e123enitan 276 Posted July 26, 2016 Posted July 26, 2016 (edited) The userdata database files. You will also lose favorites. Or, you could just use one of the interfaces to mark everything unwatched. The userdata database files So where is file locate, Userdata DB directory in Windows 7. You will also lose favoritess fine I have no Favourite Edited July 26, 2016 by e123enitan
Happy2Play 9814 Posted July 26, 2016 Posted July 26, 2016 The userdata database files So where is file locate, Userdata DB directory in Windows 7. You will also lose favoritess fine I have no Favourite C:\\Users\username\AppData\Roaming\Emby-Server\data
Happy2Play 9814 Posted July 26, 2016 Posted July 26, 2016 You could use the Multil-Select option and unwatch everything. Home screen-hold left click-select each library-three dot menu-Mark unplayed, but this is per user.
Happy2Play 9814 Posted July 26, 2016 Posted July 26, 2016 @ Luke or Anyone This weekend I rebuild my server several times with the expectation that all watch status will be clean and everything start afresh, but it appears that when I uninstall, the file that holds the watch status remain and keep reinventing. I am on windows 7, could you point me to the location where the file is kept so I can delete manually since uninstall process would perform the task. Thanks Do your nfo files contain a user watched status?
e123enitan 276 Posted July 26, 2016 Posted July 26, 2016 You could use the Multil-Select option and unwatch everything. Home screen-hold left click-select each library-three dot menu-Mark unplayed, but this is per user. Nice, I will exploit both options, but why when you uninstall this file is left behind meaning it won't delete, I thought the essence of the uninstall is to wipe everything that was installed by emby Thanks
e123enitan 276 Posted July 26, 2016 Posted July 26, 2016 Do your nfo files contain a user watched status? Sorry I don't get it, where could I establish that. Cheers!
Happy2Play 9814 Posted July 26, 2016 Posted July 26, 2016 Check Metadata-NFO setting it is the first option.
ABNParatrooper 6 Posted July 26, 2016 Posted July 26, 2016 Wait, why would you delete the movies just because it was watched? What if down the road you want to watch it again. I would think a better option would be an option to multi select and chose set as watched. I did not go thru all the posts, so if this was asked/addressed already, forgive me. With that said, I would like that option to set a bunch of movies to watched. Well at least in the Roku feature.
ebr 16354 Posted July 26, 2016 Posted July 26, 2016 Nice, I will exploit both options, but why when you uninstall this file is left behind meaning it won't delete, I thought the essence of the uninstall is to wipe everything that was installed by emby Thanks When you do the uninstall, there is an option to "Remove all traces". Selecting that will delete everything but that is not the default because we want people to be able to re-install the software without losing their configuration.
e123enitan 276 Posted July 26, 2016 Posted July 26, 2016 This is the issue, not every things is deleted if configurate is not wiped out. This should be an option for users to decided. I want configura etc to be clean nothing left behind.I hope it make sense. I have done uninstall and reinstall several times yet the same config kept resurfacing, I hope there an option build into the uninstall which provide with the choice of a complete clean, or retain current comfig. Anyway Thanks for your kind supports
ebr 16354 Posted July 26, 2016 Posted July 26, 2016 When you uninstall the server, do you not get these options...?
