build going up displays the ini mappings. Note that this is only the form, it doesn't actually do anything yet. @ please verify it looks correct. thanks. Awesome , wonderful progress, question, the Tp are preloaded or is it a case that the list will be pulled from user own receiver Tp? Thanks Edited March 17, 2016 by e123enitan
Guest Diefenthal Posted March 18, 2016 Posted March 18, 2016 this lists Comes from http://satellites-xml.eu and contains only Transponders for the Satellite this is required for an Service / channel Search the m3u way is the way if the device has an own m3u list and provide them too so have we for everyone a solution to Play with satip @@Luke Looks ok add rtsp to communication with the device Setup ,Play ,Options ,Describe ,Teardown is this inbuild can useres test the m3u way and we had some work with the Search way
Guest Diefenthal Posted March 18, 2016 Posted March 18, 2016 (edited) if rtsp implemented and you have the ui for scan implemented too can you receive rtp (unicast) so as Exsample without Table Parsing serverendpoint= new IPEndpoint(IPAddress.Any,0); UdpClient udpClient = new UdpClient(ClientRTPPort); byte[] receivedBytes = udpClient.Receive(ref serverEndPoint); if (receivedBytes.Length > 12) { byte[] tspackets = new byte[1316]; //TS Payload Array.Copy(receivedBytes, tspackets, receivedBytes.Length - 12); Byte[] tsBytes = new byte[188]; for (int x = 0; x < tspackets.Length; x++) { #region Mpeg2 //PAT if (tspackets[x] == 0x47 && tspackets.Length >= x + 188 && //Sync byte and check of length (tspackets[x + 1] & 15) == 0 && tspackets[x + 2] == 0x00 && //Check if pid is 0x00 tspackets[x + 5] == 0x00) //check if it is a PAT (Program Association Table) packet? { for (int y = 0; y < 188; y++) { tsBytes[y] = tspackets[x + y]; //TODO Table Byte Parsing } x += 188; } //CAT else if (tspackets[x] == 0x47 && tspackets.Length >= x + 188 && //Sync byte and check of length (tspackets[x + 1] & 15) == 0 && tspackets[x + 2] == 0x00 && //Check if pid is 0x00 tspackets[x + 5] == 0x01) //check if it is a CAT (Conditional Access Table) packet? { for (int y = 0; y < 188; y++) { tsBytes[y] = tspackets[x + y]; //TODO Table Byte Parsing } x += 188; } //PMT else if (tspackets[x] == 0x47 && tspackets.Length >= x + 188 && //Sync byte and check of length (tspackets[x + 1] & 15) == 0 && tspackets[x + 2] == 0x00 && //Check if pid is 0x00 tspackets[x + 5] == 0x02) //check if it is a PMT (Program Map Table) packet? { for (int y = 0; y < 188; y++) { tsBytes[y] = tspackets[x + y]; //TODO Table Byte Parsing } x += 188; } #endregion #region DVB //NIT actual else if (tspackets[x] == 0x47 && tspackets.Length >= x + 188 && //Sync byte and check of length (tspackets[x + 1] & 15) == 0 && tspackets[x + 2] == 0x10 && //Check if pid is 0x10 tspackets[x + 5] == 0x40) //check if it is a NIT (Network Information Table) packet? { for (int y = 0; y < 188; y++) { tsBytes[y] = tspackets[x + y]; //TODO Table Byte Parsing } x += 188; } //NIT other else if (tspackets[x] == 0x47 && tspackets.Length >= x + 188 && //Sync byte and check of length (tspackets[x + 1] & 15) == 0 && tspackets[x + 2] == 0x10 && //Check if pid is 0x10 tspackets[x + 5] == 0x41) //check if it is a NIT (Network Information Table) packet? { for (int y = 0; y < 188; y++) { tsBytes[y] = tspackets[x + y]; //TODO Table Byte Parsing } x += 188; } //SDT actual else if (tspackets[x] == 0x47 && tspackets.Length >= x + 188 && //Sync byte and check of length (tspackets[x + 1] & 15) == 0 && tspackets[x + 2] == 0x11 && //Check if pid is 0x11 tspackets[x + 5] == 0x42) //check if it is a SDT (Service Description Table) packet? { for (int y = 0; y < 188; y++) { tsBytes[y] = tspackets[x + y]; //TODO Table Byte Parsing } x += 188; } //SDT other else if (tspackets[x] == 0x47 && tspackets.Length >= x + 188 && //Sync byte and check of length (tspackets[x + 1] & 15) == 0 && tspackets[x + 2] == 0x11 && //Check if pid is 0x11 tspackets[x + 5] == 0x46) //check if it is a SDT (Service Description Table) packet? { for (int y = 0; y < 188; y++) { tsBytes[y] = tspackets[x + y]; //TODO Table Byte Parsing } x += 188; } //BAT else if (tspackets[x] == 0x47 && tspackets.Length >= x + 188 && //Sync byte and check of length (tspackets[x + 1] & 15) == 0 && tspackets[x + 2] == 0x11 && //Check if pid is 0x11 tspackets[x + 5] == 0x4A) //check if it is a BAT (Bouquet Association Table ) packet? { for (int y = 0; y < 188; y++) { tsBytes[y] = tspackets[x + y]; //TODO Table Bytes Parsing } x += 188; } //EIT Present/Following Actual else if (tspackets[x] == 0x47 && tspackets.Length >= x + 188 && //Sync byte and check of length (tspackets[x + 1] & 15) == 0 && tspackets[x + 2] == 0x12 && //Check if pid is 0x12 tspackets[x + 5] == 0x4E) //check if it is a EIT (Event Information Table) packet? { for (int y = 0; y < 188; y++) { tsBytes[y] = tspackets[x + y]; //TODO Table Bytes Parsing } x += 188; } //Eit Present/Following Other else if (tspackets[x] == 0x47 && tspackets.Length >= x + 188 && //Sync byte and check of length (tspackets[x + 1] & 15) == 0 && tspackets[x + 2] == 0x12 && //Check if pid is 0x11 tspackets[x + 5] == 0x4F) //check if it is a EIT (Event Information Table) packet? { for (int y = 0; y < 188; y++) { tsBytes[y] = tspackets[x + y]; //TODO Table Bytes Parsing } x += 188; } //EIT Schedule Actual else if (tspackets[x] == 0x47 && tspackets.Length >= x + 188 && //Sync byte and check of length (tspackets[x + 1] & 15) == 0 && tspackets[x + 2] == 0x12 && //Check if pid is 0x12 tspackets[x + 5] >= 0x50 && tspackets[x + 5] <= 0x5F) //check if it is a EIT (Event Information Table) packet? { for (int y = 0; y < 188; y++) { tsBytes[y] = tspackets[x + y]; //TODO Table Bytes Parsing } x += 188; } //EIT Schedule Other else if (tspackets[x] == 0x47 && tspackets.Length >= x + 188 && //Sync byte and check of length (tspackets[x + 1] & 15) == 0 && tspackets[x + 2] == 0x12 && //Check if pid is 0x12 tspackets[x + 5] >= 0x60 && tspackets[x + 5] <= 0x6F) //check if it is a EIT (Event Information Table) packet? { for (int y = 0; y < 188; y++) { tsBytes[y] = tspackets[x + y]; //TODO Table Bytes Parsing } x += 188; } //TDT else if (tspackets[x] == 0x47 && tspackets.Length >= x + 188 && //Sync byte and check of length (tspackets[x + 1] & 15) == 0 && tspackets[x + 2] == 0x14 && //Check if pid is 0x14 tspackets[x + 5] == 0x70) //check if it is a TDT (Time and Date Table) packet? { for (int y = 0; y < 188; y++) { tsBytes[y] = tspackets[x + y]; //TODO Table Bytes Parsing } x += 188; } #endregion } } Edited March 18, 2016 by Diefenthal 2
denethor 90 Posted March 18, 2016 Posted March 18, 2016 (edited) Let me share DVBviwer Recording service M3U format for SATIP: #EXTINF:-1,Channel Group Name - Channel Name #EXTVLCOPT:program=1713 rtsp://192.168.1.10:554/?src=1&freq=12245&msys=dvbs2&plts=off&fec=56&pol=h&ro=0.35&sr=27500&mtype=8psk&tnr=1,12245,27500,10600,1,0,3,4,213,113,1713,1713,6,0,25,0,7,66,-1&pids=0,16,17,18,20,1713,113,213 Examples: Channel Group Name : My Movie Channels (Generated within DVBviewer channel editor as folders) Channel Name: BBC HD Both channel names and channel groups can include special chars like space, dash etc. Edited March 18, 2016 by denethor
Luke 42244 Posted March 18, 2016 Posted March 18, 2016 Let me share DVBviwer Recording service M3U format for SATIP: #EXTINF:-1,Channel Group Name - Channel Name #EXTVLCOPT:program=1713 rtsp://192.168.1.10:554/?src=1&freq=12245&msys=dvbs2&plts=off&fec=56&pol=h&ro=0.35&sr=27500&mtype=8psk&tnr=1,12245,27500,10600,1,0,3,4,213,113,1713,1713,6,0,25,0,7,66,-1&pids=0,16,17,18,20,1713,113,213 Examples: Channel Group Name : My Movie Channels (Generated within DVBviewer channel editor as folders) Channel Name: BBC HD Both channel names and channel groups can include special chars like space, dash etc. can you test this on the latest dev or beta to see how they're showing up? thanks.
