thefirstofthe300 292 Posted August 21, 2014 Posted August 21, 2014 And another person wanting to test the beta...........
rikiwi 32 Posted August 21, 2014 Posted August 21, 2014 App has been locking up for last 2 days. I can open and watch Live & recorded TV, but as soon as I try to open my TV Shows folder app locks and the only way fix things is to clear cache and data.
Glyde62 50 Posted August 21, 2014 Posted August 21, 2014 Seems to lock up when opening certain folders,Folders with movies seem ok,tv or mixed folders freeze Sent from the secret room in the back of your closet
Redshirt 1487 Posted August 21, 2014 Author Posted August 21, 2014 I'd like to see a client log for one of these lockups. They are in \Sdcard\MB3AndroidData\Logs.
cskyrme 0 Posted August 21, 2014 Posted August 21, 2014 I am seeing the same behavior as well. I'm on server build:Version 3.0.5346.22797 It was fine before I upgraded the server just now to this beta build.
rikiwi 32 Posted August 21, 2014 Posted August 21, 2014 Here's a client log. I cleaned out all previous logs then opened app, played a recorded TV for a minute, then tried to open my TV Shows folder - total lock-up. [Fri Aug 22 09:13:45 GMT+12:00 2014] , Info , Application Version: 1.0.45 , 1 , main [Fri Aug 22 09:13:45 GMT+12:00 2014] , Info , Device: Nexus 7 , 1 , main [Fri Aug 22 09:13:45 GMT+12:00 2014] , Info , Screen Width: 1280 , 1 , main [Fri Aug 22 09:13:45 GMT+12:00 2014] , Info , Screen Height: 736 , 1 , main [Fri Aug 22 09:13:45 GMT+12:00 2014] , Info , Total Memory Available: 264 MB , 1 , main [Fri Aug 22 09:13:45 GMT+12:00 2014] , Info , Max Memory usable per Application: 64 MB , 1 , main [Fri Aug 22 09:13:45 GMT+12:00 2014] , Info , Application object initialized , 1 , main [Fri Aug 22 09:13:45 GMT+12:00 2014] , Info , Logger Started , 1 , main [Fri Aug 22 09:13:45 GMT+12:00 2014] , Info , Initializing FileUtils helper class , 1 , main [Fri Aug 22 09:13:45 GMT+12:00 2014] , Info , Searching for UDP servers , 1 , main [Fri Aug 22 09:13:46 GMT+12:00 2014] , Info , Finished searching for UDP servers , 1885 , Thread-1885 [Fri Aug 22 09:13:46 GMT+12:00 2014] , Info , Show server selection list , 1885 , Thread-1885 [Fri Aug 22 09:13:46 GMT+12:00 2014] , Info , ServerSelectionFragment: onCreateView , 1 , main [Fri Aug 22 09:13:46 GMT+12:00 2014] , Info , ServerSelectionFragment: populateServerList , 1 , main [Fri Aug 22 09:13:46 GMT+12:00 2014] , Info , Fragment ServerInfo callback , 1 , main [Fri Aug 22 09:13:48 GMT+12:00 2014] , Info , Server Matched , 1 , main [Fri Aug 22 09:13:48 GMT+12:00 2014] , Info , Saving server list , 1 , main [Fri Aug 22 09:13:48 GMT+12:00 2014] , Info , Saving last connected to app directory , 1 , main [Fri Aug 22 09:13:48 GMT+12:00 2014] , Info , GetAllUsersCallback , 1 , main [Fri Aug 22 09:13:48 GMT+12:00 2014] , Info , 1 user(s) received , 1 , main [Fri Aug 22 09:13:48 GMT+12:00 2014] , Info , mUserInfo is null or empty , 1 , main [Fri Aug 22 09:13:48 GMT+12:00 2014] , Info , User Selection Fragment: onCreateView , 1 , main [Fri Aug 22 09:13:48 GMT+12:00 2014] , Info , User Selection Fragment: User available, initializing view , 1 , main [Fri Aug 22 09:13:50 GMT+12:00 2014] , Info , User Login Activity: Stay signed in changed for user 0 , 1 , main [Fri Aug 22 09:13:50 GMT+12:00 2014] , Info , d484e7599f7a5e38eb5e8dfb28ae27a4 is default user , 1 , main [Fri Aug 22 09:13:50 GMT+12:00 2014] , Info , User Login Activity: Stay signed in changed for user 0 , 1 , main [Fri Aug 22 09:13:50 GMT+12:00 2014] , Info , d484e7599f7a5e38eb5e8dfb28ae27a4 is default user , 1 , main [Fri Aug 22 09:13:51 GMT+12:00 2014] , Info , User Login Activity: User 0 clicked. , 1 , main [Fri Aug 22 09:13:51 GMT+12:00 2014] , Info , User Login Activity: User doesn't have a password , 1 , main [Fri Aug 22 09:13:51 GMT+12:00 2014] , Info , Attempting Authentication , 1 , main [Fri Aug 22 09:13:51 GMT+12:00 2014] , Info , AuthenticateUserCallback , 1 , main [Fri Aug 22 09:13:51 GMT+12:00 2014] , Info , Data received , 1 , main [Fri Aug 22 09:13:51 GMT+12:00 2014] , Info , HTTP RESPONSE 200 , 1 , main [Fri Aug 22 09:13:51 GMT+12:00 2014] , Info , userInfo saved , 1 , main [Fri Aug 22 09:13:51 GMT+12:00 2014] , Info , Id: d484e7599f7a5e38eb5e8dfb28ae27a4 , 1 , main [Fri Aug 22 09:13:51 GMT+12:00 2014] , Info , Password: da39a3ee5e6b4b0d3255bfef95601890afd80709 , 1 , main [Fri Aug 22 09:13:51 GMT+12:00 2014] , Info , Call Homescreen Activity , 1 , main [Fri Aug 22 09:13:51 GMT+12:00 2014] , Info , HomeScreen Activity: onCreate , 1 , main [Fri Aug 22 09:13:51 GMT+12:00 2014] , Info , HomeScreen Activity: onStart , 1 , main [Fri Aug 22 09:13:51 GMT+12:00 2014] , Info , HomeScreen Activity: onResume , 1 , main [Fri Aug 22 09:13:52 GMT+12:00 2014] , Info , Initializing WebSocket , 1 , main [Fri Aug 22 09:13:52 GMT+12:00 2014] , Info , WebSocket: Connect , 1 , main [Fri Aug 22 09:13:52 GMT+12:00 2014] , Info , WebSocket: Successfully Connected , 1893 , Thread-1893 [Fri Aug 22 09:13:52 GMT+12:00 2014] , Info , NewItemsFragment: GetNewItems callback , 1 , main [Fri Aug 22 09:13:52 GMT+12:00 2014] , Info , Result not equal to null: Item count is 1 , 1 , main [Fri Aug 22 09:13:52 GMT+12:00 2014] , Info , NewItemsFragment: GetNewItems callback , 1 , main [Fri Aug 22 09:13:52 GMT+12:00 2014] , Info , NewItemsFragment - GetNewItems: Items received. , 1 , main [Fri Aug 22 09:13:54 GMT+12:00 2014] , Info , HomeScreen Activity: onPause , 1 , main [Fri Aug 22 09:13:54 GMT+12:00 2014] , Info , Loading last connected server from app directory , 1 , main [Fri Aug 22 09:13:55 GMT+12:00 2014] , Info , HomeScreen Activity: onStop , 1 , main [Fri Aug 22 09:13:59 GMT+12:00 2014] , Info , onSharedPreferenceChanged , 1 , main [Fri Aug 22 09:13:59 GMT+12:00 2014] , Info , key = pref_home_default_tab , 1 , main [Fri Aug 22 09:14:05 GMT+12:00 2014] , Info , onSharedPreferenceChanged , 1 , main [Fri Aug 22 09:14:05 GMT+12:00 2014] , Info , key = pref_play_theme , 1 , main [Fri Aug 22 09:14:07 GMT+12:00 2014] , Info , onSharedPreferenceChanged , 1 , main [Fri Aug 22 09:14:07 GMT+12:00 2014] , Info , key = pref_enable_hls , 1 , main [Fri Aug 22 09:14:11 GMT+12:00 2014] , Info , onSharedPreferenceChanged , 1 , main [Fri Aug 22 09:14:11 GMT+12:00 2014] , Info , key = pref_local_bitrate , 1 , main [Fri Aug 22 09:14:15 GMT+12:00 2014] , Info , HomeScreen Activity: onRestart , 1 , main [Fri Aug 22 09:14:15 GMT+12:00 2014] , Info , HomeScreen Activity: onStart , 1 , main [Fri Aug 22 09:14:15 GMT+12:00 2014] , Info , HomeScreen Activity: onResume , 1 , main [Fri Aug 22 09:14:15 GMT+12:00 2014] , Info , Initializing WebSocket , 1 , main [Fri Aug 22 09:14:15 GMT+12:00 2014] , Info , WebSocket: Connect , 1 , main [Fri Aug 22 09:14:15 GMT+12:00 2014] , Info , WebSocket: Successfully Connected , 1896 , Thread-1896 [Fri Aug 22 09:14:17 GMT+12:00 2014] , Info , HomeScreen Activity: onPause , 1 , main [Fri Aug 22 09:14:17 GMT+12:00 2014] , Info , HomeScreen Activity: onStop , 1 , main [Fri Aug 22 09:14:17 GMT+12:00 2014] , Info , BaseMB3ProfileActivity: OnDestroy , 1 , main [Fri Aug 22 09:14:17 GMT+12:00 2014] , Info , HomeScreen Activity: onDestroy , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , Logger Started , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , Initializing FileUtils helper class , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , Loading server list from app directory , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , Loading last connected server from app directory , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , Main Activity ServerInfo