c0m3r 95 Posted July 8, 2015 Posted July 8, 2015 (edited) It appears that the coverart treatment for thumbs has changed and I am now getting a mix of old and new which looks poor. I have tried re-scanning and refreshing the media library but nothing is working. Is there any way to force the change to the new treatment. (Not sure why it looks poor in the screenshot, doesnt look like that prior to upload.) Edited July 8, 2015 by c0m3r
ebr 16342 Posted July 8, 2015 Posted July 8, 2015 That's compression by the forum. You need to reduce the size of the image before you post it. As for the treatment style - I didn't anticipate anyone using that TV frame for anything other than actual TV episodes so it isn't automatically re-building for other types - which it looks like you are using it for. Deleting the enhanced image cache should take care of it.
c0m3r 95 Posted July 8, 2015 Author Posted July 8, 2015 Will give that a try. I am using it for both episodes and thumbnails. Will it auto re-build in the future? If not will just stop using the treatment for this type.
