markshu 8 Posted July 28, 2015 Posted July 28, 2015 (edited) I've just about given up on the Android client. The only thing saving it for me is the play to external player feature, since it's been almost two months since the built-in player has been usable and the latest version has just made things worse. I've got a couple Lenovo IdeaTabs (both 7" and 10") running Android 4.2.2, and with the move to the internal VLC engine, I get sound but a completely blacked-out display. I know the server is sending video, since if I auto-rotate I get a single frame of video-in-progress as the system switches orientation, and then the picture blanks out again. The controls overlay displays just fine, but not the playing video. Before, I had picture-but-no-controls. Now, I have controls-but-no-picture. At least play to external player works ... Edited July 28, 2015 by markshu
Luke 42242 Posted July 28, 2015 Author Posted July 28, 2015 what kind of video? are there transcoding logs on the server?
ctrlaltdefeat 8 Posted July 28, 2015 Posted July 28, 2015 Been trying the new video player and I'm having an issue with it.. Report: http://emby.media/community/index.php?/topic/23785-subtitles-not-displayed-correctly-native-emby-player/
markshu 8 Posted July 29, 2015 Posted July 29, 2015 what kind of video? are there transcoding logs on the server? http://192.168.2.170:8096/videos/4b72a747d3d27762f83774876b2008aa/hlsdynamic/main/0.ts?DeviceId=00000000-0000-0000-2f3b-221ef07c58cf&MediaSourceId=4b72a747d3d27762f83774876b2008aa&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=3680002&AudioBitrate=320000&MaxAudioChannels=6&Level=41&ClientTime=635737482233972318&Profile=high&PlaySessionId=181dc7e3c1064c49a4e8c819341594db&api_key=891e98fecd594291af7858103496f240{"Protocol":"File","Id":"4b72a747d3d27762f83774876b2008aa","Path":"\\\\AIKO\\Movies\\mBluRay\\The Consultant [2011]\\The Consultant.mkv","Type":"Default","Container":"mkv","Name":"1080P/H264/AC3","RunTimeTicks":2370880000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","Language":"eng","IsInterlaced":false,"BitRate":18001194,"BitDepth":8,"RefFrames":4,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":23.97602,"RealFrameRate":23.97602,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false,"IsCabac":true},{"Codec":"ac3","Language":"eng","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":640000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"pgssub","Language":"eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":["mkv","webm"],"Bitrate":18001194,"RequiredHttpHeaders":{}}C:\Users\togashi\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150331\ffmpeg.exe -i file:"\\AIKO\Movies\mBluRay\The Consultant [2011]\The Consultant.mkv" -map_metadata -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 3680002 -bufsize 7360004 -vsync vfr -profile:v high -level 41 -force_key_frames expr:gte(t,n_forced*3) -flags +loop-global_header -sc_threshold 0 -codec:a:0 aac -strict experimental -ac 6 -ab 320000 -af "adelay=1,aresample=async=1" -hls_time 3 -start_number 0 -hls_list_size 0 -y "C:\Users\Public\MediaBrowser\transcoding\transcoding-temp\c1d08fee838fceb95097c05684deb1f3.m3u8"ffmpeg version N-71182-g5cba529 Copyright (c) 2000-2015 the FFmpeg developers built with gcc 4.9.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib libavutil 54. 21.100 / 54. 21.100 libavcodec 56. 32.100 / 56. 32.100 libavformat 56. 27.100 / 56. 27.100 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 13.101 / 5. 