pditty1995 0 Posted July 18, 2015 Posted July 18, 2015 I want to use the mac to do the transcoding and point the serverwmc plugin to it but i can change the values but when I click save it just glows blue the wheel spins and nothing happens. I change to another page then come back and its the original values. What the heck am i doing wrong. BTW....I do have the workgroup of the wmc public folder mapped and I can add it to like photos and video but it doesn't seem to work with the plugin.
Luke 42237 Posted July 18, 2015 Posted July 18, 2015 maybe try posting the server log with debug logging on. the path to the log is displayed on the front page of the dashboard.
pditty1995 0 Posted July 18, 2015 Author Posted July 18, 2015 There doesn't appear to be anything in the logs But here it is anyway " ============================================================================ " Netrw Directory Listing (netrw v140) " /Users/r_pabis/.config/emby-server/logs " Sorted by name " Sort sequence: [\/]$,\<core\%(\.\d\+\)\=\>,\.h$,\.c$,\.cpp$,*,\.o$,\.obj$,\.info$,\.swp$,\.bak$,\~$ " Quick Help: <F1>:help -:go up dir D:delete R:rename s:sort-by x:exec " ============================================================================ ../ server-63572766599.txt server-63572766674.txt server-63572766688.txt server-63572766918.txt server-63572766954.txt
pditty1995 0 Posted July 18, 2015 Author Posted July 18, 2015 BTW....I was told to add the Macs computer name to /etc/hosts in the first non commented line like this 127.0.0.0 localhost XXXX Where XXXX is the computer name of the mac as found in system preferences->sharing. I also added the windows machine below the last line like this.... 192.168.1.109 YYYYYY Where YYYYYY is the name of the windows machine. Is this correct?
pditty1995 0 Posted July 18, 2015 Author Posted July 18, 2015 (edited) I also found this in another log 2015-07-17 21:55:58.8378 Error - ServerWMC: Running in Linux, but linux path to RecTV directory is not set in plugin configuration page and this at the time i changed it 2015-07-17 22:10:02.8892 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1. HOST: 239.255.255.250:1900. CACHE-CONTROL: max-age = 600. LOCATION: http://127.0.0.1:8095/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml. SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1. NTS: ssdp:alive. NT: uuid:a88351a89d11084d89af5baef10ce1d7. USN: uuid:a88351a89d11084d89af5baef10ce1d7.. *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-17 22:10:13.7309 Info - App: HttpClientManager GET: http://192.168.1.119:49152/4/description.xml2015-07-17 22:10:13.7321 Info - App: HttpClientManager GET: http://169.254.72.176:49152/4/description.xml2015-07-17 22:10:20.8093 Error - DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The socket is not connected System.Net.Sockets.SocketException at System.Net.Sockets.Socket.Shutdown (SocketShutdown how) [0x00000] in <filename unknown>:0 at wmc2mb.SocketClientAsync+<GetVectorAsync>d__0.MoveNext () [0x00000] in <filename unknown>:0 2015-07-17 22:10:20.8093 Error - HttpServer: Error processing request for /Plugins/817527c1-5f78-4763-acb1-59fa0d64854a/Configuration *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The socket is not connected ServiceStack.HttpError No Stack Trace Available Edited July 18, 2015 by pditty1995
Luke 42237 Posted July 18, 2015 Posted July 18, 2015 are you able to save other configuration screens?
pditty1995 0 Posted July 18, 2015 Author Posted July 18, 2015 Yeah just not the plugin. I believe it has something to do with sharing. I tried to use //192.168.1.109, \\192.168.1.109, and \\<windows computer name> and it couldn't resolve. but if i just put in 192.168.1.109 it says The socket is not connected
Luke 42237 Posted July 28, 2015 Posted July 28, 2015 can you grab the server log? the path is displayed on the front page of the server dashboard. thanks.
