reyes136 2 Posted July 10, 2015 Posted July 10, 2015 Is it possible for the tv guide on the firetv to show all channels? I know on the web viewer you can select show all channels but can't find on the firetv.
Guest Posted July 10, 2015 Posted July 10, 2015 can't you scroll them? I'm not sure if, but I think he means that channels without EPG data aren't shown in the guide section. To get to these channels one has to navigate via the live TV main menu entry..
Spaceboy 2573 Posted July 10, 2015 Posted July 10, 2015 I think he means that it only loads 50 at a time and he wants all
ebr 16336 Posted July 10, 2015 Posted July 10, 2015 I'm not sure if, but I think he means that channels without EPG data aren't shown in the guide section. To get to these channels one has to navigate via the live TV main menu entry.. This one is possible but I'm a bit torn on it. Are there a lot of these? I think he means that it only loads 50 at a time and he wants all This is just going to be the breaks. Loading any more than that simply won't perform well enough to be usable.
Spaceboy 2573 Posted July 10, 2015 Posted July 10, 2015 I'm not complaining, was just trying to help clarify
ebr 16336 Posted July 10, 2015 Posted July 10, 2015 I'm not complaining, was just trying to help clarify I know, no worries. I just wanted to answer both possibilities.
reyes136 2 Posted July 11, 2015 Author Posted July 11, 2015 Yes Spaceboy has it I would like to load more then 50 at a time so I can just scroll down through all the channels instead of having a long pause while loading the next set. I would rather have a longer load in the beginning then 4 different loads since I dont have a way to jump to channels. On the performance side is this a FireTv issue would using something like the Shield Android TV be able to handle this.
ebr 16336 Posted July 11, 2015 Posted July 11, 2015 Potentially but the app doesn't allow you to configure that at this point. My NP loads my 30 channel guide in less than a couple seconds but the Fire takes probably 6-8.
