miquelx 2 Posted December 28, 2015 Posted December 28, 2015 (edited) Ok, here we go. This is a bash shell script I also have another Powershell version in case someone wants it: (...) Basically you need to put this script on the root of your media folder tree. The script will go down each sub-folder, check if the sub file is in "FROM" encoding, and convert it to "TO" encoding. Just configure those variables according to the enconding you want to use. The script will also save a backup of your original sub file before convertion, in case something goes wrong and you want to recover your original file. For sure it can be improved since I'm not using it anymore (moved to powershell since my fileserver is running Windows Server), so feel free to do it and share! Cheers Created a script to auto-detect new files and automagically change their encoding using your method. #!/bin/bash # Srt Encoder WATCH_PATH="/mnt/Storage/Movies /mnt/Storage/TVShows" FROM="iso-8859-1" TO="utf-8" ICONV="iconv -f $FROM -t $TO" inotifywait -m --format '%w%f' -e create -e moved_to -e modify -r $WATCH_PATH | while read file; do EXT=${file##*.} if [ $EXT = "srt" ] then IS_TARGET=`file "${file}" | grep -i iso-8859` if [ "$IS_TARGET" != "" ]; then echo "${file} ---- Will be converted!" cp "${file}" "${file}.bak" $ICONV < "${file}.bak" > "${file}" fi fi done This will watch for create/move/movify events to existing files on the folders specified in the variable WATCH_PATH, when any of those events is fired, it will verify if the extension is .srt, if it is, it will change the encoding. As this watches for changes I created a systemctl service for it. [Unit] Description=SRT Encoder After=network.target [Service] ExecPreStart=pkill SCRIPT_NAME ExecStart=SCRIPT_LOCATION Restart=on-abort TimeoutSec=20 [Install] WantedBy=multi-user.target Change SCRIPT_LOCATION to the location of the script and SCRIPT_NAME to the name of the script. This way, after enabling the service, the script will start when the server boots. Edited December 28, 2015 by miquelx 1
ravenj 2 Posted March 7, 2016 Posted March 7, 2016 Hello, I know this is very simple and easy to use but couldn't it, or any other method, be easily included in emby? I have both linux and windows server installations and, with windows, there's no problem with subtitles. I can understand this is not a problem for most of emby's users because not everyone uses subtitles. But, in my opinion, the problem's priority shouldn't be defined according the number of users that have this specific need. I just don't like to see both linux and subtitles users being discriminated. Thank you. Best regards 1
anderbytes 141 Posted March 9, 2016 Posted March 9, 2016 Hello, I know this is very simple and easy to use but couldn't it, or any other method, be easily included in emby? I have both linux and windows server installations and, with windows, there's no problem with subtitles. I can understand this is not a problem for most of emby's users because not everyone uses subtitles. But, in my opinion, the problem's priority shouldn't be defined according the number of users that have this specific need. I just don't like to see both linux and subtitles users being discriminated. Thank you. Best regards I agree with you @@ravenj, I really didn't want to believe it but being a Linux emby user sometimes ends up in losing priority. Maybe because the devs use Windows in their tests...
ciss 4 Posted March 19, 2016 Posted March 19, 2016 hello and thanks for this script!! I dont know any linux, can you guys tell me how to use this on my Synology NAS?
ciss 4 Posted March 19, 2016 Posted March 19, 2016 Ok, guys I found out how to run the script. My question is: how do I go about modifying the output to "iso-8859-2" If I use this, it doesn't work. FROM="iso-8859-1" TO="iso-8859-2" Thanks
ciss 4 Posted March 19, 2016 Posted March 19, 2016 (edited) Ok, I finally understood how this works. What I need to do in order to have the subs displaying properly (in my notepad++) First, I need to select - character set > eastern european > iso-8859-2 Then I need to convert to UTF-8 and save. Is there any way to automate this? Thanks! Edited March 19, 2016 by ciss
Barlog9511 17 Posted August 29, 2016 Posted August 29, 2016 (edited) Ok, here we go. This is a bash shell script I also have another Powershell version in case someone wants it: #!/bin/bash FROM=iso-8859-1 TO=utf-8 ICONV="iconv -f $FROM -t $TO" # Convert find ./ -type f -name "*.srt" | while read fn; do IS_TARGET=`file "${fn}" | grep -i iso-8859` if [ "$IS_TARGET" = "" ]; then echo "${fn} ---- Will NOT be converted!" else echo "${fn} ---- Will be converted!" cp "${fn}" "${fn}.bak" $ICONV < "${fn}.bak" > "${fn}" fi done Basically you need to put this script on the root of your media folder tree. The script will go down each sub-folder, check if the sub file is in "FROM" encoding, and convert it to "TO" encoding. Just configure those variables according to the enconding you want to use. The script will also save a backup of your original sub file before convertion, in case something goes wrong and you want to recover your original file. For sure it can be improved since I'm not using it anymore (moved to powershell since my fileserver is running Windows Server), so feel free to do it and share! Cheers I have some issue in converting CZECH or SLOVAK subtitles but in this case is better use enca library, so I rewrite your original script #!/bin/bash LANGUAGE=czech TO=utf8 CONVERT="enca -L $LANGUAGE -x $TO" # Find and onvert find ./ -type f -name "*.srt" | while read fn; do IS_TARGET=`enca "${fn}" | grep -o UTF-8` if [ "$IS_TARGET" = "UTF-8" ]; then echo "${fn} ---- Will NOT be converted!" else echo "${fn} ---- Will be converted!" # optional backup of original srt # cp "${fn}" "${fn}.bak" $CONVERT "${fn}" fi done Edited August 29, 2016 by Barlog9511
ravenj 2 Posted August 31, 2016 Posted August 31, 2016 This problem was one of the main reasons that made me move to a windows server. Can't believe it's isn't solved yet within emby. Best regards 1
anderbytes 141 Posted August 31, 2016 Posted August 31, 2016 This problem was one of the main reasons that made me move to a windows server. Can't believe it's isn't solved yet within emby. Best regards If devs were people that live in countries with accented chars, that would be already fixed ages ago, even if this is only a Linux issue. I just ignore that Emby has this feature. I use subliminal and scheduled jobs to auto download them
Luke 42246 Posted August 31, 2016 Posted August 31, 2016 If you're having an issue, please see how to report a media playback issue. Thanks!
