Luke 42244 Posted February 17, 2016 Posted February 17, 2016 Hi Luke there are some notify Messages i had look fast over it and think there not all Servers found any notify messages from the sat devices?
Luke 42244 Posted February 17, 2016 Posted February 17, 2016 ok yes NOTIFY Device message received from 192.168.2.106:44511. Headers: HOST=239.255.255.250:1900,CACHE-CONTROL=max-age=1800,LOCATION=http://192.168.2.106:8080/desc.xml,NT=urn:ses-com:device:SatIPServer:1,NTS=ssdp:alive,SERVER=Linux/1.0 UPnP/1.1 IDL4K/1.0,USN=uuid:7eafb2be-8d9b-4263-b6fa-7a594390beea::urn:ses-com:device:SatIPServer:1,BOOTID.UPNP.ORG=778,CONFIGID.UPNP.ORG=0
Luke 42244 Posted February 17, 2016 Posted February 17, 2016 Hi Luke there are some notify Messages i had look fast over it and think there not all Servers found Since you're on windows, go to advanced -> set your automatic update level to dev. then once you have the latest dev build, let me know if you see the message i mentioned earlier.
Guest Diefenthal Posted February 17, 2016 Posted February 17, 2016 (edited) with disabled dlna and dev build are all three found 2016-02-17 07:53:52.5533 Info IDeviceDiscovery: Creating SSDP listener on 192.168.2.1042016-02-17 07:53:52.5703 Debug SsdpHandler: Sending unicast search request2016-02-17 07:53:53.6663 Info HttpClient: HttpClientManager GET: http://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog2016-02-17 07:53:53.6873 Debug PortMapper: Starting NAT discovery2016-02-17 07:53:53.6943 Debug App: SAT IP found at http://192.168.2.103/octoserve/octonet.xml2016-02-17 07:53:53.7553 Info LibraryMonitor: Watching directory C:\Users\Kay\AppData\Roaming\Emby-Server\root2016-02-17 07:53:53.7553 Info LibraryMonitor: Watching directory C:\Users\Kay\AppData\Roaming\Emby-Server\data\camerauploads2016-02-17 07:53:53.7553 Info LibraryMonitor: Watching directory C:\Users\Kay\AppData\Roaming\Emby-Server\data\collections2016-02-17 07:53:53.7553 Info LibraryMonitor: Watching directory C:\Users\Kay\AppData\Roaming\Emby-Server\data\playlists2016-02-17 07:53:53.7673 Debug SsdpHandler: Registered mount a43de1e735cf5594bd6b7b5e6e90044b at http://192.168.2.104:8096/dlna/a43de1e735cf5594bd6b7b5e6e90044b/description.xml2016-02-17 07:53:54.0474 Debug App: SAT IP found at http://192.168.2.106:8080/desc.xml2016-02-17 07:53:54.0474 Info HttpClient: HttpClientManager POST: http://www.mb3admin.com/admin/service/registration/validate2016-02-17 07:53:54.0964 Debug App: SAT IP found at http://192.168.2.102:80/rootDescr2016-02-17 07:53:54.0964 Debug App: SAT IP found at http://192.168.2.102:80/rootDescr2016-02-17 07:53:54.7174 Debug App: SAT IP found at http://192.168.2.106:8080/desc.xml Edited February 19, 2016 by Diefenthal 1
Guest Diefenthal Posted March 5, 2016 Posted March 5, 2016 is the sat>ip implementation canceld stopped? if yes let it me know
Luke 42244 Posted March 5, 2016 Posted March 5, 2016 No, not at all. But you said only 1-2% of devices support the m3u method?
Guest Diefenthal Posted March 5, 2016 Posted March 5, 2016 (edited) ok and the other way (RTSP -> RTP/RTCP->M2TS) is to much work for you ? i had no Problem with that if you answer that with yes Edited March 5, 2016 by Diefenthal
Luke 42244 Posted March 5, 2016 Posted March 5, 2016 No, it's not too much work, I just don't really know where to get started.
