Not sure if bug or not with HDTC-2US (HDHomeRun EXTEND)
drakus72
I have noticed when I set my transcode option to Internet540, I have shows that recorded and live tv as well that I cannot watch in Emby but I can watch in WMC. I set it back to heavy transcode option and everything is fine, can watch recordings and live tv.
This is only on a couple of channels this happens to, not all of them.
I haven't checked any other live tv back ends yet to see if it is just serverwmc or emby or something else.
I have the logs posted here somewhere, will see if I can find a link to where I posted them at and edit this.
krustyreturns
I would like to see the serverwmc log when you can.
drakus72
I will see what I can do tonight. I have to scour through them.
Found them
Here are the transcode logs before and after.
http://paste2.org/LaZGZL6Z
The first 2 or 3 are before I changed to heavy. the last one (line 67) is after I changed to heavy.
I have not had a problem since changing to heavy.
Edited by drakus72
krustyreturns
I really wanted the serverwmc log after you try to play a video in Internet540 mode, but maybe we can skip that.  If you can't play a recording in emby that is recorded after the tuner is set to internet540, can you make a short 2 minute recording of a channel that doesn't work in internet540 mode?
drakus72
I have them, will send links later when I get home.
Will try to recreate the problem as well.