anderbytes 141 Posted August 31, 2016 Posted August 31, 2016 (edited) Has been done in http://emby.media/community/index.php?/topic/7719-external-subtitles-ansi/page-2 (by April 2016) Ok that the user that posted the issue has given up and didn't respond to http://emby.media/community/index.php?/topic/7719-external-subtitles-ansi/page-2&do=findComment&comment=320035 , but I can download and post one now if you want. Edited August 31, 2016 by anderbytes
anderbytes 141 Posted August 31, 2016 Posted August 31, 2016 And more... nothing strange will appear in logs, because the subtitle is downloaded correctly.
anderbytes 141 Posted August 31, 2016 Posted August 31, 2016 (edited) Here it goes the downloaded by Emby... look at times 3 and 5 in file... "N�o" should be "Não", for example. A script that was already published in this forum converts from iso-8859-1 to utf-8, then the sub becomes perfectly readable in playback. Screenshots: 1. File in Linux, before manual conversion (script). 2. File in Windows before manual conversion (script) - Windows seems to read it OK. 3. File in Linux after manual conversion (script). Angry.Birds.(2016).1080p.BluRay.x264.AACpt-BR.pob.zip Edited August 31, 2016 by anderbytes
anderbytes 141 Posted August 31, 2016 Posted August 31, 2016 what about playback? Here it is. Chrome Android
Luke 42246 Posted September 1, 2016 Posted September 1, 2016 This is what i'm seeing with your sample in chrome. Does that look right?
anderbytes 141 Posted September 1, 2016 Posted September 1, 2016 Yeah it does. Are you using Windows or Linux as server?
szimat 6 Posted September 2, 2016 Posted September 2, 2016 Same problem here. Any way to make this work, without changing each srt file to utf8 manually? Emby is the only where I have this problem, Kodi and Plex both work great. However, I would prefer Emby over Plex, just need to get this issue with subtitltes resolved. Thanks Sent from my Xperia Z3 Compact using Tapatalk
Luke 42246 Posted September 2, 2016 Posted September 2, 2016 Same problem here. Any way to make this work, without changing each srt file to utf8 manually? Emby is the only where I have this problem, Kodi and Plex both work great. However, I would prefer Emby over Plex, just need to get this issue with subtitltes resolved. Thanks Sent from my Xperia Z3 Compact using Tapatalk Hi there, welcome. can you please discuss a specific example? thanks.
szimat 6 Posted September 2, 2016 Posted September 2, 2016 (edited) Hi there, welcome. can you please discuss a specific example? thanks. Hi Luke! Sure, any srt file downloaded in hungarian language from the popular sites. Using Emby in Chrome, I get this: The same srt file plays perfectly fine everywhere else: Kodi (Linux & Win), Plex, VLC, MX-Player, etc. Here is the srt file: bojack.horseman.s01e01.720p.webrip.x264-w4f.hu.srt.7z All the Hungarian characters are wrong, it should be: - A nyomorék parkolóba álltam. Remélem, nem gáz. - Hogy hova állt? Any ideas? Edited September 2, 2016 by szimat
anderbytes 141 Posted September 2, 2016 Posted September 2, 2016 related (maybe) to http://emby.media/community/index.php?/topic/23624-subtitle-problem-for-accented-characters/page-3
szimat 6 Posted September 2, 2016 Posted September 2, 2016 I get that this can be resolved with a script, but don't get me wrong, I don't want to run scripts on perfectly fine subtitles. I really think this should be somehow resolved within Emby? Don't you think? Sent from my Xperia Z3 Compact using Tapatalk
