jody 4 Posted July 26, 2015 Posted July 26, 2015 (edited) Hi there, I get some errors in my logs, I see it is looking for /home/horse/Downloads/mediabrowser/dashboard-ui/css/fonts/Roboto/RobotoLight.woff but the directory is misspelled. I do have the directory "roboto" but not with a capital: /home/horse/Downloads/mediabrowser/dashboard-ui/css/fonts/roboto/RobotoLight.woff how to fix? (obviously I could rename the directory but I don't know if there are some other references it might brake) 2015-07-26 14:50:25.3759 Error - HttpServer: Error processing request for /web/css/fonts/Roboto/RobotoLight.woff *** Error Report *** Version: 3.0.5675.1 Command line: /home/horse/Downloads/mediabrowser/MediaBrowser.Server.Mono.exe Operating system: Unix 3.2.0.85 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /home/horse/Downloads/mediabrowser/ProgramData-Server Mono: 4.0.2 (Stable 4.0.2.5/c99aa0c Wed Jun 24 10:04:37 UTC 2015) Application Path: /home/horse/Downloads/mediabrowser/MediaBrowser.Server.Mono.exe Could not find a part of the path "/home/horse/Downloads/mediabrowser/dashboard-ui/css/fonts/Roboto/RobotoLight.woff". ServiceStack.HttpError No Stack Trace Available 2015-07-26 14:50:25.3759 Error - NotFoundHttpHandler: 10.133.120.3:8096 Request not found: /web/css/fonts/Roboto/RobotoLight.woff 2015-07-26 14:51:07.8200 Error - HttpServer: Error in SharpWebSocket: An exception has occurred while receiving a message.. Exception.Message: Internal error (no progress possible) ReadInternal 2015-07-26 14:51:16.3072 Error - HttpServer: Error in SharpWebSocket: An exception has occurred while receiving a message.. Exception.Message: Internal error (no progress possible) ReadInternal 2015-07-26 14:51:16.9161 Error - HttpServer: Error in SharpWebSocket: An exception has occurred while receiving a message.. Exception.Message: Internal error (no progress possible) ReadInternal Edited July 26, 2015 by jody
fc7 123 Posted July 28, 2015 Posted July 28, 2015 (edited) My workaround for this was just to create a symbolic link named Roboto that points to roboto directory. ln -s roboto Roboto Works like a charm. I already reported this issue in another thread. Hopefully it will be fixed soon. Sent from my iPhone using Tapatalk Edited July 28, 2015 by fc7 1
Solution Luke 42243 Posted July 28, 2015 Solution Posted July 28, 2015 Thanks. It's fixed for the next server release. 1
