James W 7 Posted September 10, 2016 Posted September 10, 2016 Thanks for the feedback. Much of the inspiration actually came from Google+, which actually uses both a hamburger and bottom tab navigation. but have you seen this? http://www.theverge.com/2016/3/15/11236152/material-design-update-bottom-navigation-bar It looks like they will be going in that direction in their apps as well. I have not used G+ in a while so explains that one I guess once it goes mainstream I will get used to it. Would it be hard to keep both? Seems the manage server section still has hamburger navigation and due to the number of selections should probably stay that way. Seems more fluid if there will be hamburger navigation in one section to keep it in others as well.
Luke 42243 Posted September 11, 2016 Posted September 11, 2016 I have not used G+ in a while so explains that one I guess once it goes mainstream I will get used to it. Would it be hard to keep both? Seems the manage server section still has hamburger navigation and due to the number of selections should probably stay that way. Seems more fluid if there will be hamburger navigation in one section to keep it in others as well. I see what you're saying but that's really a secondary function of the app. I wouldn't want the entire app to be forced to do one thing or another based on that.
Luke 42243 Posted September 26, 2016 Posted September 26, 2016 How can i connect to a server ? Hi, welcome. Take a look at our Quick Start guide. Short answer - you need your own server or you need to connect to a friend's server. Thanks !
Sifu Panda 0 Posted September 26, 2016 Posted September 26, 2016 I'm a new user. So i don't know ho to use this app. But i want to use the app. And don't know how can i ge a server.
Luke 42243 Posted September 26, 2016 Posted September 26, 2016 Hi !. Take a look at our Quick Start guide. Short answer - you need to install Emby server or you need to connect to a friend's server. Thanks ! 1
Luke 42243 Posted October 16, 2016 Posted October 16, 2016 For those running the open beta I've added support for palette colors, which adds a nice touch. Please let me know your feedback on that. Thanks!
Luke 42243 Posted November 21, 2016 Posted November 21, 2016 Just looking to collect some feedback on many of the recent interface changes. You may have noticed increased spacing throughout the app just to make content easier to read. Also there is more use of the color palettes within card titles. Lastly, now that we've had the bottom tabs for a little while, how would you compare them vs. the hamburger menu? Thanks !
billzkid 1 Posted November 21, 2016 Posted November 21, 2016 I like it a lot! I don't know what was hamburger menu, but tabs work for me fine!
CBers 7554 Posted November 21, 2016 Posted November 21, 2016 Personally, I don't like the tabs at the bottom. I prefer and use the mobile version of the server instead. 1
anderbytes 141 Posted November 21, 2016 Posted November 21, 2016 I don't know how hard would be to allow users to choose between the scrollable left-panel, and the current one. Both have it's benefits 1
Latchmor 584 Posted November 22, 2016 Posted November 22, 2016 Yeah I like the bottom menu. To be honest, at the moment I really only use the app to check the dashboard for any updates or do some manual scans. For the hamburger menu, if you had a choice of which side, I'd put it right and prefer that instead of the bottom one. Easier for one handed use when right handed but that's hardly a deal breaker
jordy 284 Posted November 22, 2016 Posted November 22, 2016 I quite like it. It would be even better if the menus weren't crashing the app. Still doing it with 2.8.24 beta.
Luke 42243 Posted December 20, 2016 Posted December 20, 2016 In addition to the play store, release notes can also be found here now: https://emby.media/community/index.php?/topic/42780-emby-for-android-release-notes
anderbytes 141 Posted December 20, 2016 Posted December 20, 2016 I'm having some bugs in my playback experience: - Subtitle are being shown in the middle of the screen, not in the bottom - Sometimes the Emby logo that appears at the start of the playback doesn't disappear. It stays there during the playback
Luke 42243 Posted December 20, 2016 Posted December 20, 2016 Thanks for the report. We'll take a look.
sh0rty 727 Posted December 21, 2016 Posted December 21, 2016 (edited) I'm a new user. So i don't know ho to use this app. But i want to use the app. And don't know how can i ge a server. You should really read the whole wiki from beginning. Every question is answered there. https://github.com/MediaBrowser/Wiki/wiki Edit: Just recognized the post is 3 months old Edited December 21, 2016 by shorty1483
anderbytes 141 Posted December 29, 2016 Posted December 29, 2016 Thanks for the report. We'll take a look.The subtitles are okay again, but the logo issue still remains. Could you reproduce it?
