Luke 42242 Posted October 6, 2014 Posted October 6, 2014 The app looks great. At first attempt,however, I'm having an issue with AC3 5.1 audio when chromecasting a TV show. It works fine when played through my 2 channel TV speakers, but I seem to lose the dialog (center channel?) when listening though my stereo. The only thing that changed since it worked earlier this evening was the upgrade to the new android client. Is this a known issue, or can I provide more details to help debug? Thanks! You can file this in the server area. You should see the same behavior from the web client if this is true. CC playback is controlled by the app hosted on the receiver, not the android app.
Redshirt 1487 Posted October 6, 2014 Author Posted October 6, 2014 I can't get it to direct play . I have a low powererd ARM server all my files are x264 and 2 ch AAC. I tried with HLS or without and there is always a transcode going on so I cannot listen to any movies.. Only if I use an external player everything is fine.. except that I loose seek position. Any ideas on how I could enable direct play with the android client if the codecs are supported ? Thanks is the h264 profile baseline?
cskyrme 0 Posted October 6, 2014 Posted October 6, 2014 (edited) You can file this in the server area. You should see the same behavior from the web client if this is true. CC playback is controlled by the app hosted on the receiver, not the android app. Thanks for the prompt reply, Luke. I figured it was a related to the android app as my Chromecast version only started showing up as 2.0.000 on the web client dashboard (as opposed to 1.0.7 i think) when I upgraded the android app on my tablet. I haven't been able to confirm that the behavior is the same when casting from the web client, but will try to replicate that tomorrow. Edited October 6, 2014 by cskyrme
Redshirt 1487 Posted October 6, 2014 Author Posted October 6, 2014 One problem I am having with the new release is with subtitles I get subtitles even if none is selected when streaming to my Samsung TV What are your subtitle preferences set to in the server?
Glyde62 50 Posted October 6, 2014 Posted October 6, 2014 Where do I check that? Another problem now, files that were laughing before, Now I get message file type not supported Sent from the secret room in the back of your closet
Redshirt 1487 Posted October 6, 2014 Author Posted October 6, 2014 click your icon in the top right of web dashboard and select my preferences. Subtitle settings are there.
randomizer 2 Posted October 6, 2014 Posted October 6, 2014 The new version still doesn't like my Nexus 5. It's still locking up regularly (often more than once per minute), although unlike the old version it seems to recover after I get prompted to kill it. I've only managed to get a movie and TV show started a few times since it takes upwards of 10s to load the page for movies and TV shows and another 10s before the server starts transcoding. Music doesn't play at all because the server never starts transcoding, and the player just stops responding. I'll have to get some logs of course otherwise this is all just waffle.
iam4uk 26 Posted October 6, 2014 Posted October 6, 2014 If a user profile is hidden from login screens, when selecting that user manually, the login fails. Happens whether password protected or not. Unhide user in server, and the user can then be accessed in new android client. Please restore the ability to manually login to hidden user profiles.
Redshirt 1487 Posted October 6, 2014 Author Posted October 6, 2014 If a user profile is hidden from login screens, when selecting that user manually, the login fails. Happens whether password protected or not. Unhide user in server, and the user can then be accessed in new android client. Please restore the ability to manually login to hidden user profiles. Fixed for next release. 1
Glyde62 50 Posted October 6, 2014 Posted October 6, 2014 (edited) Something is definitely going on with seeking/resume. We're looking into it. I don't believe it's android specific.Yeah, Was working initially for me, But has stopped working now for some reason One more thing, Still no saving of default short order? Edited October 6, 2014 by Glyde62
bluemonkey07 590 Posted October 6, 2014 Posted October 6, 2014 In the tunein plugin the labels are white on white hense unreadable
speechles 2062 Posted October 6, 2014 Posted October 6, 2014 Found another issue, with books. In portrait it looks pushed off screen. Also, nice effect with the lock screen. Sent from my Nexus 7 using Tapatalk
bluemonkey07 590 Posted October 6, 2014 Posted October 6, 2014 Just an observation... I don't know if having the user logout right above the home button is great idea for a touch screen mobile device especially with no confirmation dialog
Redshirt 1487 Posted October 6, 2014 Author Posted October 6, 2014 Found another issue, with books. In portrait it looks pushed off screen. Fixed. It'll be in tomorrows update.
Redshirt 1487 Posted October 6, 2014 Author Posted October 6, 2014 Just an observation... I don't know if having the user logout right above the home button is great idea for a touch screen mobile device especially with no confirmation dialog I can increase the space between the user image and home image, but I don't think it's that bad as is.