pditty1995 0 Posted July 28, 2015 Author Posted July 28, 2015 I deleted the logs first, then tried to set the IP address in serverWMC plugin to 192.168.1.132, then waited about 3 minutes and copied logs. Here it is. BTW....on my mac I can't disable the firewall, but I have allowed connections from the mediabrowser application. 015-07-28 12:56:33.6710 Debug - HttpServer: HTTP GET http://localhost:8096/Plugins? Ip: 127.0.0.1:54642. Headers: Host=localhost:8096,Accept-Language=en-us,Accept-Encoding=gzip, deflate,Connection=keep-alive,Accept=application/json, text/javascript, */*; q=0.01,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Authorization=MediaBrowser Client="Emby Web Client", Device="Safari 537.85.16", DeviceId="349fadbc45b9caa8f542cec476ef215fb4b1f8ad", Version="3.0.5675.1", UserId="7154c6f101b54461b291611574e61c9c",X-MediaBrowser-Token=22a2888e31df43288d71c9642b530f7b 2015-07-28 12:56:33.6734 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 2.373 ms. Url: http://localhost:8096/Plugins? 2015-07-28 12:56:33.6788 Debug - HttpServer: HTTP GET http://localhost:8096/dashboard/configurationpages?pageType=PluginConfiguration Ip: 127.0.0.1:54642. Headers: Host=localhost:8096,Accept-Language=en-us,Accept-Encoding=gzip, deflate,Connection=keep-alive,Accept=application/json, text/javascript, */*; q=0.01,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Authorization=MediaBrowser Client="Emby Web Client", Device="Safari 537.85.16", DeviceId="349fadbc45b9caa8f542cec476ef215fb4b1f8ad", Version="3.0.5675.1", UserId="7154c6f101b54461b291611574e61c9c",X-MediaBrowser-Token=22a2888e31df43288d71c9642b530f7b 2015-07-28 12:56:33.6788 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 0.607 ms. Url: http://localhost:8096/dashboard/configurationpages?pageType=PluginConfiguration 2015-07-28 12:56:37.5675 Debug - HttpServer: HTTP GET http://localhost:8096/web/plugins.html Ip: 127.0.0.1:54642. Headers: Host=localhost:8096,Accept-Encoding=gzip, deflate,Accept=text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Accept-Language=en-us,Cache-Control=max-age=0,Connection=keep-alive 2015-07-28 12:56:37.5724 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 4.819 ms. Url: http://localhost:8096/web/plugins.html 2015-07-28 12:56:37.5820 Debug - HttpServer: HTTP GET http://localhost:8096/web/thirdparty/fontawesome/css/font-awesome.min.css?v=3.0.5675.1 Ip: 127.0.0.1:54642. Headers: Host=localhost:8096,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=22f204551d188472e82be34cb93f0bc4,Accept=text/css,*/*;q=0.1,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Accept-Language=en-us,Cache-Control=max-age=0 2015-07-28 12:56:37.5839 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 1.834 ms. Url: http://localhost:8096/web/thirdparty/fontawesome/css/font-awesome.min.css?v=3.0.5675.1 2015-07-28 12:56:37.5853 Debug - HttpServer: HTTP GET http://localhost:8096/web/css/all.css?v=3.0.5675.1 Ip: 127.0.0.1:54644. Headers: Host=localhost:8096,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=e884a041cc995e97ba44a6074eab66b6,Accept=text/css,*/*;q=0.1,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Accept-Language=en-us,Cache-Control=max-age=0 2015-07-28 12:56:37.5853 Debug - SessionManager: Disposing session controller WebSocketController 2015-07-28 12:56:37.5961 Debug - HttpServer: HTTP GET http://localhost:8096/web/scripts/all.js?v=3.0.5675.1 Ip: 127.0.0.1:54645. Headers: Host=localhost:8096,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=e46db26a923e9cf3a7c88bae667b7c60,Accept=*/*,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Accept-Language=en-us,Cache-Control=max-age=0 2015-07-28 12:56:37.6030 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 13.828 ms. Url: http://localhost:8096/web/css/all.css?v=3.0.5675.1 2015-07-28 12:56:37.6036 Debug - HttpServer: HTTP GET http://localhost:8096/web/bower_components/webcomponentsjs/webcomponents-lite.js?v=3.0.5675.1 Ip: 127.0.0.1:54643. Headers: Host=localhost:8096,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=15aa27523651d0c0a511bff6f6573006,Accept=*/*,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Accept-Language=en-us,Cache-Control=max-age=0 2015-07-28 12:56:37.6060 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 7.614 ms. Url: http://localhost:8096/web/scripts/all.js?v=3.0.5675.1 2015-07-28 