avalon65 2 Posted July 21, 2017 Posted July 21, 2017 (edited) Do you have the nfs-common package installed on your Mint box? Not sure, how do I find out if they are. Edit, they were not, but are now, so yes I do Edited July 21, 2017 by avalon65
mastrmind11 722 Posted July 21, 2017 Posted July 21, 2017 Not sure, how do I find out if they are. Edit, they were not, but are now, so yes I do So I bet it works now. Run sudo mount -t nfs server_IP_addr:/share_name /local_mount_point 1
avalon65 2 Posted July 21, 2017 Posted July 21, 2017 So I bet it works now. Run sudo mount -t nfs server_IP_addr:/share_name /local_mount_point Marvelous, yes it has. Thanks for your perserverance and help
mastrmind11 722 Posted July 21, 2017 Posted July 21, 2017 Marvelous, yes it has. Thanks for your perserverance and help give the thread a solved and a like to help others 1
avalon65 2 Posted July 21, 2017 Posted July 21, 2017 Ok, wher do I do that give the thread a solved and a like to help others Ok, but where do I do that.
mastrmind11 722 Posted July 21, 2017 Posted July 21, 2017 Ok, wher do I do that Ok, but where do I do that. Look to the right of the page. There are a couple buttons. 1
avalon65 2 Posted July 22, 2017 Posted July 22, 2017 (edited) Look to the right of the page. There are a couple buttons. Is it a SOLVED button I am looking for, as all I see is buttons for: MultiQuote and Quote My problem has now been SOLVED, but I can't that particular button Edited July 25, 2017 by avalon65
jesdobr 0 Posted June 17, 2021 Posted June 17, 2021 geaves Thank you sooo much. I have been trying to find this for a long time.
