glogrono 2 Posted July 21, 2015 Posted July 21, 2015 Hi Everyone, I've been using Emby for WMC for a very long time now for my media collection consisting entirely of Bluray ISO's. I've recently decided to make the move to MKV's and decided to go the route of setting Emby to use MPC-HC. The setup works great, but when Emby starts a movie through MPC-HC, I have no way to stop the movie so I can get back into Emby. I am using a Harmony Smart Remote, which emulates a Windows Media Center remote. I tried going into the "keys" settings on MPC-HC and tried different commands, but I cannot get anything to make the movie stop. The only thing that works is Play/Pause and advance fowards/backwards. Would anyone happen to know how I can get this to work? Any help is greatly appreciated.
ebr 16332 Posted July 21, 2015 Posted July 21, 2015 First, why the external player? If you install LAV the internal player will play most everything just fine.
CBers 7554 Posted July 21, 2015 Posted July 21, 2015 Here are a couple of tutorials written by @@Cheesegeezer (FFDshow) and @@Jon (LAV Filters) Setting up LAV Filters Setting up FFDShow
glogrono 2 Posted July 22, 2015 Author Posted July 22, 2015 I chose the external player because after following the tutorials I found on here MKV's would bit stream audio on any application on my machine except Emby. I then found some posts that talked about MPC-HC with the Madvr filter to render the best picture and went with that. I would definitely prefer the internal player so I might try to just uninstall all filters and start from scratch. THough if anyone has a solution for my remote control question, I'll take that as well. Thanks for your suggestions so far.
Solution AdrianW 1058 Posted July 22, 2015 Solution Posted July 22, 2015 (edited) In the keys section of options you need to put MEDIA_STOP in the "App Command" column of the "Exit" command row. Edited July 22, 2015 by AdrianW 1
Sammy 791 Posted October 27, 2016 Posted October 27, 2016 In the keys section of options you need to put MEDIA_STOP in the "App Command" column of the "Exit" command row. I have done this to no effect. MPC-HC has just always worked for me but now it isn't.. Hmm..
