Tolerant 74 Posted July 21, 2015 Posted July 21, 2015 How can I fix a show that was miscorrectly listed as airing on Monday? I edited the .nfo and .xml located with the series however Emby refuses to update the day it airs in "upcoming" view, it still shows as Monday not Wednesday as it should.
Luke 42287 Posted July 21, 2015 Posted July 21, 2015 it's editable in the metadata manager. you can also edit the metadata directly. there's a file system monitor with a delay in place so that's why you might not see it reflected immediately.
Tolerant 74 Posted July 21, 2015 Author Posted July 21, 2015 (edited) Ok, cause I edited (as I said) in the .xml (from MCM), the .nfo (from Emby), then double checked in the metadata manager and edited it there and saved too then re-scanned & refreshed, etc.. Also have edited it on TheTVDB and so far nothing has made an impact. Even restarting the server and rebooting the pc has not helped. I will check it later to see if it ever does get updated, thanks. Edited July 21, 2015 by Tolerant