12:56:37.6067 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 1.637 ms. Url: http://localhost:8096/web/bower_components/webcomponentsjs/webcomponents-lite.js?v=3.0.5675.1 2015-07-28 12:56:37.6183 Debug - HttpServer: HTTP GET http://localhost:8096/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2015-07-27T16:56:37.612Z Ip: 127.0.0.1:54649. Headers: Host=localhost:8096,Connection=keep-alive,Accept=application/json, text/javascript, */*; q=0.01,X-MediaBrowser-Token=6f2b981da22d42edb8d07344ae0c2994,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/44.0.2403.107 Safari/537.36,Authorization=MediaBrowser Client="Emby Web Client", Device="Chrome 44.0.2403.107", DeviceId="0e7f189ec4f83a15c864c218b4b3e924736d7d3c", Version="3.0.5675.1", UserId="7154c6f101b54461b291611574e61c9c",Accept-Encoding=gzip, deflate, sdch,Accept-Language=en-US,en;q=0.8 2015-07-28 12:56:37.6183 Debug - HttpServer: HTTP GET http://localhost:8096/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2015-07-27T16:56:37.611Z Ip: 127.0.0.1:54648. Headers: Host=localhost:8096,Connection=keep-alive,Accept=application/json, text/javascript, */*; q=0.01,X-MediaBrowser-Token=6f2b981da22d42edb8d07344ae0c2994,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/44.0.2403.107 Safari/537.36,Authorization=MediaBrowser Client="Emby Web Client", Device="Chrome 44.0.2403.107", DeviceId="0e7f189ec4f83a15c864c218b4b3e924736d7d3c", Version="3.0.5675.1", UserId="7154c6f101b54461b291611574e61c9c",Accept-Encoding=gzip, deflate, sdch,Accept-Language=en-US,en;q=0.8 2015-07-28 12:56:37.6240 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 5.397 ms. Url: http://localhost:8096/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2015-07-27T16:56:37.611Z 2015-07-28 12:56:37.6244 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 5.924 ms. Url: http://localhost:8096/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2015-07-27T16:56:37.612Z 2015-07-28 12:56:37.6825 Debug - HttpServer: HTTP GET http://localhost:8096/web/vulcanize-out.html Ip: 127.0.0.1:54642. Headers: Host=localhost:8096,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=f974ac5bac18037fdb655bd3a09a1040,Accept=*/*,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Accept-Language=en-us,Cache-Control=max-age=0 2015-07-28 12:56:37.6833 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 0.74 ms. Url: http://localhost:8096/web/vulcanize-out.html 2015-07-28 12:56:38.2031 Debug - HttpServer: HTTP GET http://localhost:8096/Branding/Css Ip: 127.0.0.1:54642. Headers: Host=localhost:8096,Connection=keep-alive,Accept=text/css,*/*;q=0.1,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Accept-Language=en-us,Accept-Encoding=gzip, deflate 2015-07-28 12:56:38.2038 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 0.673 ms. Url: http://localhost:8096/Branding/Css 2015-07-28 12:56:38.3246 Debug - HttpServer: HTTP GET http://localhost:8096/Users/7154c6f101b54461b291611574e61c9c Ip: 127.0.0.1:54642. Headers: Host=localhost:8096,Accept-Language=en-us,Accept-Encoding=gzip, deflate,Connection=keep-alive,Accept=application/json, text/javascript, */*; q=0.01,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Authorization=MediaBrowser Client="Emby Web Client", Device="Safari 537.85.16", DeviceId="349fadbc45b9caa8f542cec476ef215fb4b1f8ad", Version="3.0.5675.1", UserId="7154c6f101b54461b291611574e61c9c",X-MediaBrowser-Token=22a2888e31df43288d71c9642b530f7b 2015-07-28 12:56:38.3301 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 5.437 ms. Url: http://localhost:8096/Users/7154c6f101b54461b291611574e61c9c 2015-07-28 12:56:38.3440 Debug - HttpServer: HTTP GET http://localhost:8096/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2015-07-27T16:56:38.340Z Ip: 127.0.0.1:54649. Headers: Host=localhost:8096,Connection=keep-alive,Accept=application/json, text/javascript, */*; q=0.01,X-MediaBrowser-Token=6f2b981da22d42edb8d07344ae0c2994,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/44.0.2403.107 Safari/537.36,Authorization=MediaBrowser Client="Emby Web Client", Device="Chrome 44.0.2403.107", DeviceId="0e7f189ec4f83a15c864c218b4b3e924736d7d3c", Version="3.0.5675.1", UserId="7154c6f101b54461b291611574e61c9c",Accept-Encoding=gzip, deflate, sdch,Accept-Language=en-US,en;q=0.8 2015-07-28 12:56:38.3454 Debug - HttpServer: HTTP GET