Lee 212 Posted July 30, 2015 Posted July 30, 2015 I've just bought a vu+ solo2 apparently you can install kodi on it.. Anyone with any experience of that and will all the skins and plugins work with it if so..? Any help with this would be greatly appreciated!!!
im85288 1493 Posted July 30, 2015 Posted July 30, 2015 Just so happens I've had one of them for a couple of years and the Kodi experience when I last tested was beyond awful. My solo 2 now sits there doing nothing at all and has been replaced by a Moi+ (built in tvheadend Server, network tuner)..which serves multiple Kodi htpcs. Anyway share your experiences, maybe the newer Kodi versions for it are better.
e123enitan 276 Posted July 30, 2015 Posted July 30, 2015 I have one sitting helplessly, it is hard to get it to function for USA channels (Dish Network) if anyone have working on USA network pls share your experience, although it works for FTA. In the mean time, I have moved on to TBS 6895+DVBviewer still in the impelementation stage share your experience if you have TBS+DVBviewer up and running.
Lee 212 Posted July 30, 2015 Author Posted July 30, 2015 Just put my tbs 6984 up for sale! Worked flawlessly with wmc or dvbviewer... Hopefully the xbmc kodi implementation has come on a bit!!!
Lee 212 Posted July 30, 2015 Author Posted July 30, 2015 @@im85288 black hole images have xbmc baked in now although it's only Gotham.. Was that the experience before??
im85288 1493 Posted July 30, 2015 Posted July 30, 2015 No, it was a couple of years ago using plugins. Everything failed and navigation was painfully slow. I took the decision to go fully Kodi (once they started supporting PVR) and really love the moi+, solo 2 was great but I just wanted everything in one device. 1
Lee 212 Posted July 31, 2015 Author Posted July 31, 2015 I'll report back once I get the unit home. Be a few weeks (divorce-messy!)
Lee 212 Posted July 31, 2015 Author Posted July 31, 2015 @@im85288 ok to drop u a pm regarding kodi plugins when i get up and running??
Lee 212 Posted August 23, 2015 Author Posted August 23, 2015 @@im85288 i'm finally home and had a play with the vuplus solo 2. xbmc runs perfectly AND quickly only problem being its gotham... so emby plugins fail. i'd say once the kodi update drops it'll definitely be worth a look!
Luke 42243 Posted September 12, 2016 Posted September 12, 2016 The Vu+ plugin has been updated with a new configuration screen to match the look and feel of the rest of Emby Server. I think you'll find it much more enjoyable to use and configure now. Thanks.
