fredg89 8 Posted July 7, 2015 Posted July 7, 2015 The first question is, how come the 3D indicator does not work on some movies? Example Second question: Has anyone figured out how to get musicbrainz picard to automatically place the "/" in the artist section? I'm having to manually edit each file that has mutiple artist and it would be awesome if there was a way to setup the picard app to automatically do it. This Needs to be this
Raff 51 Posted July 7, 2015 Posted July 7, 2015 In Picard under Options -> Tags there is an option listed "Join multiple ID3v2.3 tags with:" and / is one of the options. I like ; which is the default, so that may be where it is coming from for you. As for editing bulk files, I use Mp3Tag. It has a lot of options under "Actions" including "replace" that can be restricted by field. That is how I cleaned up the mess of Genres I had, but if you already have tags with ; and you want / that would work.
fredg89 8 Posted July 7, 2015 Author Posted July 7, 2015 In Picard under Options -> Tags there is an option listed "Join multiple ID3v2.3 tags with:" and / is one of the options. I like ; which is the default, so that may be where it is coming from for you. As for editing bulk files, I use Mp3Tag. It has a lot of options under "Actions" including "replace" that can be restricted by field. That is how I cleaned up the mess of Genres I had, but if you already have tags with ; and you want / that would work. Yeah, the tag works fine for mp3 but doesn't work correctly with FLAC. FLAC always produces Artist;Artist
fredg89 8 Posted July 7, 2015 Author Posted July 7, 2015 Are those items properly tagged as 3D? Yes sir. Here's a screenshot.
fredg89 8 Posted July 8, 2015 Author Posted July 8, 2015 Try an advanced refresh on them. Tried that and no dice.
ebr 16307 Posted July 8, 2015 Posted July 8, 2015 Tried that and no dice. You did an advanced refresh replacing all images? Do you have multiple profiles setup in CA? Possible those are in a different profile? If not, do the advanced refresh, bring up the item in an interface and then post the server log. Thx.
fredg89 8 Posted July 11, 2015 Author Posted July 11, 2015 You did an advanced refresh replacing all images? Do you have multiple profiles setup in CA? Possible those are in a different profile? If not, do the advanced refresh, bring up the item in an interface and then post the server log. Thx. This worked. Sometimes it doesn't...simple fix for if it doesn't is to go to the images tab and simply download a new image.