http://localhost:8096/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2015-07-27T16:56:38.342Z Ip: 127.0.0.1:54648. Headers: Host=localhost:8096,Connection=keep-alive,Accept=application/json, text/javascript, */*; q=0.01,X-MediaBrowser-Token=6f2b981da22d42edb8d07344ae0c2994,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/44.0.2403.107 Safari/537.36,Authorization=MediaBrowser Client="Emby Web Client", Device="Chrome 44.0.2403.107", DeviceId="0e7f189ec4f83a15c864c218b4b3e924736d7d3c", Version="3.0.5675.1", UserId="7154c6f101b54461b291611574e61c9c",Accept-Encoding=gzip, deflate, sdch,Accept-Language=en-US,en;q=0.8 2015-07-28 12:56:38.3509 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 6.767 ms. Url: http://localhost:8096/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2015-07-27T16:56:38.340Z 2015-07-28 12:56:38.3516 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 6.099 ms. Url: http://localhost:8096/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2015-07-27T16:56:38.342Z 2015-07-28 12:56:38.3570 Debug - HttpServer: HTTP GET http://localhost:8096/Plugins? Ip: 127.0.0.1:54642. Headers: Host=localhost:8096,Accept-Language=en-us,Accept-Encoding=gzip, deflate,Connection=keep-alive,Accept=application/json, text/javascript, */*; q=0.01,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Authorization=MediaBrowser Client="Emby Web Client", Device="Safari 537.85.16", DeviceId="349fadbc45b9caa8f542cec476ef215fb4b1f8ad", Version="3.0.5675.1", UserId="7154c6f101b54461b291611574e61c9c",X-MediaBrowser-Token=22a2888e31df43288d71c9642b530f7b 2015-07-28 12:56:38.3574 Debug - HttpServer: HTTP GET http://localhost:8096/System/Info Ip: 127.0.0.1:54644. Headers: Host=localhost:8096,Accept-Language=en-us,Accept-Encoding=gzip, deflate,Connection=keep-alive,Accept=application/json, text/javascript, */*; q=0.01,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Authorization=MediaBrowser Client="Emby Web Client", Device="Safari 537.85.16", DeviceId="349fadbc45b9caa8f542cec476ef215fb4b1f8ad", Version="3.0.5675.1", UserId="7154c6f101b54461b291611574e61c9c",X-MediaBrowser-Token=22a2888e31df43288d71c9642b530f7b 2015-07-28 12:56:38.3625 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 4.927 ms. Url: http://localhost:8096/System/Info 2015-07-28 12:56:38.3632 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 5.951 ms. Url: http://localhost:8096/Plugins? 2015-07-28 12:56:38.3949 Debug - HttpServer: HTTP POST http://localhost:8096/Sessions/Capabilities/Full Ip: 127.0.0.1:54642. Headers: Host=localhost:8096,Accept=*/*,Authorization=MediaBrowser Client="Emby Web Client", Device="Safari 537.85.16", DeviceId="349fadbc45b9caa8f542cec476ef215fb4b1f8ad", Version="3.0.5675.1", UserId="7154c6f101b54461b291611574e61c9c",X-MediaBrowser-Token=22a2888e31df43288d71c9642b530f7b,Accept-Language=en-us,Accept-Encoding=gzip, deflate,Content-Type=application/json,Origin=http://localhost:8096,Content-Length=354,Connection=keep-alive,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16 2015-07-28 12:56:38.3969 Debug - HttpServer: HTTP GET http://localhost:8096/dashboard/configurationpages?pageType=PluginConfiguration Ip: 127.0.0.1:54644. Headers: Host=localhost:8096,Accept-Language=en-us,Accept-Encoding=gzip, deflate,Connection=keep-alive,Accept=application/json, text/javascript, */*; q=0.01,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Authorization=MediaBrowser Client="Emby Web Client", Device="Safari 537.85.16", DeviceId="349fadbc45b9caa8f542cec476ef215fb4b1f8ad", Version="3.0.5675.1", UserId="7154c6f101b54461b291611574e61c9c",X-MediaBrowser-Token=22a2888e31df43288d71c9642b530f7b 2015-07-28 12:56:38.3989 Debug - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 1.891 ms. Url: http://localhost:8096/dashboard/configurationpages?pageType=PluginConfiguration 2015-07-28 12:56:38.4063 Debug - HttpServer: HTTP Response 204 to 127.0.0.1. Response time: 11.295 ms. Url: http://localhost:8096/Sessions/Capabilities/Full 2015-07-28 12:56:38.4145 Debug - HttpServer: HTTP GET http://localhost:8096/web/thirdparty/jquerymobile-1.4.5/jquery.mobile.custom.icons.css Ip: 127.0.0.1:54642. Headers: Host=localhost:8096,Connection=keep-alive,If-None-Match=b6bf469c9cb1e155504d15033630e080,Accept=text/css,*/*;q=0.1,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Accept-Language=en-us,Accept-Encoding=gzip, deflate 2015-07-28 