13.101 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100[matroska,webm @ 0000000002cd1a20] Could not find codec parameters for stream 2 (Subtitle: hdmv_pgs_subtitle): unspecified sizeConsider increasing the value for the 'analyzeduration' and 'probesize' optionsInput #0, matroska,webm, from 'file:\\AIKO\Movies\mBluRay\The Consultant [2011]\The Consultant.mkv': Metadata: title : The Consultant encoder : libmakemkv v1.8.11 (1.3.0/1.4.1) win(x64-release) creation_time : 2014-08-04 06:44:52 Duration: 00:03:57.09, start: 0.000000, bitrate: 18001 kb/s Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default) Metadata: title : Surround 5.1 Stream #0:2(eng): Subtitle: hdmv_pgs_subtitle Stream #0:3: Attachment: mjpeg Metadata: filename : cover.jpg mimetype : image/jpeg[libx264 @ 0000000005212300] using SAR=1/1[libx264 @ 0000000005212300] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX[libx264 @ 0000000005212300] profile High, level 4.1Output #0, hls, to 'C:\Users\Public\MediaBrowser\transcoding\transcoding-temp\c1d08fee838fceb95097c05684deb1f3.m3u8': Metadata: encoder : Lavf56.27.100 Stream #0:0: Video: h264 (libx264), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], q=-1--1, max. 3680 kb/s, 23.98 fps, 90k tbn, 23.98 tbc Metadata: encoder : Lavc56.32.100 libx264 Stream #0:1: Audio: aac, 48000 Hz, 5.1, fltp, 320 kb/s (default) Metadata: encoder : Lavc56.32.100 aacStream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (ac3 (native) -> aac (native))Press [q] to stop, [?] for helpframe= 95 fps=0.0 q=22.0 size=N/A time=00:00:04.39 bitrate=N/A frame= 164 fps=159 q=23.0 size=N/A time=00:00:07.27 bitrate=N/A frame= 228 fps=148 q=24.0 size=N/A time=00:00:10.06 bitrate=N/A frame= 293 fps=142 q=23.0 size=N/A time=00:00:12.69 bitrate=N/A frame= 353 fps=137 q=24.0 size=N/A time=00:00:15.21 bitrate=N/A frame= 409 fps=132 q=23.0 size=N/A time=00:00:17.51 bitrate=N/A frame= 468 fps=130 q=23.0 size=N/A time=00:00:20.01 bitrate=N/A frame= 531 fps=129 q=22.0 size=N/A time=00:00:22.61 bitrate=N/A frame= 593 fps=128 q=23.0 size=N/A time=00:00:25.19 bitrate=N/A frame= 656 fps=127 q=21.0 size=N/A time=00:00:27.86 bitrate=N/A frame= 720 fps=127 q=20.0 size=N/A time=00:00:30.57 bitrate=N/A frame= 781 fps=126 q=23.0 size=N/A time=00:00:33.04 bitrate=N/A frame= 848 fps=127 q=22.0 size=N/A time=00:00:35.75 bitrate=N/A frame= 904 fps=125 q=20.0 size=N/A time=00:00:38.16 bitrate=N/A frame= 955 fps=124 q=29.0 size=N/A time=00:00:40.27 bitrate=N/A frame= 1018 fps=124 q=22.0 size=N/A time=00:00:42.98 bitrate=N/A frame= 1084 fps=124 q=21.0 size=N/A time=00:00:45.67 bitrate=N/A frame= 1148 fps=124 q=21.0 size=N/A time=00:00:48.34 bitrate=N/A frame= 1216 fps=124 q=20.0 size=N/A time=00:00:51.15 bitrate=N/A frame= 1283 fps=125 q=23.0 size=N/A time=00:00:53.93 bitrate=N/A frame= 1350 fps=125 q=21.0 size=N/A time=00:00:56.68 bitrate=N/A frame= 1413 fps=125 q=20.0 size=N/A time=00:00:59.34 bitrate=N/A frame= 1476 fps=125 q=22.0 size=N/A time=00:01:02.03 bitrate=N/A frame= 1540 fps=125 q=20.0 size=N/A time=00:01:04.68 bitrate=N/A frame= 1604 fps=124 q=23.0 size=N/A time=00:01:07.28 bitrate=N/A frame= 1667 fps=124 q=24.0 size=N/A time=00:01:09.90 bitrate=N/A frame= 1730 fps=124 q=21.0 size=N/A time=00:01:12.61 bitrate=N/A frame= 1796 fps=124 q=22.0 size=N/A time=00:01:15.34 bitrate=N/A frame= 1858 fps=124 q=23.0 size=N/A time=00:01:18.03 bitrate=N/A frame= 1921 fps=124 q=22.0 size=N/A time=00:01:20.61 bitrate=N/A frame= 1987 fps=124 q=23.0 size=N/A time=00:01:23.24 bitrate=N/A frame= 2047 fps=124 q=22.0 size=N/A time=00:01:25.84 bitrate=N/A frame= 2109 fps=124 q=22.0 size=N/A time=00:01:28.49 bitrate=N/A frame= 2174 fps=124 q=24.0 size=N/A time=00:01:31.17 bitrate=N/A frame= 2237 fps=124 q=22.0 size=N/A time=00:01:33.73 bitrate=N/A frame= 2297 fps=124 q=23.0 size=N/A time=00:01:36.23 bitrate=N/A frame= 2361 fps=124 q=22.0 size=N/A time=00:01:38.92 bitrate=N/A frame= 2424 fps=124 q=20.0 size=N/A time=00:01:41.65 bitrate=N/A