Luke 42243 Posted August 12, 2020 Posted August 12, 2020 41 minutes ago, Figment123456 said: Is there a wake on lan option for Emby? Read there is on android mobile but I see no option when selecting server Try connecting to the server once. After that it should appear in the menu.
Guest Posted August 12, 2020 Posted August 12, 2020 I'm able to connect to the server after I manually wake my PC, no option appears for wake on lan.
Guest Posted August 12, 2020 Posted August 12, 2020 It works now, I had to uninstall and reinstall app. Kind of weird but problem sovled!
gokuz 13 Posted August 22, 2020 Posted August 22, 2020 @Luke Anything happened in between 3.0.27 and the latest regarding .strm files. Its unplayable on the latest version. I can scrub files, resume from strm files in 3.0.27. But the latest version is unplayable even from start.
pwhodges 2033 Posted August 22, 2020 Posted August 22, 2020 My webcam strm files are still working fine with current betas of both Android client and server. Paul
Luke 42243 Posted August 22, 2020 Posted August 22, 2020 54 minutes ago, gokuz said: @Luke Anything happened in between 3.0.27 and the latest regarding .strm files. Its unplayable on the latest version. I can scrub files, resume from strm files in 3.0.27. But the latest version is unplayable even from start. We're happy to help. Please see how to report a media playback issue. Thanks !
a5ian300zx 7 Posted September 30, 2020 Posted September 30, 2020 When can we get the exoplayer for android mobile? The libmpv player is old and does not work well with hdr content. The exoplayer is already available e android tv (shield tv pro). Thanks
Luke 42243 Posted September 30, 2020 Posted September 30, 2020 23 minutes ago, a5ian300zx said: When can we get the exoplayer for android mobile? The libmpv player is old and does not work well with hdr content. The exoplayer is already available e android tv (shield tv pro). Thanks Hi, jump into the testing area of the community to try it 1
nonyhaha 4 Posted October 31, 2020 Posted October 31, 2020 Hello. Anybody having issues with themes on android? Both my phones are no longer able to change the main screen theme. Any theme i choose, it will do nothing to the media library pages. I have a monthly subscription on the server.
Luke 42243 Posted October 31, 2020 Posted October 31, 2020 7 hours ago, nonyhaha said: Hello. Anybody having issues with themes on android? Both my phones are no longer able to change the main screen theme. Any theme i choose, it will do nothing to the media library pages. I have a monthly subscription on the server. Hi, we'll take a look at this. Thanks for reporting.
nonyhaha 4 Posted November 1, 2020 Posted November 1, 2020 (edited) 5 hours ago, Luke said: Hi, we'll take a look at this. Thanks for reporting. Thank you @Luke, the theme it is stuck on is stock orange accent. The settings page is abe to be switched. At least to dark with red accent. This is wired af. Just started the app again an it was running apple tv skin, which i tried on last last night. I did close the app last night from task manager but it was not changing themes. I tried doing this on a galaxy s7 and s10. Edited November 1, 2020 by nonyhaha Add info
ErikRedbeard 0 Posted January 20, 2021 Posted January 20, 2021 (edited) If I open the android app and then try to connect directly to the auto detected server it fails with "Connection Failure - We're unable to connect to the selected server right now. Please ensure it is running and try again.". But if I go via Add Server" and enter the IP of the emby server (192.168.1.4) and leave port default it just connects without issues. And from that point the auto detected one works too (seems like the Add Server replaced the auto detected one though). Here's a screenshot of the IP on the emby server I'm confused on why the one auto detected (which has the correct display name) doesn't work until I Add the Server manually (which seems to replace the auto found one, and not actually add one). Would be nice for the autofind to just work for the ones in the household that aren't that tech savvy. Does the auto detected one not connect via IP on local or? Edited January 21, 2021 by ErikRedbeard Moved to own topic.
Luke 42243 Posted January 21, 2021 Posted January 21, 2021 On 1/19/2021 at 7:02 PM, ErikRedbeard said: If I open the android app and then try to connect directly to the auto detected server it fails with "Connection Failure - We're unable to connect to the selected server right now. Please ensure it is running and try again.". But if I go via Add Server" and enter the IP of the emby server (192.168.1.4) and leave port default it just connects without issues. And from that point the auto detected one works too (seems like the Add Server replaced the auto detected one though). Here's a screenshot of the IP on the emby server I'm confused on why the one auto detected (which has the correct display name) doesn't work until I Add the Server manually (which seems to replace the auto found one, and not actually add one). Would be nice for the autofind to just work for the ones in the household that aren't that tech savvy. Does the auto detected one not connect via IP on local or? Will help you in your topic: Thanks.
