pmichener1954 1 Posted July 24, 2015 Posted July 24, 2015 Probably something simple that I am overlooking.I just built my current htpc after moving and not having access to my old one. installed windows 8.1 pro with media center and all seemed to work. Installed emby wmc classic on this htpc and it find the server, displays all screens fine. When I try to play a movie, I can hear the audio portion of the movie, but the playback screen never appears. When I turn off "use custom interface" in emby settings, the movie will play correctly. I would like to use the custom interface, ,and can't figure out what I am doing wrong. Please help.
ebr 16334 Posted July 24, 2015 Posted July 24, 2015 What codecs did you install? Video drivers up to date?
pmichener1954 1 Posted July 24, 2015 Author Posted July 24, 2015 Installed Emby theater to try it out. It plays fine.
ebr 16334 Posted July 24, 2015 Posted July 24, 2015 Perhaps a log would shed some light. How to Report a Problem
pmichener1954 1 Posted July 24, 2015 Author Posted July 24, 2015 Here is the log from the latest attempt. Hope this helps MBClassic-2472015f717e94c5aac4f2a97206c1fe2ac2d72.log
ebr 16334 Posted July 24, 2015 Posted July 24, 2015 Well, no clues there, sorry. What, exactly, do you see during playback?
pmichener1954 1 Posted July 25, 2015 Author Posted July 25, 2015 I see the movie backdrop with all the information displayed ( the screen that you click play on to proceed) it never leaves that screen, just plays audio in background.
ebr 16334 Posted July 25, 2015 Posted July 25, 2015 Does a "Now Playing" menu option appear anywhere? You know, the button that would be there if you were playing something and backed up to that screen.