callback , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , Saving server list , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , Saving last connected to app directory , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , ServerConfiguration callback , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , ServerConfiguration successfully received , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , GetAllUsersCallback , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , 1 user(s) received , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , mUserInfo != null , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , mUserInfo matches , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , Attempting Authentication , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , AuthenticateUserCallback , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , Data received , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , HTTP RESPONSE 200 , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , userInfo saved , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , Id: d484e7599f7a5e38eb5e8dfb28ae27a4 , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , Password: da39a3ee5e6b4b0d3255bfef95601890afd80709 , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , Call Homescreen Activity , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , HomeScreen Activity: onCreate , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , HomeScreen Activity: onStart , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , HomeScreen Activity: onResume , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , Initializing WebSocket , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , WebSocket: Connect , 1 , main [Fri Aug 22 09:15:38 GMT+12:00 2014] , Info , WebSocket: Successfully Connected , 1899 , Thread-1899 [Fri Aug 22 09:15:45 GMT+12:00 2014] , Info , HomeScreen Activity: onPause , 1 , main [Fri Aug 22 09:15:45 GMT+12:00 2014] , Info , Library Presentation Activity: onCreate , 1 , main [Fri Aug 22 09:15:45 GMT+12:00 2014] , Info , Library Presentation Fragment: onCreate , 1 , main [Fri Aug 22 09:15:45 GMT+12:00 2014] , Info , Library Presentation Fragment: onCreateView , 1 , main [Fri Aug 22 09:15:45 GMT+12:00 2014] , Info , Library Presentation Fragment: Requesting Items , 1 , main [Fri Aug 22 09:15:46 GMT+12:00 2014] , Info , ratings returned: 10 , 1 , main [Fri Aug 22 09:15:46 GMT+12:00 2014] , Info , Library Presentation Fragment: Get Items Callback , 1 , main [Fri Aug 22 09:15:46 GMT+12:00 2014] , Info , Library Presentation Fragment - Get Items Callback: 8 Items to process , 1 , main [Fri Aug 22 09:15:46 GMT+12:00 2014] , Info , Library Presentation Fragment - Get Items Callback: Total Record Count = 8 , 1 , main [Fri Aug 22 09:15:46 GMT+12:00 2014] , Info , Library Presentation Fragment: Populating Library View , 1 , main [Fri Aug 22 09:15:46 GMT+12:00 2014] , Info , Library Presentation Fragment: 8 items to show , 1 , main [Fri Aug 22 09:15:46 GMT+12:00 2014] , Info , HomeScreen Activity: onStop , 1 , main [Fri Aug 22 09:15:51 GMT+12:00 2014] , Info , Library Presentation Fragment: Position Clicked 0 , 1 , main [Fri Aug 22 09:15:51 GMT+12:00 2014] , Info , Library Presentation Fragment: Item is media , 1 , main [Fri Aug 22 09:15:51 GMT+12:00 2014] , Info , Calling StartActivity , 1 , main [Fri Aug 22 09:15:51 GMT+12:00 2014] , Info , Media Details Activity: onCreate , 1 , main [Fri Aug 22 09:15:51 GMT+12:00 2014] , Info , Media Details Activity: onStart , 1 , main [Fri Aug 22 09:15:51 GMT+12:00 2014] , Info , Media Details Activity: onResume , 1 , main [Fri Aug 22 09:15:51 GMT+12:00 2014] , Info , MediaDetailsActivity: GetItemCallback , 1 , main [Fri Aug 22 09:15:51 GMT+12:00 2014] , Info , Update favorite visible icons , 1 , main [Fri Aug 22 09:15:51 GMT+12:00 2014] , Info , Show add favorite , 1 , main [Fri Aug 22 09:15:51 GMT+12:00 2014] , Info , Update playstate visible icons , 1 , main [Fri Aug 22 09:15:51 GMT+12:00 2014] , Info , MediaDetailsActivity: GetInitialItemCallback - Performing Phone Layout , 1 , main [Fri Aug 22 09:15:51 GMT+12:00 2014] , Info , SetMediaInfoIcons A/R width: 16 , 1 , main [Fri Aug 22 09:15:51 GMT+12:00 2014] , Info , SetMediaInfoIcons A/R height: 9 , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Media Details Activity: onPause , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Playback Activity: onCreate , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , PlaybackActivity: MediaButtonReceiver Registered , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Playback Activity: onResume , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Playback Activity: surfaceCreated , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Playback Activity: surfaceChanged , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Media Details Activity: onStop , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Playback Activity: SetNowPlayingInfo , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , calculateScaledVideoDimensions , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Screen Width: 1280 , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Screen Height: 800 , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Reported Video Width: 1920 , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Reported Video Height: 1080 , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , A/R width: 16 , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , A/R height: 9 , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Scaling based on screen width , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Video scaled to: 1280x720 , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Processing stream: 0 , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Stream Type: Subtitle , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Processing stream: 1 , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Stream Type: Video , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Setting Video stream , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Processing stream: 2 , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Stream Type: Audio , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Setting Audio stream , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Processing stream: 3 , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Stream Type: Audio , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Processing stream: 4 , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Stream Type: null , 1 , main [Fri Aug 22 09:15:54 GMT+12:00 2014] , Info , Playback Url: http://10.1.1.99:8096/mediabrowser/Videos/8e2225d4830cce5dfcc6188b74e9ee19/stream.Ts?MaxWidth=1280&audioCodec=Aac&level=3&VideoBitRate=2872000&VideoCodec=H264&MaxHeight=720&audiochannels=2&AudioBitRate=128000&profile=baseline , 1 , main [Fri Aug 22 09:16:01 GMT+12:00 2014] , Info , Playback Activity: onPrepared , 1 , main [Fri Aug 22 09:16:01 GMT+12:00 2014] , Info , SetSurfaceDimensions: 1280x720 , 1 , main [Fri Aug 22 09:16:01 GMT+12:00 2014] , Info , Playback Activity: surfaceChanged , 1 , main [Fri Aug 22 09:16:18 GMT+12:00 2014] , Info , Playback Activity: onPause , 1 , main [Fri Aug 22 09:16:18 GMT+12:00 2014] , Info , Playback Activity: onPause , 1 , main [Fri Aug 22 09:16:18 GMT+12:00 2014] , Info , PlaybackActivity: MediaButtonReceiver Unregistered , 1 , main [Fri Aug 22 09:16:18 GMT+12:00 2014] , Info , Media Details Activity: onStart , 1 , main [Fri Aug 22 09:16:18 GMT+12:00 2014] , Info , Media Details Activity: onResume , 1 , main [Fri Aug 22 09:16:18 