Deihmos 170 Posted July 12, 2015 Posted July 12, 2015 I want to replace my roku and htpc with either a nexus player or fire tv. they both will use kodi but i can't decide which one is the better option. The reviews for the nexus aren't very good but I assume there were software updates. The firetv only has 2.4ghz wifi which imo is really slow. Which one would you go with ?
JeremyFr79 228 Posted July 12, 2015 Posted July 12, 2015 I want to replace my roku and htpc with either a nexus player or fire tv. they both will use kodi but i can't decide which one is the better option. The reviews for the nexus aren't very good but I assume there were software updates. The firetv only has 2.4ghz wifi which imo is really slow. Which one would you go with ? I use 2.4Ghz Wireless N and get close to 200mbps sustained speeds. You don't need gigabit to stream a video file that at most uses 20mbps
Deihmos 170 Posted July 13, 2015 Author Posted July 13, 2015 I can't rely on 2.4ghz to stream live TV. That never worked well for me but it works well with wireless AC. I'm going with the nexus player. I see best buy has it on sale and I have, $10 coupon.
jasonmcroy 320 Posted July 13, 2015 Posted July 13, 2015 Plus, if you're planning on using Kodi it will be easier on the Nexus since it isn't offered via Amazon but is easy to download from Google. I am using a Nexus player and Nvidia Shield. Nexus isn't as powerful but still works great. -Jason