bluemonkey07 590 Posted February 11, 2021 Posted February 11, 2021 (edited) what is (or will be) the emby teams solution to Android 11 blocking user access to the emby download location? @Luke ? Edited February 17, 2021 by Vidman tagged developer
jordy 284 Posted February 11, 2021 Posted February 11, 2021 3 minutes ago, Vidman said: what is (or will be) the emby teams solution to Android 11 blocking user access to the emby download location? Are you blocked? I'm using a Pixel 5 with the absolute latest Android 11 updates (Feb 2021) and have no problem accessing any part of emby whether on Wi-fi or mobile 4/5g networks... Although, I don't use the Android Server...
bluemonkey07 590 Posted February 11, 2021 Posted February 11, 2021 3 hours ago, jordy said: Are you blocked? I'm using a Pixel 5 with the absolute latest Android 11 updates (Feb 2021) and have no problem accessing any part of emby whether on Wi-fi or mobile 4/5g networks... Although, I don't use the Android Server... do you download (not stream, download) emby content? if so can you access that content from any other Android app? if so please provide details
jordy 284 Posted February 12, 2021 Posted February 12, 2021 20 hours ago, Vidman said: do you download (not stream, download) emby content? if so can you access that content from any other Android app? if so please provide details I have downloaded an episode - by selecting it in the Emby for Android app on the phone and selecting the Download button - over wi-fi. Download completed quickly and it plays fine in Emby on the phone but I cannot find out where the actual file is stored in the phones Internal Memory. If you can point me to the location, I will see if I can play it with something else.
bluemonkey07 590 Posted February 12, 2021 Posted February 12, 2021 1 hour ago, jordy said: I have downloaded an episode - by selecting it in the Emby for Android app on the phone and selecting the Download button - over wi-fi. Download completed quickly and it plays fine in Emby on the phone but I cannot find out where the actual file is stored in the phones Internal Memory. If you can point me to the location, I will see if I can play it with something else. that is my point, Android 11 has blocked access to this location which was previously accessible in the android/data folder on internal or external storage 1
Banquero 38 Posted October 11, 2022 Posted October 11, 2022 Buenas tardes..Tengo instalada la versión beta de Emby para android...Donde puede ver las mejoras que se van implementando en dichas betas? Muchas gracias...
Luke 42243 Posted October 11, 2022 Posted October 11, 2022 14 minutes ago, Banquero said: Buenas tardes..Tengo instalada la versión beta de Emby para android...Donde puede ver las mejoras que se van implementando en dichas betas? Muchas gracias... Hi, you can follow the blog for normal release announcements: https://emby.media/community/index.php?/blogs/ And the testing area for beta builds: https://emby.media/community/index.php?/forum/123-android/ Thanks. 1
Banquero 38 Posted October 12, 2022 Posted October 12, 2022 Por cierto @Luke, en la versión de Android que utilizo en la TV (me gusta más que Emby Android TV), cuando termina una capítulo de una serie y va a comenzar el siguiente aparecen dos botones, creo recordar "seguir viendo" y " siguiente capítulo", pero no aparece el argumento del nuevo capítulo como en otras aplicaciones de Emby. Es así o debo configurar algo? Muchas gracias...
Banquero 38 Posted October 18, 2022 Posted October 18, 2022 On 10/12/2022 at 10:16 AM, Banquero said: Por cierto @Luke, en la versión de Android que utilizo en la TV (me gusta más que Emby Android TV), cuando termina una capítulo de una serie y va a comenzar el siguiente aparecen dos botones, creo recordar "seguir viendo" y " siguiente capítulo", pero no aparece el argumento del nuevo capítulo como en otras aplicaciones de Emby. Es así o debo configurar algo? Muchas gracias... A ver sí puedes pronunciarte @Luke. Muchas gracias ... 1
Luke 42243 Posted October 18, 2022 Posted October 18, 2022 On 10/12/2022 at 4:16 AM, Banquero said: Por cierto @Luke, en la versión de Android que utilizo en la TV (me gusta más que Emby Android TV), cuando termina una capítulo de una serie y va a comenzar el siguiente aparecen dos botones, creo recordar "seguir viendo" y " siguiente capítulo", pero no aparece el argumento del nuevo capítulo como en otras aplicaciones de Emby. Es así o debo configurar algo? Muchas gracias... Hi, yes it's something we can look at adding in future updates. Thanks.
chalard87 2 Posted April 6, 2023 Posted April 6, 2023 Hi, the Android mobile version of Emby is very nice, I use it with great pleasure. ... Except for one very annoying thing : My movies or series always start playing in "Auto" Aspect Ratio. I want them to always start with "Adapter" ("Adjust" or "Fit" in English?). Is there a way to keep this setting On? Thanks a lot for Emby and your hard work.