Guest Diefenthal Posted March 5, 2016 Posted March 5, 2016 (edited) No, it's not too much work, I just don't really know where to get started. device discovery had you working the next step is look for Tuning data as exsample from kingofsat the ini files for an ini Reader look there http://www.mentalis.org/soft/class.qpx?id=6 with that can you make an channelscan for that is an rtsp rtp rtcp stack needed or would you parse first an ts file ? https://onedrive.live.com/redir?resid=623CC1224D4C982B!862&authkey=!ACF5qhBI2I9Bdbs&ithint=video%2cts Edited March 5, 2016 by Diefenthal
Guest Diefenthal Posted March 6, 2016 Posted March 6, 2016 (edited) i had an dummy app for you form1 is the device discovery form2 the configuration (Basic ) for the device you can choose the Satellite for each source you can send rtsp Messages Setup Play Describe Options Teardown and hope it helps you a Little bit Edited March 6, 2016 by Diefenthal 3
Guest Diefenthal Posted March 7, 2016 Posted March 7, 2016 (edited) here is an updated Version changes the 3 progressbars now Show the values for Signal Level Quality and Result how manys Transponders are tuned but here is no ! recieving of rtp / rtcp or Transport stream reading included it should only Show how emby communicate with sat>ip servern to get channels if anyone wont help can i add this sample to github for Team work Edited March 7, 2016 by Diefenthal 2
Luke 42244 Posted March 14, 2016 Posted March 14, 2016 Just getting started with an empty config page. We can already support SAT servers that broadcast m3u in their device xml, but i guess not many do that.
Nikolaech 32 Posted March 14, 2016 Posted March 14, 2016 You want to make support for BDA devices? https://en.wikipedia.org/wiki/Broadcast_Driver_Architecture or Sat-IP devices? http://www.satip.info/products/SAT%3EIP%20Servers thank you
Guest Diefenthal Posted March 14, 2016 Posted March 14, 2016 SatIp is it at time but is BDA tuner Support on the list than is it possible to create it for both the only difference between BDA and SatIp is that BDA use Filtergraphes to tune and get the Data and SatIp use Rtsp Rtp and parse the Byte data with other words we can now create casses called DVBSTuner, DVBTTuner and DVBCTuner and can specify over the type BDA or SatIP how the channel should be tuned and the data should be received 1
pir8radio 1313 Posted March 14, 2016 Posted March 14, 2016 Just getting started with an empty config page. We can already support SAT servers that broadcast m3u in their device xml, but i guess not many do that. Sweet, ill look into sat-ip devices and play around!
Nikolaech 32 Posted March 15, 2016 Posted March 15, 2016 Yes, the first step is done. Good luck to you!
Guest Diefenthal Posted March 15, 2016 Posted March 15, 2016 i see that here some use dvb Viewers Recording Service as satip Server is there one with dvbt or dvbc if yes can i implement that but i cant that test
Nikolaech 32 Posted March 16, 2016 Posted March 16, 2016 i see that here some use dvb Viewers Recording Service as satip Server Yes, there are many such. I use DVB-S/S2. if yes can i implement that but i cant that test I can test. Hardware SkyStar 2 eXpress HD; software Win 10 x64 ru. DVBViewer 5.6.0 + RegService 1.32.0
e123enitan 276 Posted March 16, 2016 Posted March 16, 2016 Yes, the first step is done. Good luck to you! I can't review these pix's
Guest Diefenthal Posted March 16, 2016 Posted March 16, 2016 I can't review these pix's in emby is it an dev build the Form1 and Form2 is from my dummy that i attached some Posts over this zip Name is Satipv3
Nikolaech 32 Posted March 16, 2016 Posted March 16, 2016 (edited) EmbyServer-beta. RS 1.32.0(service record DVBViewer ) should be started. Should be the second picture. Edited March 16, 2016 by Nikolaech
e123enitan 276 Posted March 16, 2016 Posted March 16, 2016 (edited) Kudos to the guys currently working on this project to it make a reality, I strongly believe this would be a selling feature for emby, that said, I hope soon DVB Viewer/RS would integrate with emby server. Cheers!! Edited March 16, 2016 by e123enitan
Luke 42244 Posted March 16, 2016 Posted March 16, 2016 Does anyone have a device that supports m3u channels via X_SATIPM3U?
rechner123 12 Posted March 16, 2016 Posted March 16, 2016 i see that here some use dvb Viewers Recording Service as satip Server is there one with dvbt or dvbc if yes can i implement that but i cant that test Hi I use recording service with dvb-c. What can i do?
Nikolaech 32 Posted March 17, 2016 Posted March 17, 2016 (edited) Does anyone have a device that supports m3u channels via X_SATIPM3U? as a client? any computer with Windows Edited March 17, 2016 by Nikolaech
