Jasin 11 Posted November 18, 2014 Posted November 18, 2014 OK, still having issues with playback via Chromecast - pauses/plays every minute or so. Playback is fine via Roku app on my Now TV. I'll supply logs when I can, but I haven't found anything untoward in them so far. . I was having same issue. Thought it was the file I was playing last night.
CBers 7554 Posted November 18, 2014 Posted November 18, 2014 I'll supply logs when I can, but I haven't found anything untoward in them so far. . This log contains an 'Error sending data' error message: https://docs.google.com/file/d/0B9FtGLztFm-gaGVPZ0tkcWFXRk0/edit?usp=docslist_api
TheShanMan 41 Posted November 18, 2014 Posted November 18, 2014 I was wondering why there isn't any sorting or filtering in the app so I searched this thread and found the answer - swipe the panel from the right. There is absolutely no visual indication that such a panel exists. As much as I love this app and hate to be critical, it's really a poor user experience. Now that I know what to do, I'm good, but PLEASE consider redesigning this so other users aren't in the dark like I was. Most people probably won't come here looking for the answer.
CBers 7554 Posted November 18, 2014 Posted November 18, 2014 (edited) Now just need to check all is working again. . OK, still having issues with playback via Chromecast - pauses/plays every minute or so. Playback is fine via Roku app on my Now TV. I'll supply logs when I can, but I haven't found anything untoward in them so far. . Edited November 17, 2014 by CBers
Tranquil 95 Posted November 18, 2014 Posted November 18, 2014 Hello Forum, hello Devs. Today I noticed, that when I resume a movie, the correct position is played but the wrong position is marked in the timebar below the movie. It simply starts at 0:00 even if I resume at 29:00.
Redshirt 1487 Posted November 18, 2014 Author Posted November 18, 2014 Hello Forum, hello Devs. Today I noticed, that when I resume a movie, the correct position is played but the wrong position is marked in the timebar below the movie. It simply starts at 0:00 even if I resume at 29:00. Do you have hls enabled or disabled in the apps settings?
Tranquil 95 Posted November 18, 2014 Posted November 18, 2014 Hls is disabled as it doesn't work since some weeks.
iam4uk 26 Posted November 20, 2014 Posted November 20, 2014 On Android phone with on-screen nav icons (for example, HTC One M8), is there a way to play full screen in the Media Browser app?
James Nally 16 Posted November 22, 2014 Posted November 22, 2014 Cm12 on lg g2 is handling hls so far. As stable as ever.
Sp3kt3r 13 Posted November 22, 2014 Posted November 22, 2014 (edited) Hi I would like to know if I'm the only one with this problem. When I play something from my phone with the android app and Chromecast. If I stop the video at any time higher than 10% watched (approximately) the apps set the video to "played" and it's removed from my resume list or home page and it has a check mark for watched. Thx Edited November 22, 2014 by Sp3kt3r
James Nally 16 Posted November 22, 2014 Posted November 22, 2014 I think you can setup this on the server side.
Tranquil 95 Posted November 22, 2014 Posted November 22, 2014 Is this happening on a recently added movie? I got the same issue on new added movies where the playtime of the movie was not calculated yet by the mbs.
Sp3kt3r 13 Posted November 22, 2014 Posted November 22, 2014 I think you can setup this on the server side.I don't have this issue when playing from any other device (web client or xbmb3c)
Redshirt 1487 Posted November 22, 2014 Author Posted November 22, 2014 Does the same thing happen if you use the web client to control the CC?
James Nally 16 Posted November 23, 2014 Posted November 23, 2014 Got update today anything big this time?
James Nally 16 Posted November 23, 2014 Posted November 23, 2014 Does the same thing happen if you use the web client to control the CC?Looks more material.Got update today anything big this time?
blade005 185 Posted November 23, 2014 Posted November 23, 2014 Redshirt, Version 2.1.03 Something is amiss with RESUME items tab in latest version. It looks like it just grabbed 20 items and threw them in the tab. Even weirder is it is 20 items that I watched and deleted from my library. RESUME is showing properly in WebUI.
Redshirt 1487 Posted November 24, 2014 Author Posted November 24, 2014 (edited) I haven't seen that. Is it happening every time? Does it happen if you clear data on the device? Edited November 24, 2014 by Redshirt
Redshirt 1487 Posted November 24, 2014 Author Posted November 24, 2014 Just published version 2.1.0.4 which fixes a last minute audio bug that was reported. This version also adds several translations into the mix. The Android client now has localized text for: Norwegian Bokmål Spanish (Mexico) Finnish French Swedish Chinese Simplified Russian Kazakh German Portuguese (Brazil) A big thank you to the community members who are taking the time to do what must be a boring task. And a big sorry because I'll be adding a bunch more text in the coming weeks 1
James Nally 16 Posted November 24, 2014 Posted November 24, 2014 Just published version 2.1.0.4 which fixes a last minute audio bug that was reported. This version also adds several translations into the mix. The Android client now has localized text for: Norwegian Bokmål Spanish (Mexico) Finnish French Swedish Chinese Simplified Russian Kazakh German Portuguese (Brazil) A big thank you to the community members who are taking the time to do what must be a boring task. And a big sorry because I'll be adding a bunch more text in the coming weeks Thanks for the continued support. As for multiplatform media server software I think mb has it licked.
blade005 185 Posted November 24, 2014 Posted November 24, 2014 I haven't seen that. Is it happening every time? Does it happen if you clear data on the device? Happening every time. Just went into APPS and cleared data, logged back in and the same. 20 items in RESUME and all items that have been watched and deleted from the library. Strange, because the WebUI is showing the correct items in RESUME, which for me at the moment are two items.
Redshirt 1487 Posted November 24, 2014 Author Posted November 24, 2014 I figured clearing the data would eliminate the possibility of it being a caching issue. With the data gone it seems that info is coming from the server, which may indicate something wrong with the request. Can you post the client log.
blade005 185 Posted November 24, 2014 Posted November 24, 2014 I figured clearing the data would eliminate the possibility of it being a caching issue. With the data gone it seems that info is coming from the server, which may indicate something wrong with the request. Can you post the client log. Not a problem. Here you go. http://paste2.org/2dZINEXt
Redshirt 1487 Posted November 24, 2014 Author Posted November 24, 2014 ok. I think I know what might be happening. Two questions. Are the two items that are resumable included in the 20 items you get? Also, if you start to watch something else, via any client and then launch the Android client is that item included in that list. The list is sorted by sort name, so you'll need to try with media that's alphabetically closer to A than the last item in that 20.
blade005 185 Posted November 24, 2014 Posted November 24, 2014 ok. I think I know what might be happening. Two questions. Are the two items that are resumable included in the 20 items you get? Also, if you start to watch something else, via any client and then launch the Android client is that item included in that list. The list is sorted by sort name, so you'll need to try with media that's alphabetically closer to A than the last item in that 20. Redshirt, Responses to your two questions below. 1. No. The two items actually in my resume queue are NOT included. 2. Started a show that begins with A and got to a resume point. The item does not show up in the resume tab. It is still populate with the same 20 items.
