AxeMan 25 Posted July 28, 2015 Posted July 28, 2015 So I had mpc-hc + shark007 working fine for years now.. some update recently somewhere caused this to break slowly but surely. I don't know what exactly caused it. I uninstalled Shark and installed the lastest version (I was way behind)... and am happy to say that I can now use the emby internal player with bitstreamed audio (WIN!). I hated using MPC-HC, and yearned to get away from it. Now I have a good reason.. BUt (you knew there was a but)... I can't seem to figure out how to select subtitle streams or change audio streams. Is there a way to do this ?
Solution ebr 16334 Posted July 29, 2015 Solution Posted July 29, 2015 Not without additional software and setup (something like MediaControl). WMC was designed in the days of DVDs and all those operations were performed via the DVD menu.
