Luke 42246 Posted September 2, 2016 Posted September 2, 2016 What operating system are you on and what version of Emby Server?
Luke 42246 Posted September 2, 2016 Posted September 2, 2016 For me, this is how they look. Does this look right?
szimat 6 Posted September 2, 2016 Posted September 2, 2016 Emby server is the latest beta, and running on Linux (Ubuntu Server 16.04). Client Windows 10 Pro, Chrome latest. Your subtitles are correct (well, almost, since the encoding is not perfect, as the long accented characters are not proper, but it is quite commom). If I could get the way you have, that would be fine. It should be "élő" and "előtt" to be completely correct. Sent from my Xperia Z3 Compact using Tapatalk
anderbytes 141 Posted September 2, 2016 Posted September 2, 2016 So issue is only on Linux servers, I believe
Luke 42246 Posted September 2, 2016 Posted September 2, 2016 Yea we're using the .net encoding api. Is it possible that it doesn't understand the "windows-1250" character set because something is not installed on the machine? Maybe there is just a dependency that is missing.
speechles 2062 Posted September 2, 2016 Posted September 2, 2016 (edited) What locale is the linux machine set to? Is emby reading them based on locale of machine, or encoding of the subtitle? Windows-1250 is cp1250 on *nix. So you just alias one to the other. When it doesnt match anything, the encoding will fall back to locale. This might be the issue. Edited September 2, 2016 by speechles
Luke 42246 Posted September 2, 2016 Posted September 2, 2016 Here is the issue: https://developer.xamarin.com/api/type/System.Text.Encoding/ Windows 1250 is not baked into the .net framework, in other words, it has to be supported by the native system. The ones on the right with a * are baked into the framework, so we need to choose one of those.
Luke 42246 Posted September 2, 2016 Posted September 2, 2016 When I use windows-1252, the result looks the same so i will make that change for the next release and you should be good to go.
Luke 42246 Posted September 2, 2016 Posted September 2, 2016 @@Abobader can you try arabic subtitles on your synology server? Thanks. 1
Abobader 3485 Posted September 2, 2016 Posted September 2, 2016 @@Abobader can you try arabic subtitles on your synology server? Thanks. Good day Luke, I will test tonight and reply back, well done. My best
anderbytes 141 Posted September 2, 2016 Posted September 2, 2016 When I use windows-1252, the result looks the same so i will make that change for the next release and you should be good to go. Will this resolve the issues with Latin accents, too?
Luke 42246 Posted September 2, 2016 Posted September 2, 2016 Not sure yet. I will have to spin up a VM to test. But pob is already using 1252 so it might not.
anderbytes 141 Posted September 2, 2016 Posted September 2, 2016 Ok. I asked about in which os you did your tests, in the other topic. Have you seen those correct latin chars with a Linux Debian server ? Or Windows?
anderbytes 141 Posted September 2, 2016 Posted September 2, 2016 You can answer there, if you want, instead of here
Abobader 3485 Posted September 3, 2016 Posted September 3, 2016 Good day @@Luke Internal subtitle are ok: The problem with external subtitle: I tried many titles for testing, all external subtitles (srt) have the above issue. Test done on the web client on win 10 as client, the emby server on Synology (latest beta build): Let me know if you want the test done on another client, like ET. My best
Luke 42246 Posted September 3, 2016 Posted September 3, 2016 Thanks. And I'm guessing it's all OK with the windows server?
Abobader 3485 Posted September 3, 2016 Posted September 3, 2016 Thanks. And I'm guessing it's all OK with the windows server? Yes buddy:
anderbytes 141 Posted September 12, 2016 Posted September 12, 2016 Hello @@Luke ? Is the problem only in Linux? Have you found anything based on my files I gave you?
anderbytes 141 Posted September 12, 2016 Posted September 12, 2016 Okay Just hope this will be eventually fixed
rbanaco 2 Posted September 14, 2016 Posted September 14, 2016 Just for information, I am using a Freenas jail for emby server and this problem is also present there with every pt-pt subtitles that are not modified with notepad++
djhifi 56 Posted September 16, 2016 Posted September 16, 2016 +1 for external subtitles in ANSI implementation. Also getting ???? on accented characters while streaming (direct play is ok, of course). 5k and 500 tv shows with subtitles...wont recode them System: Synology 1813+ (latest DSM) EMBY: Community package
rbanaco 2 Posted September 16, 2016 Posted September 16, 2016 Well it looks like it works on Windows Server? I have to test it when I have time, to confirm.
rbanaco 2 Posted September 18, 2016 Posted September 18, 2016 True.. the problem is with FreeBSD server. I installed in Windows and it works. Any clues?
