juankroi 0 Posted March 15, 2016 Posted March 15, 2016 Hello, I'd like to install Emby server to the DS215J but I can't find all the packages needed. The CPU arch. is "Armada375" as stated in the link provided. About Emby, I can find this: emby_armada375-5.1_3.0.5597.1-3.spk About "ffmpeg", I can't find one for Armada375 here: cytec.us/syno/test-spk/ffmpeg, but only for Armada370. Did someone made Emby working on DS215J ?? I hope someone can hel, thanks a lot in advance. Did anyone finally succed with installation of emby server at Synology DS215j NAS?? I've bought one of this and would like to use emby there. Thanks
Darkjeje 11 Posted March 16, 2016 Posted March 16, 2016 Hello to all,Do you have any news concerning a stable version of Emby for Synology whitout Mono/Mediainfo/ImageMagic ? Is it planned that Emby for Synology Takes care the material transcoding of the DS214play, DS415play and DS216play to reduce the request to CPU during the transcoding ?
darkside2006 0 Posted March 18, 2016 Posted March 18, 2016 I have a DS413 with a FREESCALE QorIQ P1022 CPU and 1024MB of total Physical memory. When I followed the instructions under “Pre-Installation” and “Installation” in the original post I could not install “Mono” from the Package Centre as it did not appear there. The other packages “Mediainfo” and “ImageMagick” were listed and available for installation. A bit of research seemed to indicate to me that “mono” was not compatible with the Freescale Architecture. Does anyone know if Mono can be installed on my machine? Also, there did not seem to be any Installation instructions for the Freescale CPU – does this mean even after the Package moves from Beta, I will not be able to install on my machine? Many Thanks I have the same question. i tried the windows version and emby is really cool, but for now it seems there is no way to get it on the DS413. Is there any news to install this without mono?
hMeco 0 Posted March 21, 2016 Posted March 21, 2016 when i manualy update, i went from 3.0.5724.5 mine wont start now, and refuses my connection, the only way is to remove everything in my DSM and reinstall from scratch.is there a way to build the spk file?
Luke 42243 Posted March 22, 2016 Author Posted March 22, 2016 when i manualy update, i went from 3.0.5724.5 mine wont start now, and refuses my connection, the only way is to remove everything in my DSM and reinstall from scratch. is there a way to build the spk file? Hi, yes! Can you pose that question here? https://github.com/SynoCommunity/spksrc/pull/1673 Thanks!
hMeco 0 Posted March 22, 2016 Posted March 22, 2016 Hi, yes! Can you pose that question here? https://github.com/SynoCommunity/spksrc/pull/1673 Thanks! and hopefully they will make a spk file yay ;P gonna do it in a min or two
KRULL 10 Posted March 22, 2016 Posted March 22, 2016 I tried updating 8 times last week, using the exact same method that last worked for me, and it never took. I ended up giving up, and deleted Pushbullet plug in to stop the annoying update messages.
hexagram 5 Posted March 31, 2016 Posted March 31, 2016 Mono package from synocommunity causes a segfault. Mono from Xamarin can be installed. Need to modify start-stop-status script of Emby to point to the official synology package.
WebBuddha 1 Posted April 8, 2016 Posted April 8, 2016 (edited) I'm not able to install emby on DSM 6, because the packages are for DSM 5.1. Any ideas how I'm able to get it running? Edited April 8, 2016 by WebBuddha
burnz 0 Posted April 10, 2016 Posted April 10, 2016 I'm not able to install emby on DSM 6, because the packages are for DSM 5.1. Any ideas how I'm able to get it running? I installed the emby server within docker, it works great
Gernash 19 Posted April 19, 2016 Posted April 19, 2016 Building SPK I install Linux in a vm and use this https://github.com/SynoCommunity/spksrc then add coffee, face palming and some head beating against a wall.
simono5 21 Posted April 19, 2016 Posted April 19, 2016 I installed the emby server within docker, it works great Fancy pulling a quick guide together on how Emby is installed with Docker? I've tried to do it on my Synology but could never work out how to do it! Cheers!
yukes33 0 Posted April 21, 2016 Posted April 21, 2016 Hello everyone, I managed to make Emby work on my DS214 with DSM 6.0-7321. Everything is working fine except Mono that is taking almost all the RAM left (200MB) but that's OK. Has anyone tried to update to DSM 6.0-7321 Update 2 ? And if anyone knows how to reduce the RAM consumption (an alternative to the official Mono package maybe), I'm listening. I tried the Xamarin version but the Emby package didn't start at all so got back to the official one. Cheers
sonofdad 2 Posted April 23, 2016 Posted April 23, 2016 Didn't work for me with update 2 on a DS414 and still doesn't after just applying update 3. Would really be something special for Emby Co to comment on this. I'd be kicking myself if I were someone who had given money to Emby and now couldn't use the service.
