studio-jurdan 9 Posted July 28, 2015 Posted July 28, 2015 (edited) Emby connect make permanently trouble in my server the login is nerly impossible to switch between 2 ou more user in the same station. it ask me 300X the password before UNDERTANDING tha i'm ME It FORCE the ENGLISH language that NO one at my house will never use It declare mostr of time that my server is down and this is FALSE SO i NEED to use my server MYSELF w<ithout emby connect but i MUST use it to set new user, invite, and passowrd etc. i realy can't understant THIS if EMBY is not able to land to my server, to see it is ON, to use the language on the membre and pass this info to the server. etc etc to REALMY CONNECT to my server WHAT to do with it???? Edited August 3, 2015 by studio-jurdan
ebr 16307 Posted July 28, 2015 Posted July 28, 2015 Use a dynamic DNS service so that you have a friendly domain name for your server. Then be sure your router is setup properly to forward the ports to your Emby server machine. Then just connect with whatever app you wish using the Dynamic DNS name you setup.
Happy2Play 9799 Posted July 28, 2015 Posted July 28, 2015 The only time you may want to use Emby connect is when not on your LAN. And if not on your LAN the you can use Emby Connect or your WAN/DDNS address.
studio-jurdan 9 Posted July 28, 2015 Author Posted July 28, 2015 (edited) i almready use a DDNS ;-))THANKS If only i knew that before.... i'd 1 week off time not used ANds i thinks it is better to use DDNS, because invitation with emby connect that come to a friend got in the trash directly. it never seem to be send by me. i send real mail, with form, with french, witrh my writing style, and with cert dsdign, also with some with crypt too. so when a friend have a mail from emby connezctr he push it in the trash or spam. my own mail seems like signed, cripted newsleter. I thinks that i'ts a minum to can modify the message tpo send, a preview it before sending ;-) Edited July 28, 2015 by studio-jurdan
schaduwheer 1 Posted July 28, 2015 Posted July 28, 2015 i'm not using emby connect myself, i simply told my family members the external ip and port and to skip the signup for an account. works like a charm, only thing i have to make sure of is that the port is enabled in the router otherwise it will not work.
Longrifle 33 Posted July 28, 2015 Posted July 28, 2015 You will also have to keep your family updated on the IP address when it changes Sent from my iPhone using Tapatalk 1
studio-jurdan 9 Posted July 29, 2015 Author Posted July 29, 2015 (edited) nope it is not needed with ddns service, try it if you need http://embyfr.ddns.net:8096 or http://media.jurdan.be:8096 Edited August 3, 2015 by studio-jurdan