frame= 2484 fps=124 q=21.0 size=N/A time=00:01:44.04 bitrate=N/A frame= 2545 fps=123 q=23.0 size=N/A time=00:01:46.60 bitrate=N/A frame= 2606 fps=123 q=24.0 size=N/A time=00:01:49.09 bitrate=N/A frame= 2666 fps=123 q=22.0 size=N/A time=00:01:51.63 bitrate=N/A frame= 2725 fps=123 q=21.0 size=N/A time=00:01:54.06 bitrate=N/A frame= 2784 fps=123 q=20.0 size=N/A time=00:01:56.56 bitrate=N/A frame= 2845 fps=123 q=21.0 size=N/A time=00:01:59.08 bitrate=N/A frame= 2904 fps=123 q=23.0 size=N/A time=00:02:01.55 bitrate=N/A frame= 2967 fps=123 q=23.0 size=N/A time=00:02:04.18 bitrate=N/A frame= 3032 fps=123 q=22.0 size=N/A time=00:02:06.95 bitrate=N/A frame= 3087 fps=122 q=22.0 size=N/A time=00:02:09.13 bitrate=N/A frame= 3140 fps=122 q=23.0 size=N/A time=00:02:11.41 bitrate=N/A frame= 3201 fps=122 q=23.0 size=N/A time=00:02:13.97 bitrate=N/A frame= 3265 fps=122 q=23.0 size=N/A time=00:02:16.66 bitrate=N/A frame= 3325 fps=122 q=21.0 size=N/A time=00:02:19.15 bitrate=N/A frame= 3379 fps=121 q=22.0 size=N/A time=00:02:21.39 bitrate=N/A frame= 3433 fps=121 q=24.0 size=N/A time=00:02:23.65 bitrate=N/A frame= 3490 fps=121 q=24.0 size=N/A time=00:02:26.00 bitrate=N/A frame= 3546 fps=121 q=24.0 size=N/A time=00:02:28.37 bitrate=N/A frame= 3605 fps=121 q=23.0 size=N/A time=00:02:30.76 bitrate=N/A frame= 3661 fps=120 q=22.0 size=N/A time=00:02:33.10 bitrate=N/A frame= 3718 fps=120 q=24.0 size=N/A time=00:02:35.56 bitrate=N/A frame= 3778 fps=120 q=21.0 size=N/A time=00:02:37.97 bitrate=N/A frame= 3836 fps=120 q=24.0 size=N/A time=00:02:40.40 bitrate=N/A frame= 3912 fps=121 q=18.0 size=N/A time=00:02:43.60 bitrate=N/A frame= 3982 fps=121 q=22.0 size=N/A time=00:02:46.48 bitrate=N/A frame= 4044 fps=121 q=24.0 size=N/A time=00:02:49.06 bitrate=N/A frame= 4100 fps=121 q=22.0 size=N/A time=00:02:51.43 bitrate=N/A frame= 4161 fps=121 q=23.0 size=N/A time=00:02:54.03 bitrate=N/A frame= 4225 fps=121 q=23.0 size=N/A time=00:02:56.61 bitrate=N/A frame= 4288 fps=121 q=23.0 size=N/A time=00:02:59.37 bitrate=N/A frame= 4357 fps=121 q=22.0 size=N/A time=00:03:02.12 bitrate=N/A frame= 4420 fps=121 q=23.0 size=N/A time=00:03:04.87 bitrate=N/A frame= 4489 fps=121 q=22.0 size=N/A time=00:03:07.69 bitrate=N/A frame= 4566 fps=121 q=18.0 size=N/A time=00:03:10.82 bitrate=N/A frame= 4642 fps=122 q=18.0 size=N/A time=00:03:14.06 bitrate=N/A frame= 4728 fps=122 q=19.0 size=N/A time=00:03:17.61 bitrate=N/A frame= 4815 fps=123 q=18.0 size=N/A time=00:03:21.32 bitrate=N/A frame= 4903 fps=124 q=21.0 size=N/A time=00:03:25.01 bitrate=N/A frame= 4991 fps=124 q=22.0 size=N/A time=00:03:28.59 bitrate=N/A frame= 5082 fps=125 q=21.0 size=N/A time=00:03:32.39 bitrate=N/A frame= 5176 fps=126 q=20.0 size=N/A time=00:03:36.29 bitrate=N/A frame= 5272 fps=126 q=19.0 size=N/A time=00:03:40.30 bitrate=N/A frame= 5364 fps=127 q=22.0 size=N/A time=00:03:44.21 bitrate=N/A frame= 5459 fps=128 q=22.0 size=N/A time=00:03:48.11 bitrate=N/A frame= 5555 fps=128 q=25.0 size=N/A time=00:03:52.14 bitrate=N/A frame= 5658 fps=129 q=18.0 size=N/A time=00:03:56.52 bitrate=N/A frame= 5684 fps=129 q=-1.0 Lsize=N/A time=00:03:57.09 bitrate=N/A video:79099kB audio:8195kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown[libx264 @ 0000000005212300] frame I:80 Avg QP:10.71 size: 82498[libx264 @ 0000000005212300] frame P:1876 Avg QP:14.86 size: 23505[libx264 @ 0000000005212300] frame B:3728 Avg QP:16.26 size: 8128[libx264 @ 0000000005212300] consecutive B-frames: 6.5% 15.6% 7.4% 70.4%[libx264 @ 0000000005212300] mb I I16..4: 54.9% 28.1% 16.9%[libx264 @ 0000000005212300] mb P I16..4: 12.0% 5.8% 0.6% P16..4: 30.9% 0.0% 0.0% 0.0% 0.0% skip:50.7%[libx264 @ 0000000005212300] mb B I16..4: 1.9% 0.7% 0.0% B16..8: 14.6% 0.0% 0.0% direct:11.8% skip:71.1% L0:42.8% L1:49.1% BI: 