philipmichener1954 0 Posted July 14, 2015 Posted July 14, 2015 I have an annoying problem while playing larger files (1080p movies). Movies load and start to play, then freeze to "load" further into the movie. Any way to improve the performance with larger file movies on the Samsung smart hub?
FrostByte 5453 Posted July 14, 2015 Posted July 14, 2015 Have you tried adjusting the bitrate setting in the Emby app? That may help. It should be set at, or below, what your TV/network can handle (max bitrate should be in your TV's user manual). A lot of my files are around 20Mbps with no issues and settings are at 30Mbps
