ebr 16307 Posted July 19, 2015 Posted July 19, 2015 Look at all of the requests out of your server to ours. The are all failing the same way. It isn't just the invite. It definitely could be something between your box and our server but I know it isn't an issue on our server so the only thing we can do is investigate things on your end.
daz_pp 1 Posted July 19, 2015 Posted July 19, 2015 Look at all of the requests out of your server to ours. The are all failing the same way. It isn't just the invite. It definitely could be something between your box and our server but I know it isn't an issue on our server so the only thing we can do is investigate things on your end. I installed the exact same version of Emby on another pc on the same network behind the same firewall and that one worked ok. Same setup with firewall disabled and nothing else in the way network wise. The one I have problems with I have upgraded alot. The one that works I installed latest beta from your webpage now. The problem is on the other box I have. With your software in som way. Could it be old config conflicting with new somewhere ?
