Mozy 1 Posted December 20, 2014 Posted December 20, 2014 I'm having the opposite problem with video size on the latest release, where video is scaled down on my Note 4. It looks like it is possibly playing at native resolution (1080p) on the "4k" display. Here's a screenshot.
blade005 185 Posted December 20, 2014 Posted December 20, 2014 I'm having the opposite problem with video size on the latest release, where video is scaled down on my Note 4. It looks like it is possibly playing at native resolution (1080p) on the "4k" display. Here's a screenshot. Since the issue seems to be with it recognizing the max display resolution of the device, I would suspect the fix Red is working on might resolve both of our issues.
Redshirt 1487 Posted December 21, 2014 Author Posted December 21, 2014 Version 2.1.34 has been published. You guys should start seeing it shortly. Fixes include - Improve connection logic. Hopefully less timeouts will occur. - Fixes to subtitle/audio stream selection dialogs - Fix video scaling issue introduced in last release
blade005 185 Posted December 21, 2014 Posted December 21, 2014 Version 2.1.34 has been published. You guys should start seeing it shortly. Fixes include - Improve connection logic. Hopefully less timeouts will occur. - Fixes to subtitle/audio stream selection dialogs - Fix video scaling issue introduced in last release Red, Thanks for the quick update. Video scaling issue is resolved. I notice now that HLS ON plays all media types and Live TV stream. HLS OFF plays all media types, but locks up MB Android on Live TV streams. I can live with that, but I find HLS OFF starts up all streams much quicker, especially Recorded TV and Live TV streams and seeking is much quicker. Just wondering if it is something that could be resolved. (Android 4.4.4 OS)
Redshirt 1487 Posted December 21, 2014 Author Posted December 21, 2014 I'm able to reproduce. It will be fixed for next release.
cpthooker 3 Posted December 21, 2014 Posted December 21, 2014 Thanks for the quick fix. Works great now
Deihmos 170 Posted December 21, 2014 Posted December 21, 2014 (edited) I never got MB Connect to work remotely but it seems to work on Lan. It shows the correct server when I use MB Connect but when I try to connect nothing happens. When I manually enter the server address it works fine. Edited December 21, 2014 by Deihmos 1
Luke 42242 Posted December 21, 2014 Posted December 21, 2014 then check the server address in the dashboard because that's what connect is using. you can manually override it
iam4uk 26 Posted December 22, 2014 Posted December 22, 2014 Build 2.1.28 has just been published. Notable changes are Fix status bar showing up during video playback. Also fully hides the soft-keys on Android 4.4+ devices. Pressing "Home" in the navigation drawer now clears the back-stack. So pressing back on the homescreen won't lead to somewhere else in your library. Thanks for true full-screen, hiding softkeys. 2
CBers 7554 Posted December 30, 2014 Posted December 30, 2014 When did the app become free? In the last few days.
Deihmos 170 Posted December 30, 2014 Posted December 30, 2014 In the last few days. I did not see an announcement. I bought it when it launched.
Deihmos 170 Posted December 30, 2014 Posted December 30, 2014 (edited) I cannot view that thread. Edited December 30, 2014 by Deihmos
CBers 7554 Posted December 30, 2014 Posted December 30, 2014 I cannot view that thread. Oh, it's seems to be hidden
Latchmor 584 Posted December 30, 2014 Posted December 30, 2014 Oh, it's seems to be hidden Yeah, I can't see it either but I had seen elsewhere he was leaving
Abobader 3485 Posted December 30, 2014 Posted December 30, 2014 Good day, At the moment let just wait and see, final words about this matters will come from Luke and Ebr for the community members. My best I cannot view that thread. Oh, it's seems to be hidden
whiteb68 2 Posted January 1, 2015 Posted January 1, 2015 ive purchased the app from the play store, is there a way i can get the apk to try and side-load it on my nexus player?
Luke 42242 Posted January 1, 2015 Posted January 1, 2015 ive purchased the app from the play store, is there a way i can get the apk to try and side-load it on my nexus player? Not yet. We are working on getting a release out for that though.
MSattler 390 Posted January 1, 2015 Posted January 1, 2015 Not yet. We are working on getting a release out for that though. Does this mean we could end up sideloading this on Amazon devices which do not have the Google Play store?
mediacowboy 438 Posted January 1, 2015 Posted January 1, 2015 There is going to be a amazon app. Which is what they are working on 1
MSattler 390 Posted January 1, 2015 Posted January 1, 2015 There is going to be a amazon app. Which is what they are working on I understand that, but until it is released, sometime later in January, one could use this for now.
dark_slayer 103 Posted January 1, 2015 Posted January 1, 2015 ive purchased the app from the play store, is there a way i can get the apk to try and side-load it on my nexus player?You can with titanium backup. Probably other apps as well as other methods but that's the easiest one I know of
whiteb68 2 Posted January 1, 2015 Posted January 1, 2015 You can with titanium backup. Probably other apps as well as other methods but that's the easiest one I know of Thank you, Worked to get the apk!
whiteb68 2 Posted January 1, 2015 Posted January 1, 2015 other then the over-scan (tried to adjust it but doesn't seem to work) the current version works perfect on the Nexus Player!!! just ditched plex for this!!!! 5.1 sound works perfect as well!! 1