12:56:38.4155 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 0.954 ms. Url: http://localhost:8096/web/thirdparty/jquerymobile-1.4.5/jquery.mobile.custom.icons.css 2015-07-28 12:56:38.4502 Debug - HttpServer: Web Socket ws://localhost:8096/?api_key=22a2888e31df43288d71c9642b530f7b&deviceId=349fadbc45b9caa8f542cec476ef215fb4b1f8ad Ip: 127.0.0.1:54650. Headers: Upgrade=websocket,Connection=Upgrade,Host=localhost:8096,Origin=http://localhost:8096,Pragma=no-cache,Cache-Control=no-cache,Sec-WebSocket-Key=/xqdGvdgy5YEHn7BjKwgnA==,Sec-WebSocket-Version=13,Sec-WebSocket-Extensions=x-webkit-deflate-frame,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16 2015-07-28 12:56:38.4543 Debug - HttpServer: Web socket connection allowed 2015-07-28 12:56:41.7305 Debug - HttpServer: HTTP GET http://localhost:8096/web/ConfigurationPage?name=ServerWMC Addon Ip: 127.0.0.1:54642. Headers: Host=localhost:8096,Connection=keep-alive,If-None-Match=862c052f044d8bf5b4694bb3f0cb9284,Accept=text/html, */*; q=0.01,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Accept-Language=en-us,Accept-Encoding=gzip, deflate 2015-07-28 12:56:41.7310 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 0.481 ms. Url: http://localhost:8096/web/ConfigurationPage?name=ServerWMC Addon 2015-07-28 12:56:41.7558 Debug - HttpServer: HTTP GET http://localhost:8096/Plugins/817527c1-5f78-4763-acb1-59fa0d64854a/Configuration Ip: 127.0.0.1:54642. Headers: Host=localhost:8096,Accept-Language=en-us,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=612cb19fa185cb0dbca5d9a00998c943,Accept=application/json, text/javascript, */*; q=0.01,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Authorization=MediaBrowser Client="Emby Web Client", Device="Safari 537.85.16", DeviceId="349fadbc45b9caa8f542cec476ef215fb4b1f8ad", Version="3.0.5675.1", UserId="7154c6f101b54461b291611574e61c9c",X-MediaBrowser-Token=22a2888e31df43288d71c9642b530f7b 2015-07-28 12:56:41.7574 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 1.58 ms. Url: http://localhost:8096/Plugins/817527c1-5f78-4763-acb1-59fa0d64854a/Configuration 2015-07-28 12:56:43.7310 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: upnp:rootdevice . USN: uuid:a88351a89d11084d89af5baef10ce1d7::upnp:rootdevice . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:56:43.7310 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:device:MediaServer:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:device:MediaServer:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:56:43.7317 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:service:ContentDirectory:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:service:ContentDirectory:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:56:43.7329 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:service:ConnectionManager:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:service:ConnectionManager:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:56:43.7340 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:56:43.7340 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: uuid:a88351a89d11084d89af5baef10ce1d7 . USN: uuid:a88351a89d11084d89af5baef10ce1d7 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:56:50.3174 Debug - HttpServer: HTTP GET http://localhost:8096/Plugins/817527c1-5f78-4763-acb1-59fa0d64854a/Configuration Ip: 127.0.0.1:54642. Headers: Host=localhost:8096,Accept-Language=en-us,Accept-Encoding=gzip, deflate,Connection=keep-alive,If-None-Match=612cb19fa185cb0dbca5d9a00998c943,Accept=application/json, text/javascript, */*; q=0.01,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16,Authorization=MediaBrowser Client="Emby Web Client", Device="Safari 537.85.16", DeviceId="349fadbc45b9caa8f542cec476ef215fb4b1f8ad", Version="3.0.5675.1", UserId="7154c6f101b54461b291611574e61c9c",X-MediaBrowser-Token=22a2888e31df43288d71c9642b530f7b 2015-07-28 12:56:50.3190 Debug - HttpServer: HTTP Response 304 to 127.0.0.1. Response time: 1.516 ms. Url: http://localhost:8096/Plugins/817527c1-5f78-4763-acb1-59fa0d64854a/Configuration 2015-07-28 12:56:50.3223 Debug - HttpServer: HTTP POST http://localhost:8096/Plugins/817527c1-5f78-4763-acb1-59fa0d64854a/Configuration Ip: 127.0.0.1:54642. Headers: Host=localhost:8096,Accept=*/*,Authorization=MediaBrowser Client="Emby Web Client", Device="Safari 