denethor 90 Posted March 18, 2016 Posted March 18, 2016 (edited) can you test this on the latest dev or beta to see how they're showing up? thanks. Thats exactly what I'm doing right now but my previous post was not complete, sorry. Here is the actual example and how it looks in channel list of WEB Client. Looks like there is a problem with parsing. #EXTINF:-1,D-Smart - FOXCRIME HD #EXTVLCOPT:program=1707rtsp://192.168.1.10:554/?src=1&freq=12245&msys=dvbs2&plts=off&fec=56&pol=h&ro=0.35&sr=27500&mtype=8psk&tnr=1,12245,27500,10600,1,0,3,4,207,107,1707,1707,6,0,25,0,7,66,-1&pids=0,16,17,18,20,1707,107,207,307 One last edit Server version :3.0.5921.20537 Edited March 18, 2016 by denethor
Guest Diefenthal Posted March 18, 2016 Posted March 18, 2016 hmm &tnr=1,12245,27500,10600,1,0,3,4,207,107,1707,1707,6,0,25,0,7,66,-1 isnt a specified in the satip spec
Nikolaech 32 Posted March 18, 2016 Posted March 18, 2016 The file rtspchannels.m3u does not necessarily indicate. Enough to register here.http://192.168.0.105:8089/rtspchannels.m3u Channels will be defined in the server. Temporarily not tell of course.
denethor 90 Posted March 18, 2016 Posted March 18, 2016 (edited) hmm &tnr=1,12245,27500,10600,1,0,3,4,207,107,1707,1707,6,0,25,0,7,66,-1 isnt a specified in the satip spec Only trail I can find is in their 1.28 release notes and listed as UPNP missing param. fix. (1.32 is the current version) "Fix: UPnP: Missing tnr-parameters in RTSP playlists and the GetChannelsXML API prevented playback of encrypted and DVB-C channels." Edited March 18, 2016 by denethor
Nikolaech 32 Posted March 18, 2016 Posted March 18, 2016 (edited) My file channel. rtsp m3u does not work. rtspchannels (1).zip Edited March 18, 2016 by Nikolaech
denethor 90 Posted March 18, 2016 Posted March 18, 2016 are you able to play? Nope. But I only tried it with iPAD Safari. I wasn't aware about it could have play streams. I was thinking that you are at the stage of developing UI.
Luke 42244 Posted March 18, 2016 Posted March 18, 2016 they should be able to play now, if the m3u data is valid.
