PeteWhite67 0 Posted July 12, 2015 Posted July 12, 2015 Hi, Does anyone know where I can find the Comcerto installation package for MediaInfo 0.7.72-1. This particular version appears to be a dependency for Emby and the only one available on SynoCommunity is 0.7.73-2 which doesn't work. Cheers, Pete
PeteWhite67 0 Posted July 18, 2015 Author Posted July 18, 2015 Hi Luke, When I try to install Emby I get a dialog box asking me to install version 0.7.72-1.. As you can see from the screen grab attached, I have 0.7.73-2 installed. The annoying thing is that I had 0.7.72-1 installed and I thought it would be a good iea to upgrade!! Cheers, Pete
Luke 42239 Posted July 18, 2015 Posted July 18, 2015 i'm not really sure of the answer to this. the package might be hard-coded to that version. you can try posting here: https://github.com/SynoCommunity/spksrc/issues/1346#issuecomment-113430052
Gernash 19 Posted July 19, 2015 Posted July 19, 2015 (edited) @PeteWhite67 Current resolution http://emby.media/community/index.php?/topic/22921-synology-setup/?p=225118 Edited July 19, 2015 by Gernash 1
PeteWhite67 0 Posted July 19, 2015 Author Posted July 19, 2015 @@Gernash Thanks, that did the trick and its now installed OK. However, I do have a problem with adding libraries. I have all my, for example, HD films in "/volume1/Media/Movies HD", but when I try to add it to the library, I can't go any further than "/volume1/Media". if I try to add the folder manually I get a "The path does not exist." error! Any help would be appreciated. Cheers, Pete
Gernash 19 Posted July 20, 2015 Posted July 20, 2015 @PeteWhite67 Using WINSCP browse the folder properties you probably have the permissions setup incorrectly in your shard folders for access for different users.
