ffmpeg compiling switches
Gernash
Does anybody know what switches are needed to compile ffmpeg to work with Emby?
eg. --arch=i686 --target-os=linux --enable-optimizations --disable-altivec --enable-pic --enable-shared --disable-swscale-alpha --disable-ffserver --disable-ffplay --enable-nonfree --enable-version3 --enable-gpl --disable-doc --prefix=/opt --disable-asm --enable-libx264 --enable-libfaac
Is there any preferred way to compile it to work with less overhead etc for transcoding?
Gernash
No ffmpeg guru's around?
On a windows PC this is the ffmpeg info from Emby
ffmpeg version N-71182-g5cba529 Copyright © 2000-2015 the FFmpeg developers
  built with gcc 4.9.2 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib
  libavutil      54. 21.100 / 54. 21.100
  libavcodec     56. 32.100 / 56. 32.100
  libavformat    56. 27.100 / 56. 27.100
  libavdevice    56.  4.100 / 56.  4.100
  libavfilter     5. 13.101 /  5. 13.101
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  1.100 /  1.  1.100
  libpostproc    53.  3.100 / 53.  3.100
On a Synology with Cytec FFmpeg installed
ffmpeg version 2.6 Copyright © 2000-2015 the FFmpeg developers
  built with gcc 4.7.3 (crosstool-NG 1.18.0) 20130102 (prerelease)
  configuration: --enable-gpl --enable-version3 --enable-nonfree --enable-cross-compile --enable-rpath --target-os=linux --cross-prefix=/home/cytec/syno/toolchains/syno-x64-5.1/work/x86_64-pc-linux-gnu/bin/x86_64-pc-linux-gnu- --prefix=/usr/local/ffmpeg --extra-cflags=-I/home/cytec/syno/spk/ffmpeg/work-x64-5.1/install/usr/local/ffmpeg/include --extra-ldflags=-L/home/cytec/syno/spk/ffmpeg/work-x64-5.1/install/usr/local/ffmpeg/lib --extra-libs='-lxml2 -ldl' --disable-doc --disable-htmlpages --disable-manpages --disable-podpages --disable-txtpages --pkg-config=/usr/bin/pkg-config --enable-pic --disable-debug --enable-pthreads --enable-thumb --enable-libx264 --enable-libmp3lame --enable-libfdk-aac --enable-libspeex --enable-openssl --enable-libvorbis --enable-gpl --enable-nonfree --enable-libass --enable-libbluray --enable-libopenjpeg --enable-libopus --enable-libtheora --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-libvpx --arch=x86_64
  libavutil      54. 20.100 / 54. 20.100
  libavcodec     56. 26.100 / 56. 26.100
  libavformat    56. 25.101 / 56. 25.101
  libavfilter     5. 11.102 /  5. 11.102
  • 2 weeks later...
Getting closer need assistace from somebody who has spksrc or manual Synology cross compiling knowlage.
Need to compile cross/libva for ---enable-vaapi (xpenology crew) --enable-vdpau (Synology crew) I have been chassing libva down a x11 rabbit hole and getting stuck on "Package requirements (xcb-proto >= 1.11) were not met" I have found it but can't get it to work, I'm Assuming it needs Python to build it but not able to locate the commands.
Anyone out there that can put me onto somebody for assistance, would be greatly appreciated.
Edited by Gernash
My current build.