537.85.16", DeviceId="349fadbc45b9caa8f542cec476ef215fb4b1f8ad", Version="3.0.5675.1", UserId="7154c6f101b54461b291611574e61c9c",X-MediaBrowser-Token=22a2888e31df43288d71c9642b530f7b,Accept-Language=en-us,Accept-Encoding=gzip, deflate,Content-Type=application/json,Origin=http://localhost:8096,Content-Length=87,Connection=keep-alive,User-Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/600.7.12 (KHTML, like Gecko) Version/7.1.7 Safari/537.85.16 2015-07-28 12:56:50.3333 Error - DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The socket is not connected System.Net.Sockets.SocketException at System.Net.Sockets.Socket.Shutdown (SocketShutdown how) [0x00000] in <filename unknown>:0 at wmc2mb.SocketClientAsync+<GetVectorAsync>d__0.MoveNext () [0x00000] in <filename unknown>:0 2015-07-28 12:56:50.3333 Error - HttpServer: Error processing request for /Plugins/817527c1-5f78-4763-acb1-59fa0d64854a/Configuration *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The socket is not connected ServiceStack.HttpError No Stack Trace Available 2015-07-28 12:56:50.3333 Debug - HttpServer: HTTP Response 500 to 127.0.0.1. Response time: 11.21 ms. Url: http://localhost:8096/Plugins/817527c1-5f78-4763-acb1-59fa0d64854a/Configuration 2015-07-28 12:57:13.7262 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: upnp:rootdevice . USN: uuid:a88351a89d11084d89af5baef10ce1d7::upnp:rootdevice . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:57:13.7275 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:device:MediaServer:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:device:MediaServer:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:57:13.7275 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:service:ContentDirectory:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:service:ContentDirectory:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:57:13.7287 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:service:ConnectionManager:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:service:ConnectionManager:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:57:13.7296 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:57:13.7296 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: uuid:a88351a89d11084d89af5baef10ce1d7 . USN: uuid:a88351a89d11084d89af5baef10ce1d7 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:57:33.6629 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: e792007447f5433082394bac3aaa55b4 2015-07-28 12:57:33.6629 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 89f4147443f94b1ba1046dd4ebb9db58 2015-07-28 12:57:33.6629 Debug - HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: cac4ef0e99124d5f801f555ddd145901 2015-07-28 12:57:43.7236 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: upnp:rootdevice . USN: uuid:a88351a89d11084d89af5baef10ce1d7::upnp:rootdevice . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:57:43.7246 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:device:MediaServer:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:device:MediaServer:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:57:43.7255 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:service:ContentDirectory:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:service:ContentDirectory:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:57:43.7268 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:service:ConnectionManager:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:service:ConnectionManager:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:57:43.7281 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:57:43.7281 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: uuid:a88351a89d11084d89af5baef10ce1d7 . USN: uuid:a88351a89d11084d89af5baef10ce1d7 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:58:13.7196 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: upnp:rootdevice . USN: uuid:a88351a89d11084d89af5baef10ce1d7::upnp:rootdevice . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:58:13.7196 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:device:MediaServer:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:device:MediaServer:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:58:13.7210 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:service:ContentDirectory:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:service:ContentDirectory:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:58:13.7213 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:service:ConnectionManager:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:service:ConnectionManager:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:58:13.7213 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:58:13.7213 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: uuid:a88351a89d11084d89af5baef10ce1d7 . USN: uuid:a88351a89d11084d89af5baef10ce1d7 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:58:43.7175 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: upnp:rootdevice . USN: uuid:a88351a89d11084d89af5baef10ce1d7::upnp:rootdevice . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:58:43.7175 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:device:MediaServer:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:device:MediaServer:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:58:43.7180 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:service:ContentDirectory:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:service:ContentDirectory:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:58:43.7180 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:service:ConnectionManager:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:service:ConnectionManager:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:58:43.7192 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:58:43.7192 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: uuid:a88351a89d11084d89af5baef10ce1d7 . USN: uuid:a88351a89d11084d89af5baef10ce1d7 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:59:13.7132 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: upnp:rootdevice . USN: uuid:a88351a89d11084d89af5baef10ce1d7::upnp:rootdevice . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:59:13.7140 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:device:MediaServer:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:device:MediaServer:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:59:13.7140 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:service:ContentDirectory:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:service:ContentDirectory:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:59:13.7152 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:schemas-upnp-org:service:ConnectionManager:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:schemas-upnp-org:service:ConnectionManager:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:59:13.7160 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 . USN: uuid:a88351a89d11084d89af5baef10ce1d7::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0 2015-07-28 12:59:13.7160 Error - SsdpHandler: Error sending Datagram to 239.255.255.250:1900 from 127.0.0.1:0: NOTIFY * HTTP/1.1 . HOST: 239.255.255.250:1900 . CACHE-CONTROL: max-age = 600 . LOCATION: http://127.0.0.1:8096/dlna/a88351a89d11084d89af5baef10ce1d7/description.xml . SERVER: Unix32/13.4 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5675.1 . NTS: ssdp:alive . NT: uuid:a88351a89d11084d89af5baef10ce1d7 . USN: uuid:a88351a89d11084d89af5baef10ce1d7 . . *** Error Report *** Version: 3.0.5675.1 Command line: /Applications/MediaBrowser.Server.Mac.app/Contents/MacOS/MediaBrowser.Server.Mac Operating system: Unix 13.4.0.0 Processor count: 8 64-Bit OS: False 64-Bit Process: False Program data path: /Users/r_pabis/.config/emby-server Mono: 3.12.1 ((detached/0849ec7) Application Path: /Applications/MediaBrowser.Server.Mac.app/Contents/MonoBundle/MediaBrowser.Server.Mac.exe The requested address is not valid in this context System.Net.Sockets.SocketException at System.Net.Sockets.Socket.EndSend (IAsyncResult result) [0x00000] in <filename unknown>:0 at MediaBrowser.Dlna.Ssdp.Datagram+<Send>c__AnonStorey0.<>m__0 (IAsyncResult result) [0x00000] in <filename unknown>:0
pditty1995 0 Posted July 28, 2015 Author Posted July 28, 2015 One other thing.....I have two NICs. The Ethernet is first in service order and is my work address 10.XXX.XXX.XXX and then the WIFI is second which is 192.168.1.XXX. If that is contributing as well...IDK. I tried disabling the Ethernet as well as moving the WIFI to first in service order but that didn't help either.
