manf0001 4 Posted July 28, 2015 Posted July 28, 2015 Hello, Last night I had to wipe and reload my CentOS 7 server and reinstall Emby. i"m running emby Server 3.0.5621.4 (that's all I can upgrade to now) However since I re-added my media files and reset all my settings I have noticed that I'm missing menu items and default icons as described below. Before when I logged into the web interface of emby on my home page it would show me my media selection, TV, Movies, Music, and each of those options had a colourful icon. Now it's just a plain folder icon with a gray background. (unlike before) And also before when I would click into lets say the TV folder, It would take me to the TV section and show a menu across the top, Suggestion, Latest, Upcoming, Shows, Genres etc... Now when I click on TV it takes me to a screen listing all of the shows, and dosen't even show me the above menu to select Genres, or suggestions etc. The only way that menu will come up, is if I select a show from the list then the menu appears. This is happening with my Music, Movies and Shows. I would like to get the full functionality back, because it also affects my android TV and Android Phone Apps. Thanks
Solution ddecaro 4 Posted July 29, 2015 Solution Posted July 29, 2015 I would check the content type for each folder under the library.i had simular issue when I reinstalled my server and used the plug in server configuration backup to restore my libray. It added all my folders but put the content type as unset. 1
