Michael_Schmitz 7 Posted July 19, 2015 Posted July 19, 2015 Hi, just installed newest package für my synology DS415+ Installation worked fine, but I cannot a my libraries /volume1/Music /volume1/Video/Spielfilme It says Path not found Any idea? Best Michael
Michael_Schmitz 7 Posted July 19, 2015 Author Posted July 19, 2015 When I try to add a source to my library. I can select a path on /volume1 but Emby does not find any files in it. And also I cannot choose subdirectories e.g. Videos/films. No Chance.
Luke 42240 Posted July 19, 2015 Posted July 19, 2015 Ok, I think you'll need to mount these as internal shares in order for the server to see them
Michael_Schmitz 7 Posted July 20, 2015 Author Posted July 20, 2015 I read a Little bit into NFS. What would be the IP Adress My NAS has the 192.168.11.12 The Fire TV stick has 192.168.11.5 It would be fantastic if you can tell me what would the correct Options that I have to fill in. I am a totally newbie to that. Do I have to create a own user for that. I see that Plex have done that on my synology. Great thanks in advance.Michael
Gernash 19 Posted July 20, 2015 Posted July 20, 2015 @Michael_Schmitz Emby uses SAMBA by default, NFS is more "server" based. Look in your control panel ==> Shard folder. click on your share name you are trying to access, then edit. Make sure admin has read/write enabled The other way of looking at the permissions is open File station browse to the folder, right click it properties. Then permissions. Make sure read/write is enabled for admin.
Michael_Schmitz 7 Posted July 21, 2015 Author Posted July 21, 2015 Great, I enabled permissions for users on the shared Folders. Now it works, but ... The library scan hangs at 71.6 % completion. Restart the emby Server several times, but it goes no further ;-( Using Server build 5607.2
Luke 42240 Posted July 21, 2015 Posted July 21, 2015 that should be resolved in the latest. is there no newer version available?
Michael_Schmitz 7 Posted July 21, 2015 Author Posted July 21, 2015 good question: emby prompts me, that there is a new Version 5675 availlable and i have manually install it. But I have no new package for Synology. Do you know where to download it for my synology nas?
Gernash 19 Posted July 21, 2015 Posted July 21, 2015 http://emby.media/community/index.php?/topic/22921-synology-setup/?p=224173 Follow the updating instructions until a new package is released.
Michael_Schmitz 7 Posted July 21, 2015 Author Posted July 21, 2015 I installed successfully the 5675 zip. But I still hangs in the process. It never Comes to an end ;-( Any Idea
Gernash 19 Posted July 21, 2015 Posted July 21, 2015 @Michael_Schmitz http://emby.media/community/index.php?/topic/13890-emby-server-on-synology/?p=224162 Most likely this.
Michael_Schmitz 7 Posted July 22, 2015 Author Posted July 22, 2015 Ah, try to understand that und fix my library ;-)
Michael_Schmitz 7 Posted July 22, 2015 Author Posted July 22, 2015 HI , a new Thing every day ;-) NOw Videos are starting for themselves without having selected that. Very annoying.
Gernash 19 Posted July 22, 2015 Posted July 22, 2015 if there are video's in subfolder named the same as folders can cause scanning issues, if you look in the logs it usually shows where the issue is. If you have a dump of files in a folder then it just craps out. it will eventually get through the scan. But when it scanns again I've found it get's bogged down in the same spot over and over. If it is a mess make a new tv and movie folder and use some kind of sorting software to automate and rename it for you like the renamer, mediacenter master or manually with filebot.
Michael_Schmitz 7 Posted July 24, 2015 Author Posted July 24, 2015 Again another Thing I have several libraries for movies and one for tv shows In emby Server I set the up as separate media folders Spielfilme Dokumentationen TV Aufnahmen ... In Kodi (emby for kodi) Emby Server synchronizes only the first media Folder "Spielfilme" and themedia Folder tv Shows Folder, but not the additional movie Folders ??
Gernash 19 Posted July 24, 2015 Posted July 24, 2015 That is a Howto Kodi Question I "Think" your asking how to display different folders on the home page. You edit the tiles in the skin settings ===>Configure shortcuts.
