FLHTHEMI 2 Posted July 24, 2015 Posted July 24, 2015 If I use Emby as the source for Kodi files is there any problem with running 14.2 Helix on one machine and 15 Isengard on another? I know you're not supposed to do this if you use MySql so I thought I would ask as I'm about to update.
Deihmos 170 Posted July 24, 2015 Posted July 24, 2015 (edited) No it does not matter. Edited July 24, 2015 by Luke Moved topic
im85288 1493 Posted July 25, 2015 Posted July 25, 2015 If I use Emby as the source for Kodi files is there any problem with running 14.2 Helix on one machine and 15 Isengard on another? I know you're not supposed to do this if you use MySql so I thought I would ask as I'm about to update. It will work correctly, the emby for kodi addon uses the local database of each kodi installation you have.
