Luke 42243 Posted March 20, 2016 Posted March 20, 2016 In both the web app (app.emby.media) and the android Emby app, from the left slide out menu, where Home is at top left, there is, beneath Home, C Drive, D Drive, PlayLists, though the order of these elements can be altered by the user. Selecting Playlists, displays a Playlist. This is where the dupes appear. There are three playlists displayed for each playlist I have created, of which two dupes that should not be displayed. Each playlist display consists of a thumbnail, which you call a Poster, and a name. Randy Are there actually three distinct items you can click on? Are you sure it's not just the auto-generated thumbnail image with 3 slices?
Randy Kerr 0 Posted March 21, 2016 Posted March 21, 2016 Yes. I am sure. This also reflected in the nunber of playlists. That number is displayed at the top of the playlist page as 1 of 31, where it should say 1 of 11.
Randy Kerr 0 Posted March 28, 2016 Posted March 28, 2016 The dupe (triplicate) listing of my playlists problem has been rectified. Thank you. Randy
Randy Kerr 0 Posted March 29, 2016 Posted March 29, 2016 Hey Luke, Is it normal that, when playing from a playlist (I chose "Play all from here), the Remote Function doesn't work? BTW,I quite like the way the playlists are displayed now, alphabetically. Cheers, Randy
Luke 42243 Posted March 29, 2016 Posted March 29, 2016 No, sending a playlist to another device should work just fine.
Randy Kerr 0 Posted March 29, 2016 Posted March 29, 2016 Hey Luke,.about the remote function ...It's working now Cheers, Randy
bluemonkey07 590 Posted April 27, 2016 Posted April 27, 2016 Now that the android TV app is again relegated to only android tv/5.0 + devices is there any chance the mobile app can add support for basic navigation via remote/gamepad (up, down, left, right and select... And maybe menu)
Luke 42243 Posted April 27, 2016 Posted April 27, 2016 Now that the android TV app is again relegated to only android tv/5.0 + devices is there any chance the mobile app can add support for basic navigation via remote/gamepad (up, down, left, right and select... And maybe menu) Now that you mention it: http://emby.media/community/index.php?/topic/34318-android-mobile-2652/
bluemonkey07 590 Posted April 27, 2016 Posted April 27, 2016 (edited) Now that you mention it: http://emby.media/community/index.php?/topic/34318-android-mobile-2652/ Now that looks great:)Now I just need xmltv support so I can try it out;) Edited April 27, 2016 by Vidman
Luke 42243 Posted May 19, 2016 Posted May 19, 2016 There's a new release that's slowly rolling out that should resolve all of the HTTPS issues. Thanks to everyone who helped test this, especially @@anderbytes
statik 0 Posted May 19, 2016 Posted May 19, 2016 I have been unable to use the internal player with the 2.6 versions. The last version to play movies with both internal and external players was 2.4.30. f915da17-5fcb-415f-b54c-d35aa617c2bd.log
Luke 42243 Posted May 19, 2016 Posted May 19, 2016 I have been unable to use the internal player with the 2.6 versions. The last version to play movies with both internal and external players was 2.4.30. Hi, can you try the open beta version? http://emby.media/community/index.php?/topic/24350-android-open-beta-testing/ If the issue persists, then please provide a new log, although it's going to be in a new location now due to android 6.0 permission changes, under data/com.mb.android. Thanks. 1
anderbytes 141 Posted May 19, 2016 Posted May 19, 2016 (edited) There's a new release that's slowly rolling out that should resolve all of the HTTPS issues. Thanks to everyone who helped test this, especially @@anderbytes Thank you too for the excellent work on the software. Edited May 19, 2016 by anderbytes
statik 0 Posted May 20, 2016 Posted May 20, 2016 Hi, can you try the open beta version? http://emby.media/community/index.php?/topic/24350-android-open-beta-testing/ If the issue persists, then please provide a new log, although it's going to be in a new location now due to android 6.0 permission changes, under data/com.mb.android. Thanks.
statik 0 Posted May 20, 2016 Posted May 20, 2016 The internal player works great in the beta but my external player is unable to fast forward.
Luke 42243 Posted May 20, 2016 Posted May 20, 2016 The internal player works great in the beta but my external player is unable to fast forward. So this is still a big step forward right? Because you said the last playable build you had was 2.4.30 which I think was a year ago. It sounds like the external player can't fast forward due to transcoding. If you try customizing the in-app bitrate to a high value, that may prevent that from happening, although for best results we generally suggest leaving it on Auto.
statik 0 Posted May 20, 2016 Posted May 20, 2016 So this is still a big step forward right? Because you said the last playable build you had was 2.4.30 which I think was a year ago. It sounds like the external player can't fast forward due to transcoding. If you try customizing the in-app bitrate to a high value, that may prevent that from happening, although for best results we generally suggest leaving it on Auto. Thank you for the great work.
Luke 42243 Posted July 3, 2016 Posted July 3, 2016 2.7.13 is available now on the open beta. Sync has been reworked to use the storage access framework. You should have no trouble with external SD cards now. Additionally, it supports any android storage provider as the backing storage for your sync files. That means you can use internal storage, sd card, google drive, whatever you like. For those who are new to the open beta, you can sign up here: https://play.google..../com.mb.android Enjoy. 2
anderbytes 141 Posted July 3, 2016 Posted July 3, 2016 Very good, Luke. I've seen in code that subtitles aren't really "synced", just downloaded, that answers why they aren't removed along when their video are, and also aren't updated when their content changes. Is that correction planned? Thanks
Luke 42243 Posted July 6, 2016 Posted July 6, 2016 The update is going to begin to roll out over the next several days. Since the app requires authorization for the specific folder that you choose in the directory picker, you'll need to reconfigure your sync path. Once complete, you'll be able to sync to internal storage, SD card, google drive, or any other android storage provider. Enjoy.
dark_slayer 103 Posted July 6, 2016 Posted July 6, 2016 The update is going to begin to roll out over the next several days. Since the app requires authorization for the specific folder that you choose in the directory picker, you'll need to reconfigure your sync path. Once complete, you'll be able to sync to internal storage, SD card, google drive, or any other android storage provider. Enjoy.Will it appear native to the app like synced content is presented in Google music or Plex?
Guest asrequested Posted August 4, 2016 Posted August 4, 2016 I may be living up to my name here, but I can't seem to find a way to download an album other than download the individual songs. What am I missing?
Luke 42243 Posted August 4, 2016 Posted August 4, 2016 there isn't. you can use the sync feature to do that.