TonkaTuff 10 Posted October 6, 2014 Posted October 6, 2014 Hi Redshirt. I've got a problem since updating the app. The app freezes at the "Select a Media Browser Server" page immediately after launching. Log Excerpt (full log coming via PM): [Mon Oct 06 19:44:36 CEST 2014] , Error , Error loading last connected server. com.mb.android.utils.FileUtils.LoadSavedSessionInfo(FileUtils.java:69) com.mb.android.ui.mobile.main.MainActivity.loadOrCreateSavedSessionInfo(MainActivity.java:112) com.mb.android.ui.mobile.main.MainActivity.onCreate(MainActivity.java:75) android.app.Activity.performCreate(Activity.java:5086) android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1079) Thanks for your hlep 1
Redshirt 1487 Posted October 6, 2014 Author Posted October 6, 2014 Does it actually freeze, or is it just not doing anything. Looking at the PM'd log it appears to survive the errors and carry on. If you click the icon beside the text you should be able to add your connection info. 1
jordy 284 Posted October 6, 2014 Posted October 6, 2014 Hey Red, Just updated my sg3 and it looks great. seems to function quite well and at the moment plays my MKVs beautifully with HLS on. Very happy. One question, when trying ti use play to, if I load MB Android before I start the target app - say MBT on my laptop, MBA does not see it as a play to device. There appears to be no way to refresh the available play to devices other than completely shutting MBA down - removing it from the phones list of "in use" apps and then re-starting the app. Any way of getting MBA to keep polling the server for new devices - seeing as the server picks up new connections pretty much instantly, as they become available or to do a manual refresh?
TonkaTuff 10 Posted October 6, 2014 Posted October 6, 2014 LOL, don't I feel like an idiot! That's fixed it. I was tapping on the text, not the icon next to the text. Thanks
Redshirt 1487 Posted October 6, 2014 Author Posted October 6, 2014 LOL, don't I feel like an idiot! That's fixed it. I was tapping on the text, not the icon next to the text. Thanks Lol, it's still a valid point. That should look more like a button.
Redshirt 1487 Posted October 6, 2014 Author Posted October 6, 2014 (edited) Hey Red, Just updated my sg3 and it looks great. seems to function quite well and at the moment plays my MKVs beautifully with HLS on. Very happy. One question, when trying ti use play to, if I load MB Android before I start the target app - say MBT on my laptop, MBA does not see it as a play to device. There appears to be no way to refresh the available play to devices other than completely shutting MBA down - removing it from the phones list of "in use" apps and then re-starting the app. Any way of getting MBA to keep polling the server for new devices - seeing as the server picks up new connections pretty much instantly, as they become available or to do a manual refresh? I'll see what I can do. I'm seeing it too. Edited October 6, 2014 by Redshirt 1
inkubux 7 Posted October 6, 2014 Posted October 6, 2014 I can't get it to direct play . I have a low powererd ARM server all my files are x264 and 2 ch AAC. I tried with HLS or without and there is always a transcode going on so I cannot listen to any movies.. Only if I use an external player everything is fine.. except that I loose seek position. Any ideas on how I could enable direct play with the android client if the codecs are supported ? Thanks is the h264 profile baseline? I donn know what baseline is sorry ;( But this is a typical movie probe information : ffprobe 'Robots (2005).m4v' ffprobe version N-66454-ge113692 Copyright (c) 2007-2014 the FFmpeg developers built on Sep 25 2014 15:09:26 with gcc 4.6 (Debian 4.6.3-14) configuration: --enable-gpl --enable-nonfree --enable-libfaac --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-postproc --enable-swscale --enable-pthreads --enable-version3 --enable-postproc --enable-runtime-cpudetect --enable-libtheora --enable-gray --enable-libass --enable-libfreetype --enable-libopenjpeg --enable-libspeex --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvpx libavutil 54. 7.101 / 54. 7.101 libavcodec 56. 1.101 / 56. 1.101 libavformat 56. 5.100 / 56. 5.100 libavdevice 56. 1.100 / 56. 1.100 libavfilter 5. 1.102 / 5. 1.102 libswscale 3. 1.100 / 3. 1.100 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 1.100 / 53. 1.