8.1%[libx264 @ 0000000005212300] 8x8 transform intra:30.3% inter:40.6%[libx264 @ 0000000005212300] coded y,uvDC,uvAC intra: 35.2% 65.4% 51.4% inter: 5.8% 13.9% 0.9%[libx264 @ 0000000005212300] i16 v,h,dc,p: 63% 18% 14% 5%[libx264 @ 0000000005212300] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 17% 15% 34% 6% 5% 6% 6% 5% 6%[libx264 @ 0000000005212300] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 24% 12% 7% 6% 7% 6% 6% 6%[libx264 @ 0000000005212300] i8c dc,h,v,p: 54% 19% 19% 8%[libx264 @ 0000000005212300] Weighted P-Frames: Y:4.2% UV:2.8%[libx264 @ 0000000005212300] kb/s:2733.29
AM S1 1 Posted July 30, 2015 Posted July 30, 2015 Hi Luke I have 2.3.80, but still when direct stream te external substitles does not appears, when i reduce te quality to for expample 480p to force transcode then the subtitle apears regards Version 2.3.84 and still no subtitles when direct stream, only with transcoding regards
AM S1 1 Posted August 6, 2015 Posted August 6, 2015 Hi, Luke, any plans to solve the issue when the subtitles only appears when the video is transcoded, and not in directstream I have the same situation in: version app 2.3.84 galaxy S3, android 4.3 And Asus nexus 7, android 5.1.1 Thankyou regrads
Luke 42242 Posted August 7, 2015 Author Posted August 7, 2015 Yes, for the next release, make sure to participate in the android alpha area.
AM S1 1 Posted August 7, 2015 Posted August 7, 2015 Yes, for the next release, make sure to participate in the android alpha area. OK!! Luke Thanks
pünktchen 1411 Posted August 10, 2015 Posted August 10, 2015 Hi Luke, since the integration of VLC as a player, my Emby app is always crashing to Android home when trying to play a LiveTV stream. In the app log there is only "vlc exception" without any further information... Do you want the logs anyway?
Luke 42242 Posted August 10, 2015 Author Posted August 10, 2015 make sure to send a crash report if promoted to do so by the OS
pünktchen 1411 Posted August 10, 2015 Posted August 10, 2015 make sure to send a crash report if promoted to do so by the OS I have done this
Luke 42242 Posted August 14, 2015 Author Posted August 14, 2015 Am I too late to join??? Certainly not. It has been released so you can report issues based on the release version. If you'd like to help test pre-release builds, we're participating in google's open beta feature. You can signup here: https://play.google.com/apps/testing/com.mb.android You'll then start getting beta builds. In order to avoid confusion with the users on the release build, please use the Android alpha section at the bottom of the forum to discuss anything related to pre-release builds. Thanks.
AM S1 1 Posted September 12, 2015 Posted September 12, 2015 Hi Luke, something very strange happens, when streaming a movie with external subtitle, direct stream: 1) the movie starts playing 2) select the subtitles and displayed properly, everything is perfect, but suddenly, 3) for any reason, the video stutters and is pixelated for w few secconds and then again it playbacks normally and then it happens 4) automatically disappear subtitles 5) ok well then I select the subtitle option and yes, they are actually "none" 6) After this, again I select the subtitle waiting to appear again, but no, it happens that suddenly stops playing the video 7) when again select "none" the video starts playing and so on This means it can not longer display the subtitles, having to play from the beginning. This is a problematic situation. apparently when playback stutters, something happens with external subtitle stream Appreciate your help regards
Luke 42242 Posted September 12, 2015 Author Posted September 12, 2015 Try lowering the bitrate setting.