Luke 42243 Posted April 23, 2016 Author Posted April 23, 2016 Didn't work for me with update 2 on a DS414 and still doesn't after just applying update 3. Would really be something special for Emby Co to comment on this. I'd be kicking myself if I were someone who had given money to Emby and now couldn't use the service. What exactly doesn't work? Can you provide a little more information? thanks.
horstepipe 423 Posted April 23, 2016 Posted April 23, 2016 Didn't work for me with update 2 on a DS414 and still doesn't after just applying update 3. Would really be something special for Emby Co to comment on this. I'd be kicking myself if I were someone who had given money to Emby and now couldn't use the service. Emby definitely works on DS414, but you have to make some manual adjustments, read here: http://emby.media/community/index.php?/topic/32554-dsm-6-ds414-armadaxp/
sonofdad 2 Posted April 23, 2016 Posted April 23, 2016 What exactly doesn't work? Can you provide a little more information? thanks. What doesn't work..... Exactly the same thing I reported on March 6th when DSM6 was still in pre-release. Seriously why is Emby Co still treating this like a complete mystery? Posted 06 March 2016 - 10:09 AM It's a DS414 Emby version package is listed as 3.0.5724.5-5 selecting run displays 'loading' for about 8-9 seconds then times out with no error message
sonofdad 2 Posted April 23, 2016 Posted April 23, 2016 Emby definitely works on DS414, but you have to make some manual adjustments, read here: http://emby.media/community/index.php?/topic/32554-dsm-6-ds414-armadaxp/ That post reads as three pages of someone saying "I did this and it works" followed by someone saying "I tried the same and it didn't but then I did something else and now it works". Frak it I can just use the in built media server to watch what I want if it's impossible to make an install package that actually works.
KRULL 10 Posted April 24, 2016 Posted April 24, 2016 What doesn't work..... Exactly the same thing I reported on March 6th when DSM6 was still in pre-release. Seriously why is Emby Co still treating this like a complete mystery? You're coming across as entitled, and as you have pointed out, you haven't paid for this. Your post yesterday was not helpful, as it had next to no detail, and you didn't bother to reference your earlier post. I.E, you're not helping yourself in anyway by providing relevant info. So please drop the attitude, it will not endear people to help you solve your issue.
sonofdad 2 Posted April 24, 2016 Posted April 24, 2016 So please drop the attitude, it will not endear people to help you solve your issue. No I'll just drop Emby as likely many others have due to it not actually running.
Luke 42243 Posted April 24, 2016 Author Posted April 24, 2016 What doesn't work..... Exactly the same thing I reported on March 6th when DSM6 was still in pre-release. Seriously why is Emby Co still treating this like a complete mystery? Hi, since that version is pretty old now, can you try with the latest version of Emby Server? Also what version of the mono runtime are you running? Thanks.
horstepipe 423 Posted April 24, 2016 Posted April 24, 2016 Mono package from synocommunity causes a segfault. Mono from Xamarin can be installed. Need to modify start-stop-status script of Emby to point to the official synology package. This is everything you have to do. If you had read the corresponding threads properly, you would have seen that hexagram wrote this a couple of times.