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Robots (2005).m4v': Metadata: major_brand : isom minor_version : 512 compatible_brands: isomiso2avc1mp41 encoder : Lavf55.12.100 Duration: 01:23:39.58, start: 0.061000, bitrate: 3299 kb/s Chapter #0.0: start 0.000000, end 123.540000 Metadata: title : 00:00:00.000 Chapter #0.1: start 123.540000, end 264.139000 Metadata: title : 00:02:03.540 Chapter #0.2: start 264.139000, end 437.312000 Metadata: title : 00:04:24.139 Chapter #0.3: start 437.312000, end 650.984000 Metadata: title : 00:07:17.312 Chapter #0.4: start 650.984000, end 814.397000 Metadata: title : 00:10:50.984 Chapter #0.5: start 814.397000, end 952.827000 Metadata: title : 00:13:34.397 Chapter #0.6: start 952.827000, end 1144.894000 Metadata: title : 00:15:52.827 Chapter #0.7: start 1144.894000, end 1362.611000 Metadata: title : 00:19:04.894 Chapter #0.8: start 1362.611000, end 1484.191000 Metadata: title : 00:22:42.611 Chapter #0.9: start 1484.191000, end 1604.394000 Metadata: title : 00:24:44.191 Chapter #0.10: start 1604.394000, end 1764.513000 Metadata: title : 00:26:44.394 Chapter #0.11: start 1764.513000, end 1983.773000 Metadata: title : 00:29:24.513 Chapter #0.12: start 1983.773000, end 2098.346000 Metadata: title : 00:33:03.773 Chapter #0.13: start 2098.346000, end 2196.444000 Metadata: title : 00:34:58.346 Chapter #0.14: start 2196.444000, end 2463.336000 Metadata: title : 00:36:36.444 Chapter #0.15: start 2463.336000, end 2755.044000 Metadata: title : 00:41:03.336 Chapter #0.16: start 2755.044000, end 2993.199000 Metadata: title : 00:45:55.044 Chapter #0.17: start 2993.199000, end 3222.344000 Metadata: title : 00:49:53.199 Chapter #0.18: start 3222.344000, end 3549.004000 Metadata: title : 00:53:42.344 Chapter #0.19: start 3549.004000, end 3662.993000 Metadata: title : 00:59:09.004 Chapter #0.20: start 3662.993000, end 3879.876000 Metadata: title : 01:01:02.993 Chapter #0.21: start 3879.876000, end 4014.761000 Metadata: title : 01:04:39.876 Chapter #0.22: start 4014.761000, end 4344.632000 Metadata: title : 01:06:54.761 Chapter #0.23: start 4344.632000, end 4572.902000 Metadata: title : 01:12:24.632 Chapter #0.24: start 4572.902000, end 4740.235000 Metadata: title : 01:16:12.902 Chapter #0.25: start 4740.235000, end 4884.213000 Metadata: title : 01:19:00.235 Chapter #0.26: start 4884.213000, end 5019.642000 Metadata: title : 01:21:24.213 Stream #0:0(fra): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1280x696 [SAR 1:1 DAR 160:87], 2970 kb/s, 23.98 fps, 23.98 tbr, 16k tbn, 47.95 tbc (default) Metadata: handler_name : VideoHandler Stream #0:1(fra): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 321 kb/s (default) Metadata: handler_name : SoundHandler and this is a part of the transcoding log in HLS: usr/local/bin/ffmpeg -fflags +genpts -i file:"/mnt/Media/Movies/Movies/m4v/Robots (2005).m4v" -map_metadata -1 -threads 2 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -preset superfast -crf 23 -maxrate 2970341 -bufsize 5940682 -vsync vfr -profile:v baseline -level 41 -force_key_frames expr:gte(t,n_forced*6) -vf "scale=trunc(min(iw\,1920)/2)*2:trunc(min((iw/dar)\,1080)/2)*2" -copyts -flags -global_header -codec:a:0 aac -strict experimental -ac 2 -ab 128000 -af "adelay=1,aresample=async=1" -hls_time 6 -start_number 0 -hls_list_size 1440 -y "/opt/mbserver/ProgramData-Server/transcoding-temp/cddee7ec60b1051bf74b62a7b6dae3cb.m3u8" ffmpeg version N-66454-ge113692 Copyright (c) 2000-2014 the FFmpeg developers built on Sep 25 2014 15:09:26 with gcc 4.6 (Debian 4.6.3-14) configuration: --enable-gpl --enable-nonfree --enable-libfaac --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-postproc --enable-swscale --enable-pthreads --enable-version3 --enable-postproc --enable-runtime-cpudetect --enable-libtheora --enable-gray --enable-libass --enable-libfreetype --enable-libopenjpeg --enable-libspeex --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvpx libavutil 54. 7.101 / 54. 7.101 libavcodec 56. 1.101 / 56. 1.101 libavformat 56. 5.100 / 56. 5.100 libavdevice 56. 1.100 / 56. 1.100 libavfilter 5. 1.102 / 5. 1.102 libswscale 3. 1.100 / 3. 1.100 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 1.100 / 53. 1.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'file:/mnt/Media/Movies/Movies/m4v/Robots (2005).m4v': Thanks for your help
blade005 185 Posted October 6, 2014 Posted October 6, 2014 Redshirt, Nice to see DELETE functionality in Android app now. It will be quite useful when watching Recorded TV that can be deleted after viewing. However, the non-descriptive X on the screen may be confusing. Are you closing the screen or deleting a file? A prompt that asks if you are sure you want to DELETE the file would be useful. Found that out the hard way while testing it out. Great job.
bluemonkey07 590 Posted October 6, 2014 Posted October 6, 2014 Ditto., still issues with subtitles, seeking and remote control