Guest Diefenthal Posted March 18, 2016 Posted March 18, 2016 @@Luke had you inbuild rtsp ? had you the right URL for playback "rtp://clientip:clientrtpport"
Luke 42244 Posted March 18, 2016 Posted March 18, 2016 it takes the rtsp url and passes that to ffmpeg, which supports rtsp
Luke 42244 Posted March 18, 2016 Posted March 18, 2016 ok so when parsing the m3u we have to skip the line that starts with #EXTVLCOPT:program
Nikolaech 32 Posted March 18, 2016 Posted March 18, 2016 ok so when parsing the m3u we have to skip the line that starts with #EXTVLCOPT:program No play. #EXTM3U #EXTINF:-1,Orion Express - Первый Канал rtsp://localhost:554/?src=1&freq=12640&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=30000&mtype=qpsk&tnr=1,12640,30000,10600,1,1,0,4,2101,1101,101,101,1,0,25,0,7,1,-1&pids=0,16,17,18,20,101,1101,151,2101 #EXTINF:-1,Orion Express - Первый Канал HD rtsp://localhost:554/?src=1&freq=11960&msys=dvbs2&plts=off&fec=35&pol=h&ro=0.35&sr=28800&mtype=8psk&tnr=1,11960,28800,10600,1,0,0,7,2902,1902,902,92,6,0,25,0,15,1,-1&pids=0,16,17,18,20,902,1902,33,2902,3902 #EXTINF:-1,Orion Express - Первый канал (+2) rtsp://localhost:554/?src=1&freq=11872&msys=dvbs&plts=off&fec=12&pol=h&ro=0.35&sr=15000&mtype=qpsk&tnr=1,11872,15000,10600,1,0,0,1,4603,3603,1603,1603,0,0,25,0,22,1,-1&pids=0,16,17,18,20,1603,3603,4603 #EXTINF:-1,Orion Express - Первый Канал HD (+4) rtsp://localhost:554/?src=1&freq=11960&msys=dvbs2&plts=off&fec=35&pol=h&ro=0.35&sr=28800&mtype=8psk&tnr=1,11960,28800,10600,1,0,0,7,2904,1904,904,904,6,0,25,0,15,1,-1&pids=0,16,17,18,20,904,1904,2904,2954 #EXTINF:-1,Orion Express - Первый Канал (+4) rtsp://localhost:554/?src=1&freq=12080&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=28800&mtype=8psk&tnr=1,12080,28800,10600,1,0,0,2,2414,1414,414,414,6,0,25,0,10,1,-1&pids=0,16,17,18,20,414,1414,2414 #EXTINF:-1,Orion Express - Россия HD rtsp://localhost:554/?src=1&freq=11960&msys=dvbs2&plts=off&fec=35&pol=h&ro=0.35&sr=28800&mtype=8psk&tnr=1,11960,28800,10600,1,0,0,7,2901,1901,901,901,6,0,25,0,15,1,-1&pids=0,16,17,18,20,901,1901,2901 logs.zip
Nikolaech 32 Posted March 19, 2016 Posted March 19, 2016 I'm illiterate, but I'll try. Wait what the guys say. Maybe it's in Cyrillic or special symbols.
Guest Diefenthal Posted March 19, 2016 Posted March 19, 2016 @@Nikolaech if you had Windows MediaPlayer and the LAV Directshow Filter Installed than load this package https://github.com/Diefenthal/SatIp-Rtsp-Sample/Releases customize your rtspchanneles.m3u so from #EXTM3U #EXTINF:-1,Orion Express - Первый Канал rtsp://localhost:554/?src=1&freq=12640&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=30000&mtype=qpsk&tnr=1,12640,30000,10600,1,1,0,4,2101,1101,101,101,1,0,25,0,7,1,-1&pids=0,16,17,18,20,101,1101,151,2101 to #EXTM3U #EXTINF:-1,Orion Express - Первый Канал src=1&freq=12640&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=30000&mtype=qpsk&pids=0,16,17,18,20,101,1101,151,2101 save the customized as PlayList.m3u and put it into the SatIp Rtsp Sample Folder and start it let us know if it works or not if not ,find you an sample.log there C:\ProgramData\SatIp RtspSample\Logs
Nikolaech 32 Posted March 19, 2016 Posted March 19, 2016 (edited) ОК @Diefenthal Scrambled channels Первый канал-not shows. Free channel Kino TV HD-works. A working example of the playlist rtsp.m3u #EXTM3U #EXTINF:-1,Orion Express - Kino TV HD rtsp://localhost:554/?src=1&freq=11800&msys=dvbs2&plts=off&fec=23&pol=h&ro=0.35&sr=28800&mtype=8psk&tnr=1,11800,28800,10600,1,0,0,2,4408,3408,1408,1408,6,0,24,0,20,1,-1&pids=0,16,17,18,20,1408,3408,4408 #EXTINF:-1,Orion Express - Первый Канал rtsp://localhost:554/?src=1&freq=12640&msys=dvbs&plts=off&fec=56&pol=v&ro=0.35&sr=30000&mtype=qpsk&tnr=1,12640,30000,10600,1,1,0,4,2101,1101,101,101,1,0,25,0,7,1,-1&pids=0,16,17,18,20,101,1101,151,2101 Will continue to test Edited March 19, 2016 by Nikolaech
