speechles 2062 Posted October 29, 2015 Posted October 29, 2015 (edited) the transcoding profiles should allow you to specify multiple audio codecs, comma-delimeted. try that. the first one is the one that will be used if the audio has to be re-encoded. This isn't exactly feasible. What if I want 5.1 in DCA or AC3 to use AC3, but I want 2.0 to use AAC. Using multiple audio codecs doesn't allow this behavior. if surroundSound then t = m.Codecs if t <> invalid then ' dts and ac3 are 5.1, ac3 can pass-through ' pass dts as ac3, pass truehd as ac3 s = CreateObject("roRegex","dts","i") r = CreateObject("roRegex","ac3","i") q = CreateObject("roRegex","truehd","i") if q.isMatch(t) or r.isMatch(t) or s.isMatch(t) then transAudio = "ac3" else transAudio = "aac" end if else transAudio = "aac" end if else transaudio = "aac" end if profiles.push({ Type: "Video" Container: "ts" AudioCodec: transAudio VideoCodec: "h264" Context: "Streaming" Protocol: "Hls" }) m.Codecs is my shortcut cheat of course to i.MediaName so It can be passed among functions. This logic is how the transcoding should be. You can't accomplish this any other way. Also... It is wrong to transcode DIVX/XVID in all MPEG4 streams. You only need to transcode in presence of the MKV container. t = m.Extension if t <> invalid then ' mkv container with mpeg4 cannot be xvid/divx r = CreateObject("roRegex","mkv","i") if r.isMatch(t) then mpeg4Conditions.push({ Condition: "NotEquals" Property: "CodecTag" Value: "DIVX" IsRequired: false }) mpeg4Conditions.push({ Condition: "NotEquals" Property: "CodecTag" Value: "XVID" IsRequired: false }) end if end if The m.Extension is the global shortcut for i.Container which is needed for this. Only in the presence of MKV container should MPEG4 XVID/DIVX streams be transcoded, otherwise they should be remuxed. The fix for DX50 is transcode in any container. The official client needs to use these methods otherwise it will introduce needless transcoding. Also, thanks for adding the codecTag attribute which allows this new detection. Edited October 29, 2015 by speechles
ssmith129 0 Posted December 4, 2015 Posted December 4, 2015 @@BobbyDing Good Question... Why can't emby transcode to the best available codec? Why doesn't it understand ordering preference when transcoding? Because the transcoding part doesn't work this way... Function getTranscodingProfiles() profiles = [] profiles.push({ Type: "Audio" Container: "mp3" AudioCodec: "mp3" Context: "Streaming" Protocol: "Http" }) profiles.push({ Type: "Video" Container: "ts" AudioCodec: "aac" VideoCodec: "h264" Context: "Streaming" Protocol: "Hls" }) return profilesEnd FunctionThe original code for transcoding offers one codec for audio only. shucks... But what if we change the code to like it is below... Function getTranscodingProfiles() surroundSound = SupportsSurroundSound(false, false) audioOutput51 = getGlobalVar("audioOutput51") surroundSoundDCA = surroundSound AND audioOutput51 'AND (RegRead("fivepointoneDCA", "preferences", "1") = "1") surroundSound = surroundSound AND audioOutput51 'AND (RegRead("fivepointone", "preferences", "1") = "1") profiles = [] profiles.push({ Type: "Audio" Container: "mp3" AudioCodec: "mp3" Context: "Streaming" Protocol: "Http" }) if surroundSound then t = m.Codecs if t <> invalid then r = CreateObject("roRegex","ac3","i") if r.isMatch(t) then transAudio = "ac3" else transAudio = "aac" end if else transAudio = "aac" end if else transaudio = "aac" end if profiles.push({ Type: "Video" Container: "ts" AudioCodec: transAudio VideoCodec: "h264" Context: "Streaming" Protocol: "Hls" }) return profilesEnd FunctionThis uses a small cheat, in the way of global space to remember the codecs and then a regular expression can tell if ac3 is there. If so use that, if not, then use the normal aac. The above code isn't the entire changes. There is the part which sets m.Codecs as well. But the benefit here is that this seems to allow transcoding to retain 5.1 surround quite nicely. The new emby blue neon night theme at ( https://my.roku.com/account/add?channel=EmbyBlueNeon ) has this ability. It will transcode and keep surround when possible. I will submit pulls to github so the official client can adopt this too if wanted. Thanks for this post. I've been using Emby Blue Neon since I saw it and I'm very pleased with its ability to play AC-3 audio from .AVI files. Nice job!
Luke 42242 Posted January 11, 2017 Posted January 11, 2017 If you'd like to try a preview of the new Roku app you can do so here: https://emby.media/community/index.php?/topic/43616-new-emby-for-roku-public-preview-beta Please make sure to read the disclaimers. Thanks and enjoy !
