badaas 139 Posted July 17, 2015 Posted July 17, 2015 Just gotta say this works like a charm! Was thinking I'd have to install filebot on my nas on a cron to sort out some naming issues on download, but no! AO best match just works wanders, everything so far is caught, renamed and moved perfectly. No more hassles for me 2
jasonmcroy 320 Posted July 17, 2015 Posted July 17, 2015 I totally agree. It is my most used non player feature of Emby. I use MCEBUDDY to cut commercials and drop the file into a folder that I have auto organize watching and it moves it automatically to the correct season folder in my tv shows folder. It is all so automatic now. -Jason
AgileHumor 123 Posted October 1, 2015 Posted October 1, 2015 I use this custom file naming pattern to ensure MCEBuddy still works when it can't find metadata: I've updated my custom file renaming as shown below:%ifseason%<%showname% - S%season%##E%episode%##,%showname% - %airyear%-%airmonth%-%airday%> This gives the following functionality:* If season found, use this naming format: %showname% - S%season%##E%episode%## * If season NOT found, use this naming format: %showname% - %airyear%-%airmonth%-%airday% This really helps for daily shows like the Late Show or Ellen that tend not to have metadata pre-entered on sites like the TVDB.