GMT+12:00 2014] , Info , Initializing WebSocket , 1 , main [Fri Aug 22 09:16:18 GMT+12:00 2014] , Info , WebSocket: Connect , 1 , main [Fri Aug 22 09:16:18 GMT+12:00 2014] , Info , Playback Activity: surfaceDestroyed , 1 , main [Fri Aug 22 09:16:18 GMT+12:00 2014] , Info , WebSocket: Successfully Connected , 1902 , Thread-1902 [Fri Aug 22 09:16:19 GMT+12:00 2014] , Info , Playback Activity: onStop , 1 , main [Fri Aug 22 09:16:19 GMT+12:00 2014] , Info , Playback Activity: onStop , 1 , main [Fri Aug 22 09:16:19 GMT+12:00 2014] , Info , Playback Activity: onDestroy , 1 , main [Fri Aug 22 09:16:19 GMT+12:00 2014] , Info , Playback Activity: mPlayer.stop called , 1 , main [Fri Aug 22 09:16:19 GMT+12:00 2014] , Info , Async Delete: Sending HTTP Delete to http://10.1.1.99:8096/mediabrowser/Users/d484e7599f7a5e38eb5e8dfb28ae27a4/PlayingItems/8e2225d4830cce5dfcc6188b74e9ee19?positionTicks=163710000 , 1890 , AsyncTask #4 [Fri Aug 22 09:16:19 GMT+12:00 2014] , Info , Playback Activity: mPlayer.release called , 1 , main [Fri Aug 22 09:16:19 GMT+12:00 2014] , Info , Playback Activity: onDestroy , 1 , main [Fri Aug 22 09:16:20 GMT+12:00 2014] , Info , Media Details Activity: onPause , 1 , main [Fri Aug 22 09:16:21 GMT+12:00 2014] , Info , Media Details Activity: onStop , 1 , main [Fri Aug 22 09:16:21 GMT+12:00 2014] , Info , Media Details Activity: onDestroy , 1 , main [Fri Aug 22 09:16:21 GMT+12:00 2014] , Info , BaseMB3ProfileActivity: OnDestroy , 1 , main [Fri Aug 22 09:16:23 GMT+12:00 2014] , Info , HomeScreen Activity: onRestart , 1 , main [Fri Aug 22 09:16:23 GMT+12:00 2014] , Info , HomeScreen Activity: onStart , 1 , main [Fri Aug 22 09:16:23 GMT+12:00 2014] , Info , HomeScreen Activity: onResume , 1 , main [Fri Aug 22 09:16:23 GMT+12:00 2014] , Info , BaseMB3ProfileActivity: OnDestroy , 1 , main [Fri Aug 22 09:16:23 GMT+12:00 2014] , Info , Library Presentation Activity: onDestroy , 1 , main [Fri Aug 22 09:16:26 GMT+12:00 2014] , Info , HomeScreen Activity: onPause , 1 , main [Fri Aug 22 09:16:26 GMT+12:00 2014] , Info , HomeScreen Activity: onStop , 1 , main [Fri Aug 22 09:17:58 GMT+12:00 2014] , Info , HomeScreen Activity: onRestart , 1 , main [Fri Aug 22 09:17:59 GMT+12:00 2014] , Info , HomeScreen Activity: onStart , 1 , main [Fri Aug 22 09:17:59 GMT+12:00 2014] , Info , HomeScreen Activity: onResume , 1 , main [Fri Aug 22 09:17:59 GMT+12:00 2014] , Info , Initializing WebSocket , 1 , main [Fri Aug 22 09:17:59 GMT+12:00 2014] , Info , WebSocket: Connect , 1 , main [Fri Aug 22 09:17:59 GMT+12:00 2014] , Info , WebSocket: Successfully Connected , 1904 , Thread-1904 [Fri Aug 22 09:18:07 GMT+12:00 2014] , Info , HomeScreen Activity: onPause , 1 , main [Fri Aug 22 09:18:07 GMT+12:00 2014] , Info , Library Presentation Activity: onCreate , 1 , main [Fri Aug 22 09:18:07 GMT+12:00 2014] , Info , Library Presentation Fragment: onCreate , 1 , main [Fri Aug 22 09:18:07 GMT+12:00 2014] , Info , Library Presentation Fragment: onCreateView , 1 , main [Fri Aug 22 09:18:07 GMT+12:00 2014] , Info , Library Presentation Fragment: Requesting Items , 1 , main [Fri Aug 22 09:18:07 GMT+12:00 2014] , Info , Library Presentation Fragment: Get Items Callback , 1 , main [Fri Aug 22 09:18:07 GMT+12:00 2014] , Info , Library Presentation Fragment - Get Items Callback: 16 Items to process , 1 , main [Fri Aug 22 09:18:07 GMT+12:00 2014] , Info , Library Presentation Fragment - Get Items Callback: Total Record Count = 16 , 1 , main [Fri Aug 22 09:18:07 GMT+12:00 2014] , Info , Library Presentation Fragment: Populating Library View , 1 , main [Fri Aug 22 09:18:07 GMT+12:00 2014] , Info , Library Presentation Fragment: 16 items to show , 1 , main [Fri Aug 22 09:18:07 GMT+12:00 2014] , Error , Uncaught Exception , 1 , main [Fri Aug 22 09:18:07 GMT+12:00 2014] , Error , Stack Trace: java.lang.NullPointerException at com.mb.android.adapters.MediaAdapterBackdrops.getView(MediaAdapterBackdrops.java:255) at android.widget.AbsListView.obtainView(AbsListView.java:2255) at android.widget.GridView.onMeasure(GridView.java:1044) at android.view.View.measure(View.java:16497) at android.widget.RelativeLayout.measureChildHorizontal(RelativeLayout.java:719) at android.widget.RelativeLayout.onMeasure(RelativeLayout.java:455) at android.view.View.measure(View.java:16497) at android.view.ViewGroup.measureChildWithMargins(ViewGroup.java:5125) at android.widget.FrameLayout.onMeasure(FrameLayout.java:310) at android.view.View.measure(View.java:16497) at android.view.ViewGroup.measureChildWithMargins(ViewGroup.java:5125) at android.widget.FrameLayout.onMeasure(FrameLayout.java:310) at android.view.View.measure(View.java:16497) at android.support.v4.widget.DrawerLayout.onMeasure(DrawerLayout.java:704) at android.view.View.measure(View.java:16497) at android.widget.RelativeLayout.measureChildHorizontal(RelativeLayout.java:719) at android.widget.RelativeLayout.onMeasure(RelativeLayout.java:455) at android.view.View.measure(View.java:16497) at android.view.ViewGroup.measureChildWithMargins(ViewGroup.java:5125) at android.widget.FrameLayout.onMeasure(FrameLayout.java:310) at android.view.View.measure(View.java:16497) at android.view.ViewGroup.measureChildWithMargins(ViewGroup.java:5125) at com.android.internal.widget.ActionBarOverlayLayout.onMeasure(ActionBarOverlayLayout.java:327) at android.view.View.measure(View.java:16497) at android.view.ViewGroup.measureChildWithMargins(ViewGroup.java:5125) at android.widget.FrameLayout.onMeasure(FrameLayout.java:310) at com.android.internal.policy.impl.PhoneWindow$DecorView.onMeasure(PhoneWindow.java:2291) at android.view.View.measure(View.java:16497) at android.view.ViewRootImpl.performMeasure(ViewRootImpl.java:1912) at android.view.ViewRootImpl.measureHierarchy(ViewRootImpl.java:1109) at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:1291) at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:996) at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:5600) at android.view.Choreographer$CallbackRecord.run(Choreographer.java:761) at android.view.Choreographer.doCallbacks(Choreographer.java:574) at android.view.Choreographer.doFrame(Choreographer.java:544) at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:747) at android.os.Handler.handleCallback(Handler.java:733) at android.os.Handler.dispatchMessage(Handler.java:95) at android.os.Looper.loop(Looper.java:136) at android.app.ActivityThread.main(ActivityThread.java:5001) at java.lang.reflect.Method.invokeNative(Native Method) at java.lang.reflect.Method.invoke(Method.java:515) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:785) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:601) at dalvik.system.NativeStart.main(Native Method) , 1 , main
blade005 185 Posted August 22, 2014 Posted August 22, 2014 (edited) I'd like to see a client log for one of these lockups. They are in \Sdcard\MB3AndroidData\Logs. Redshirt, MBS Version: 3.0.5346.22797 Android Client: 1.0.45 I am seeing lockup when trying to enter any media collection folder. MOVIES, TV and MUSIC tabs on main screen and any folders in my LIBRARY section. I can view and play any items that are currently in the NEW, NEXT UP and RESUME section. Issue started in the last few days. Exact same lockup is occurring on both a Nexus 7 Tablet and Moto X phone with Android Client. Attached is client log. http://paste2.org/gJD8bvsm Edited August 21, 2014 by blade005
Redshirt 1487 Posted August 22, 2014 Author Posted August 22, 2014 I know what it is. Its a change in server that the release version of the client isnt able to handle. I'll have to see if that change can be temporarily undone.