scyto 0 Posted April 25, 2016 Posted April 25, 2016 (edited) I am utterly confused by this thread. Are the instructions in the OP upto date and do they work in DSM6? For example it mentions installing ffmpeg manually - but i notice this is now in the community repo. I see some say it does work and some say it doesnt' and some say to install in docker. Is there official update guidance / community package i can install that does it all? Edited April 25, 2016 by scyto
verbumfeit 2 Posted April 26, 2016 Posted April 26, 2016 (edited) I got emby up and running on a friends DiskStation (DS415+) just a couple of days ago and here is what I did (read this post completely before trying anything): Follow the instructions in Post #1 (I installed ImageMagick beta from the Community): Pre-installation Package center-->Settings-->General choose-Trust Level any publisher Package center-->Settings-->Beta choose-Yes, I want to see beta version! Add http://packages.synocommunity.com/ and http://cytec.us/spk/ to Package center -->Package Source Check the what CPU/architecture you have in your synology https://github.com/S...r-Synology-mode so you can use the right Package for your base install.(#Shell command uname -a) Installation Install Mono from Package center --> Community Tab Install Mediainfo from Package center --> Community Tab Install ImageMagick using the build attached to this post Download and Install ffmpeg from here: http://cytec.us/syno/test-spk/ffmpeg/ Download and Install emby from here: http://cytec.us/syno/test-spk/emby/ Updating 1. Download Emby.Mono.zip from here: https://github.com/MediaBrowser/Emby/releases/latest 2. Extract the zip file into a folder 2. Download and install winSCP http://winscp.net/eng/download.php login as root to synology 3. Make sure the Emby service is stopped 4. Copy the contents of the zip file into /volume1/@appstore/emby/share/emby (or wherever it has been installed, the contents of the zip should look like the contents of the folder you are copying into) 5. Start Emby Important things are: Set up the server before updating to the newest version (Create a user, etc. Click Next until you are at the dashboard where emby tells you a newer version is available). Don't add library folders now. The update will perform a database upgrade which takes some time. Save that time by adding folders after the update. Make sure you stopped emby via the DSM Package Manager before updating. After updating: make sure the file owner/group of the updated files is set correctly. Otherwise emby won't start. (In my case it had to be emby:root. Check this before you overwrite the files) Optional: Edit the INFO file in /var/packages/emby/ (e.g. with nano) and change the version and changelog values to the correct version. This will be displayed in the DSM Package Manager. I'm using the mono beta from SynoCommunity (not Mono from Xamarin) and it works flawlessly. I tried it with Mono beta from Xamarin and it works just as well. Running on a DS415+ ----------------------------------------------- I was sooo confused reading this thread and jumping back and forth between the forum and github. It seems some DiskStations still have the mono segfault error and therefore have to use Mono from Xamarin. It would be nice if it could be determined which ones are affected and update the first post of this thread accordingly. Edited April 26, 2016 by verbumfeit 2
Simba 0 Posted April 26, 2016 Posted April 26, 2016 hello after the update i have problems Snapshot of MediaBrowser.WebDashboard.Api.GetDashboardResource generated by ServiceStack on 04/26/2016 11:19:42 Response Status Error Code Exception Message Error trying to resolve Service 'MediaBrowser.WebDashboard.Api.DashboardService' or one of its autowired dependencies (see inner exception for details). Stack Trace at Funq.Container.ResolveImpl[TService] (System.String name, Boolean throwIfMissing) <0x419fd4c0 + 0x00107> in <filename unknown>:0 at Funq.Container.ResolveNamed[TService] (System.String name) <0x41a313b0 + 0x00033> in <filename unknown>:0 at Funq.Container.Resolve[TService] () <0x41a31330 + 0x00027> in <filename unknown>:0 at (wrapper dynamic-method) System.Object:lambda_method (System.Runtime.CompilerServices.Closure,Funq.Container) at ServiceStack.Host.ContainerResolveCache.CreateInstance (System.Type type, Boolean tryResolve) <0x41a2c6d0 + 0x0012b> in <filename unknown>:0 at ServiceStack.Host.ContainerResolveCache.CreateInstance (System.Type type) <0x41a2c310 + 0x00013> in <filename unknown>:0 at ServiceStack.Host.ServiceController+<>c__DisplayClassf.<RegisterServiceExecutor>b__d (IRequest requestContext, System.Object dto) <0x41a2bcd0 + 0x000a5> in <filename unknown>:0 at ServiceStack.Host.ServiceController.Execute (System.Object requestDto, IRequest req) <0x41a2ac20 + 0x0009d> in <filename unknown>:0 at ServiceStack.HostContext.ExecuteService (System.Object request, IRequest httpReq) <0x41a2a620 + 0x0005f> in <filename unknown>:0 at ServiceStack.Host.Handlers.ServiceStackHandlerBase.ExecuteService (System.Object request, IRequest httpReq) <0x41a2a3a0 + 0x00013> in <filename unknown>:0 at ServiceStack.Host.RestHandler.GetResponse (IRequest request, System.Object requestDto) <0x41a29650 + 0x00077> in <filename unknown>:0 at ServiceStack.Host.RestHandler.ProcessRequestAsync (IRequest httpReq, IResponse httpRes, System.String operationName) <0x419e2740 + 0x006a1> in <filename unknown>:0