Small steps 10% faster
ffmpeg version 2.7.1 Copyright © 2000-2015 the FFmpeg developers
configuration: --enable-gpl --enable-version3 --enable-nonfree --enable-cross-compile --enable-rpath --target-os=linux --cross-prefix=/home/gernash/spksrc/toolchains/syno-cedarview-5.1/work/x86_64-pc-linux-gnu/bin/x86_64-pc-linux-gnu- --prefix=/usr/local/ffmpeg --extra-cflags=-I/home/gernash/spksrc/spk/ffmpeg/work-cedarview-5.1/install/usr/local/ffmpeg/include --extra-ldflags=-L/home/gernash/spksrc/spk/ffmpeg/work-cedarview-5.1/install/usr/local/ffmpeg/lib --extra-libs='-lxml2 -ldl' --disable-doc --disable-htmlpages --disable-manpages --disable-podpages --disable-txtpages --pkg-config=/usr/bin/pkg-config --enable-pic --disable-debug --enable-pthreads --enable-thumb --enable-libx264 --enable-libmp3lame --enable-libfdk-aac --enable-libspeex --enable-openssl --enable-libvorbis --enable-gpl --enable-nonfree --enable-libass --enable-libbluray --enable-libopenjpeg --enable-libopus --enable-libtheora --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-libvpx --arch=x86_64
libavutil 54. 27.100 / 54. 27.100
libavcodec 56. 41.100 / 56. 41.100
libavformat 56. 36.100 / 56. 36.100
libavfilter 5. 16.101 / 5. 16.101
libswresample 1. 2.100 / 1. 2.100
  • Like 1
Also need assistance with valgrind
Done
Edited by Gernash
  • Like 1
2015-07-16 03:54:22.8583 Info - Main: Emby
    Command line: /usr/local/emby/share/emby/MediaBrowser.Server.Mono.exe -programdata /usr/local/emby/var -ffmpeg /usr/local/ffmpeg/bin/ffmpeg -ffprobe /usr/local/ffmpeg/bin/ffprobe
    Operating system: Unix 3.10.35.0
    Processor count: 4
    64-Bit OS: True
    64-Bit Process: True
    Program data path: /usr/local/emby/var
    Mono: 3.12.1 (tarball Thursday 16 July 03:45:31 AEST 2015)
Building 4.0.2.5 going to sleep 4am
Edited by Gernash
#ref info
ffmpeg HW transoding.
Looks like it can be done on the DS Play models or XPEnology , the intel drivers are enabled so you can manipulate them for newer version (if needed.) if you go down the libva path. At this point you would have to hack the OS of the synology making it unstable with DSM updates (which i have no interest in doing). So at this point if anyone who knows about spksrc and has a synology play you can fiddle down this path. I have made up the cross files for spksrc (with my limited knowledge) and can email requested files for you to laugh at.
In my understanding the ffmpeg trans code path with VAAI is|  vid input==>ffmpeg==>libVA==>dummyx11 driver==>intel driver==>ffmpeg==>vid output
Hope this helps anyone.
DS415Play files
libva - DEPENDS = cross/wayland cross/libdrm
libdrm - DEPENDS = cross/libpthread-stubs cross/libpciaccess cross/valgrind
wayland - DEPENDS = cross/libffi cross/expat
libpciaccess - DEPENDS = cross/xorg-macros (the dev package)
Please correct me if I'm wrong so I can update info
Edited by Gernash
Hi Gernash ,
Thank you for contacting Synology support.
The inquired may be beyond the scope of Synology Support, please allow me to explain:
1. Unfortunately, this hasn't been supported and tested. However, I will be glad to put in an enhancement request regarding this for our developer analysis.
2. Unfortunately, I must apologize that currently we have no support for such modification and no engineer ever did what you want to modified. However, maybe you could take the following modification site as a reference, which are provided from the powerful users of Synology forum. We believe that this information could be more helpful for your achievement:
http://forum.synology.com/wiki/index.php/Modifications
Users of forums may be able provide other insight:
Thanks for your understanding and continued support.
Hope this helps.
Technical Support
Synology Inc.
Problem Explanation:
Question 1: Will the DS1812+ or any of the other atom based Synology NAS's have the intel onboard graphic drivers enabled to allow Hardware transcoding by 3rd party packages like EMBY,PLEX or Visualization Packages?
Question 2: The DS Play have custom/proprietary ffmpeg --enable-libh264_smd --enable-smd. Is the toolchain sorce available to this for development? If not can a transcoding capable version be built as a package install for these models so Emby/Plex make use of them.
Thanks in advance
Product Information/Question
Personal Information
Product:
DS1812+
Type of Customer:
End User
Product Version:
DSM 5.2-5592 Update 1
Company Name:
Edited by Gernash
So maybe Synology will adds the intel.ko files to some synology's in the future, But Hacking the OS is the path they recommend (ie Script.)