rikiwi 32 Posted August 22, 2014 Posted August 22, 2014 Thanks Redshirt - I thought that it must have been a change in the server as the problem started after a recent server update. I'm on Dev. build - Version 3.0.5346.22797
rikiwi 32 Posted August 23, 2014 Posted August 23, 2014 I can confirm (at least on my Nexus 7 2012) that with Server update this morning - Version 3.0.5347.22095 (Dev build), all folders opening and video, photos, etc. all displaying fine. Great work Devs.
thefirstofthe300 292 Posted August 23, 2014 Posted August 23, 2014 It never quit working for me (although I didn't upgrade to 3.0.5437 until just yesterday).
dark_slayer 103 Posted August 23, 2014 Posted August 23, 2014 Hi redshirt, I've been using your app quite a bit recently and noticed what I consider a quirk It would be helpful for me if I had a local and external address fields along with a local and external port Reason for me is that I have a paid VPN tunnel I run on my server, and they allow a bypass port. I can NAT that bypass port to 8096 on the local mb3 servers internal IP. When I use that in combination with my routers DNS service I get flawless playback with only mb3 bypassing my vpn tunnel. The problem is when I come back home to my local network, the app resets the manual port override (that I specify) back to 8096. This works fine locally (with the internal IP or the Asus DNS address) but once I leave home I have to override the port settings back to the one that bypasses my VPN
Redshirt 1487 Posted August 23, 2014 Author Posted August 23, 2014 The ability to set unique internal and external ports is already in the next version. Hopefully the beta process won't be much longer. 1
dark_slayer 103 Posted August 23, 2014 Posted August 23, 2014 Thanks, I'd be glad to join a beta if it's open
heretostay 1 Posted August 28, 2014 Posted August 28, 2014 (edited) Any idea when the newest update will be released? Edited August 28, 2014 by heretostay
CBers 7554 Posted August 28, 2014 Posted August 28, 2014 Any idea when the newest update will be released? It's still going through beta testing.
Luke 42242 Posted September 3, 2014 Posted September 3, 2014 Team, I just want to issue an update because I know a lot of you are waiting patiently for the next android release. We are all working hard on it and apologize that it hasn't gotten out sooner, but it is getting close so just hang tight a little longer. The good news is, it will be almost fully caught up to all of the latest server features, and it is quite honestly almost a whole new application and I know you're going to love it. You can name pretty much any server feature, and chances are the app has it now - live tv, channels, playlists, all of the latest transcoding improvements, particularly in regards to seeking, cpu usage, and text-based subtitles without transcoding. And it is using our new Chromecast receiver that the web client is using, which is going to be great because the new receiver manages itself entirely. You'll get a consistent Chromecast experience no matter which device you launch from, and you can change devices on the fly, from web client to android and vice versa, without disrupting anything that the receiver is doing. So hang tight, we'll have it out for you soon. 10
Ghostm 75 Posted September 3, 2014 Posted September 3, 2014 Team, I just want to issue an update because I know a lot of you are waiting patiently for the next android release. We are all working hard on it and apologize that it hasn't gotten out sooner, but it is getting close so just hang tight a little longer. The good news is, it will be almost fully caught up to all of the latest server features, and it is quite honestly almost a whole new application and I know you're going to love it. You can name pretty much any server feature, and chances are the app has it now - live tv, channels, playlists, all of the latest transcoding improvements, particularly in regards to seeking, cpu usage, and text-based subtitles without transcoding. And it is using our new Chromecast receiver that the web client is using, which is going to be great because the new receiver manages itself entirely. You'll get a consistent Chromecast experience no matter which device you launch from, and you can change devices on the fly, from web client to android and vice versa, without disrupting anything that the receiver is doing. So hang tight, we'll have it out for you soon. Going to be domestic disputes because my wife uses android and now im jealous
Glyde62 50 Posted September 3, 2014 Posted September 3, 2014 Sounds good Sent from the secret room in the back of your closet
heretostay 1 Posted September 17, 2014 Posted September 17, 2014 Any update as to when this will be released?
Luke 42242 Posted September 17, 2014 Posted September 17, 2014 Any update as to when this will be released? http://mediabrowser.tv/community/index.php?/topic/2344-android-client-release/?p=128518
Redshirt 1487 Posted September 18, 2014 Author Posted September 18, 2014 Just want to give everyone a heads up. Beta testing is in the final stages. We're no longer looking at weeks or months before the next release. Keep an eye out for the blog post in the days to come. There's so much going on, I think people will be very happy. 9
