JeremyFr79 228 Posted July 29, 2015 Posted July 29, 2015 I'm using server Version 3.0.5675.1, up to date android client, and ServerWMC. Ever since the swith to LibVLC I can only watch Live TV if I'm on my LAN the minute I go to 4G, or an outside wireless network I get "playback error, there was an error processing your request. Please try again later" message box.
Luke 42243 Posted July 29, 2015 Posted July 29, 2015 known issue for the moment. in order to facilitate direct play the app is assuming it can directly access the tv url
JeremyFr79 228 Posted July 29, 2015 Author Posted July 29, 2015 Ok, been so busy in life haven't been able to keep up on the forum so was unaware it was a known issue, ETA? for a fix?
overtime39 1 Posted September 6, 2015 Posted September 6, 2015 Hi, I am having the same problem with EmbyServer Version 3.0.5724.4 as well. I am running Emby via docker on a Synology 1812+ with an HdHomerun Extend. I went from an older version of EmbyServer with a live tv plugin which could stream outside the network to the newest stable version which can't. Really thought I did something wrong on the install process. Glad I found your post. Nice that the HdHomerun Extend is doing all the transcoding now instead of my Nas. Really looking forward to streaming the football game on days I have to work
Luke 42243 Posted December 4, 2022 Posted December 4, 2022 On 12/2/2022 at 5:24 AM, Milldor said: Hi, Was this ever fixed up? Hi @Milldor, if you're experiencing an issue we're happy to help. How to Report a Problem Thanks.
Milldor 14 Posted December 4, 2022 Posted December 4, 2022 41 minutes ago, Luke said: Hi @Milldor, if you're experiencing an issue we're happy to help. How to Report a Problem Thanks. It's not a new issue... I'm asking if you've attempted to fix something that's not been working for 7 years.
Luke 42243 Posted December 4, 2022 Posted December 4, 2022 30 minutes ago, Milldor said: It's not a new issue... I'm asking if you've attempted to fix something that's not been working for 7 years. Yes, Live TV works just fine on both the LAN and WAN. If you're experiencing an issue we're happy to help. How to Report a Problem Thanks !