AM S1 1 Posted September 12, 2015 Posted September 12, 2015 Try lowering the bitrate setting. Ok I understand that lowering the bitrate we would be avoiding stuttering and therefore avoiding this issue but the subtitles should continue to work regardless if there is stuttering because of bandwidth problems?
Luke 42242 Posted September 12, 2015 Author Posted September 12, 2015 Does it even matter? A stuttering video is unwatchable anyway. I don't really see how that's worth spending any time dwelling on that.
AM S1 1 Posted September 12, 2015 Posted September 12, 2015 Does it even matter? A stuttering video is unwatchable anyway. I don't really see how that's worth spending any time dwelling on that. Luke but if the problem is only a few seconds and then corrected because some network traffic peak, however you think is right down the quality and make the server do transcoding? I think it would be worth trying to correct this and wait a few seconds of stuttering rather than putting the server to work hard and lose quality Video not stutter all the time, if that were the case, I do agree with you, the situation is that there are only a few seconds and the problem arises the video of which we speak is 720p h264 ACC, 800Mb bitrate, nothing problematic in the end anyway I think that regardless of whether the video is stopped for any reason and then continue playing, the operation of the player, in this case with the subtitles, should continue to function normally without reducing the quality of the transmission I think the decrease in video quality should be user's own choice, but should not be linked to a failure of the player. I do not know where the problem lies in this case, but if I could fix it, I would do it without thinking, I think any big or small problem, fix it would be worth to ultimately be the best product of its kind Regrads
AM S1 1 Posted September 18, 2015 Posted September 18, 2015 Hello again Luke reporting something happens to me on multiple devices with version app 2.4.25 Android 5.1 moto X 2014 Android 4.3 samsung s3 Forget the video is stuttering, in this case the video is played perfectly without subtitles This video and subtitle work perfectly in web player, they also work perfectly on other players as plex I mentioned above to tell you that the video and subtitles are OK This situation happens to all my videos with external subtitle .srt movie.mp4 (h264) AAC LC audio movie.spa.srt Once I start to play and select IMMEDIATELY external subtitles, these are deployed well. but if I pause playback, forward or rewind the video, Then the subtitles will automatically disappear, and then, if the subtitles active again, the video stops if I turn off the subtitles, the video is played again and so Besides if I start to play the video without subtitle and then forward the video and then, if the subtitles active again, the video stops if I turn off the subtitles, the video is played again and so I hope this is helpful to solve this problem Thank you
AM S1 1 Posted September 23, 2015 Posted September 23, 2015 (edited) Thanks, will test. Luke, thank you very much, Now, the problem of external subtitles, already fully corrected I think it was the new version of the server I thought the problem was with the client. Well, whatever, now everything flows Well, something additional that I think would be very good, is that the subtitles can be larger, especially on smartphones. regrads Edited September 23, 2015 by AM S1
Luke 42242 Posted September 23, 2015 Author Posted September 23, 2015 I am glad to hear it Yes it was the server all along.
AM S1 1 Posted October 6, 2015 Posted October 6, 2015 (edited) Hi Luke, I am very positively surprised, however, I do not know that this situation is due, as suddenly, when I reproduced a movie with DTS 5.1 audio and also one with 5.1 AC3 audio, video h264 4.1 on a MKV container. The films are heard and played in direct streaming, Great !! I use the native player of the Android application. android 5.1 lolipop in use: MotoX 2014 and Galaxy Tab (S) 8.4 You know what is allowing this ?? Emby? or Android? because as far as I knew, android natively does not support DTS or AC3 or MKV. Then Emby already supports these audio and video mkv? I would like to know Thank you Regards Edited October 6, 2015 by AM S1
ebr 16335 Posted October 6, 2015 Posted October 6, 2015 Both the Android mobile and Android TV apps integrate VLC as their playback engine (when possible) which is what allows us this type of playback.
AM S1 1 Posted October 6, 2015 Posted October 6, 2015 Both the Android mobile and Android TV apps integrate VLC as their playback engine (when possible) which is what allows us this type of playback.Ebr thanksExcelent! Enviado desde mi XT1097 mediante Tapatalk
